| View Poll Results: Have you had an issue with your Direct Injection System? | |||
| I have had a DI issue and was fixed under warranty (Subaru) |
10 | 12.35% |
| I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) |
2 | 2.47% |
| I have had a DI issue and was fixed under warranty (Toyota) |
31 | 38.27% |
| I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) |
3 | 3.70% |
| I have had a DI issue and denied warranty by (Subaru) |
7 | 8.64% |
| I have had a DI issue and denied warranty by (Toyota) |
14 | 17.28% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) |
8 | 9.88% |
| I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) |
6 | 7.41% |
| Voters: 81. You may not vote on this poll | |||
#211 | |
Yes, 2012. |
#212 |
Drives: 1985 P-Type
Thanks @CSG Mike for posting the info from Stu on gt86ownersclub.co.uk. Great info! This needs to be highlighted and stickied. Hopefully some of the South African members can keep us posted on whether this updated software fixes the issue.
#213 |
Drives: They have four wheels
Just heard back from a friend at Lexus after showing him the pics from the RSA TSB. Apparently the injectors on the IS actually use two nylon collars where the pics here indicate only one.
#214 |
Drives: GT86
The thing is, all our cars will do this. They will all 'suffer' this. You just have to drive it in the 'right' way to make it happen.
The changes in calibration previously mentioned does not fix all the det issues. I get transient det if I slip the clutch slightly on changes, at any engine speed. Thing is, not all det is evil. I'm keen to find out what the composition of the cylinders are though, does anyone know? Is it some kind of coated aluminium? That Stu guy is a legend. I vote sticky! |
#215 |
Track Junkie
Drives: Faster than the Stig!
I really hope its an easy factory ecu flash fix.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#216 |
Drives: Scion FR-S/Toyota Yaris
My car has started giving a fairly loud exhaust cam sound coming right from the back of the engine above 5k remp in 3rd gear. I think its just the sound tube but who knows.
I am about to buy a tune and be done with it, the more I research this issue it goes further than the shifting. Tuners are reporting half as much knock overall vs the factory tune with their datalogging. WRX/STI owners all report an aftermarket tune is a must for engine reliability. Doubt this boxer is any different.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#217 |
Track Junkie
Bump for trying to collect more votes.
#218 |
Track Junkie
Seems like the number keeps rising
#219 |
Drives: Moped
#220 |
I check them often. Been the same for awhile. I keep expecting them to go up, but they really aren't much
#221 | |
I just checked and there are 37,729 registered members here at this site. Just using that as a baseline that would mean that .00063611545% of registered members have reported the issue
#222 | |
#223 | |
Drives: Moped
#224 | |
The number is most definitely higher than .0006%, but I would be shocked if it was higher than half a percent. |
| Tags |
| direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 06:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 12:35 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 06:54 AM |
| Wilwood Failure | SubieNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 46 | 04-09-2013 08:32 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 12:25 PM |
