Old 08-05-2013, 12:40 PM   #29
Kris_IIR
Cosmis Racing MRII 18x8.5 +22
I Got my BC Racing coilovers on Friday and threw them on with the new Cosmis Racing USA MRII's. Extremely happy with the fitment. Offset is perfect, no spacers needed! I am running 18x8.5 +22 all around, and 215/40 tires as well.
I currently only have Iphone pictures but I just did a shoot with Lowered Lifestyle so I will have quality photo's once they post the feature!
Kris_IIR is offline   Reply With Quote
The Following 2 Users Say Thank You to Kris_IIR For This Useful Post:
Cesium Rainbow (08-15-2013), Ohbean (08-05-2013)
Old 08-05-2013, 02:28 PM   #30
86TruenoFRS
Drives: Rocket Bunny v1 FRS
Are the backs of the wheels spacer friendly? Or is the surface that comes in contact w/ the hub flat w/ no holes?
86TruenoFRS is offline   Reply With Quote
Old 08-05-2013, 02:33 PM   #31
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Sexy
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 08-05-2013, 02:54 PM   #32
Kris_IIR
I'm assuming you are asking for bolt on spacers?
They are recessed, but not enough to clear the studs. The holes are only 1-2mm deep. I assume it's due to the wheel size/offset. The wider sets have alot deeper holes.
If you plan on running these on a stock body FRS/BRZ you wont need spacers. I am running -2 front and -3 rear degree's of camber to fit with no rubbing.
Old 08-08-2013, 02:31 AM   #33
Xovit
Drives: 2002 Camaro
Curious, how much of a drop would you say you currently have? Would you say its less then 2in?
Xovit is offline   Reply With Quote
Old 11-18-2013, 07:50 PM   #34
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @Kris_IIR's topic: same wheels w same specs
Old 11-18-2013, 07:58 PM   #35
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
To answer this question. The back of the wheel is flat and will not accommodate a bolt on spacer that is less than 25mm.
Old 02-20-2014, 06:18 PM   #36
Umbie
Umbie's Avatar
Drives: 2013 Subaru BRZ
Bump for question:
I am sooo close to purchasing these wheels, and have just done a ton of research on wheel offset, etc. I was concerned that the +22 offset would be too far outboard, thus potentially harmful to the wheel bearings and steering system. Furthermore, research is suggesting that this will have a negative effect on handling.
Can someone tell me if there is any truth to these statements? Has anyone who installed these wheels experienced these problems?
FYI I will be running Apexi N1 coils, 1" drop, 18x8.5 +22 offset Cosmis MRII.
2013 Subaru BRZ Limited M/T CBS
1998 Subaru Legacy 2.5GT
1966 Pontiac GTO 6.5L V8
1986 Jeep CJ 4.2L I6
Umbie is offline   Reply With Quote
Old 02-20-2014, 06:30 PM   #37
BugeyedWagon
Suby Specialist
Wheel Directory: Cosmis Racing Wheels 18x8.5 +22
I ran them with tein S tech springs and the natural camber associated with a 1.5" drop on stock shocks. I had some poke in the front and was flush in the rears running a stretched 225/45 tire.
As far as wear on wheel bearings, I did not have the setup long enough to say for sure. In general, a wider track width can wear out wheel bearings much faster. Handling is dependent on tire and camber/caster. With the track width wider the car does not get as loose in the rear.
These wheels are really looks only and not a performance setup. If you want performance get a set of enkei rpf1 17x9 +35 and some sticky 245/255 tires.
The Following User Says Thank You to BugeyedWagon For This Useful Post:
Umbie (02-21-2014)
Old 05-16-2014, 05:42 PM   #38
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
Because of caster, the change in offset has an effect on what happens up front when you turn the steering wheel called "corner jacking". The reduced positive offset would increase the corner jacking effect and come with the related changes to handling, especially during turn-in. You also change the scrub radius which affect vehicle stability, especially under braking.
Eau Rouge is offline   Reply With Quote
Old 03-06-2015, 08:15 PM   #39
sachu
Drives: rocketship
bumping this thread. anyone else running these wheels? how's the handling with the more aggressive offset?
any long term reviews?
sachu is offline   Reply With Quote
Wheel Directory: Cosmis XT-005R 18x9.0 +25 HarrisRees Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 07-20-2018 10:14 PM
Cosmis Racing Wheels @ Import Image Racing!****************************************** ImportImage Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-04-2013 03:40 PM
Cosmis Racing Forged 18x8.5 +22 20lbs JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-02-2013 04:34 PM
