Old 08-01-2013, 09:11 PM   #183
cnk
Drives: '13 DGM BRZ Limited
So far I only get that one pop on the first drive of the day when I turn the wheel and it's dead silent the rest of the day. I'll keep it like this until they get worse. . hopefully not, but if/when they do I'm hoping a fix will be available. Otherwise, I think I'll just throw some Group N mounts on and call it a day.
Old 08-01-2013, 09:25 PM   #184
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
This is with the Subaru OEM Conical Washers installed right?
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-01-2013, 09:51 PM   #185
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
So are people actually running the conical washers on the factory style strut? With the washer welded on the spring cap, I would think it should be unnecessary. I am not above adding a conical washer to my setup if it will stop the popping/clunking. The reasoning behind needing the conical washer for the high camber/caster does make some sense.
console_cowboy is offline   Reply With Quote
Old 08-01-2013, 10:01 PM   #186
cnk
Yes. . with the conical washer. I'm running KW V3's though.
Old 08-01-2013, 10:24 PM   #187
I have the RCE Tarmac 2 Clubsports + conical washer + Stock Mounts ... Which is basically the KW V3s with RCE springs ... and have had zero problems with clunking/spring binding since putting in the conical washers ... I was about to pull the trigger on the Whiteline COM C's but now I think I'm just going elsewhere for replacement of the caster/camber plate/stock top ....
Old 08-01-2013, 10:40 PM   #188
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I'd really like to know what the fix is.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 08-02-2013, 03:08 PM   #189
console_cowboy
Well I finally spoke with Jan at Whiteline today. He claims that even the newer style koyo bearing com-c top hats have some similar issues to the original black bearings. They claim the newer version of the top hats should have no issues. I am currently waiting on a warranty replacement now. I guess I should be happy that they at least send the new top hats before I have to remove the old ones.
Old 08-02-2013, 03:14 PM   #190
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
New version meaning newer than just the revision with the koyos? I've had two copies with the koyos, both had the same problems - waiting on a 3rd set, wondering if there are physical changes that I can look for in this new revision.
Sent from my SGH-M919 using Tapatalk 4 Beta
mikalem is offline   Reply With Quote
Old 08-02-2013, 03:17 PM   #191
whataboutbob
AutoX-10/10ths every run
I've been running the latest COMCs on RCEs with the Subie conical washers for 6+ weeks. No issues so far.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
console_cowboy (08-02-2013)
Old 08-02-2013, 03:47 PM   #192
console_cowboy
I don't know if there is an actual physical revision. Perhaps it is just a change in the hardness of the rubber or they had a batch of bearings with issues. Whiteline did say that they had made changes though.
I am curious to try the conical washer on mine. I believe I will attempt that during the fresh install. Did you try them without the conical washers? Do you still use the factory spring cap?
Old 08-02-2013, 03:50 PM   #193
whataboutbob
The first set of COMCs I had I ran without the washers and they were noisy. I read up and obtained the washers which I used with the replacement set of COMCs. Still using the factory spring cap. You'll definitely need a spring compressor to run the washers as the additional stack height made it impossible for me to get the nut back on by hand.
Build thread:Here
Old 08-02-2013, 03:57 PM   #194
console_cowboy
Ah that's less fun. The spring compressors for rent around here are pretty terrible. How thick are the conical washers?
Old 08-02-2013, 04:01 PM   #195
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Probably 2mm. The irony is that I have emails from Jan months ago asking if a conical washer should be used on the new Koyo bearing'd Com-C's and he insisted that they weren't necessary.
The washers will increase the ride height in the front by that amount if you don't have adjustable coilovers.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
console_cowboy (08-02-2013), whataboutbob (08-02-2013)
Old 08-02-2013, 06:02 PM   #196
OrbitalEllipses
Drives: Attitude
You should only be using the washer if you are NOT using the OEM upper spring perch, which you mean you're more than likely on a threaded body coilover.
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
