Old 07-24-2013, 08:22 PM   #71
Suberman
Drives: Subaru BRZ Sport Tech Satin White
I just had mine installed and it isn't snug to the windshield at the top of the adapter. It vibrates and is hard to adjust because it moves around as you try to adjust it. I think the design is defective and I'm asking Subaru for a fix or a refund.
Suberman is offline   Reply With Quote
Old 07-24-2013, 08:50 PM   #72
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
yea if they stripped the screw which seems to be the case for most of them, it'll end up loose. I'd ask them to try another mounting adapter. if they can't get it right, refund
abutterman is offline   Reply With Quote
Old 07-26-2013, 01:12 AM   #73
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Mine fell off today too... On my way home from the dealership...
Back again tomorrow
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 07-30-2013, 11:38 AM   #74
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
the same thing just happened to mine. i see you guys haven't noticed that you can unplug the mirror instead of taping it to the dash.
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 08-02-2013, 03:37 PM   #75
BryanGT
Drives: WRD BRZ Limited
My mirror is about to fall off, too.
BryanGT is offline   Reply With Quote
Old 08-02-2013, 04:20 PM   #76
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Already had mine replaced 2 months ago and it's starting to rattle again. Hopefully this new piece fixes it for good!
rapidcars is offline   Reply With Quote
Old 08-02-2013, 10:39 PM   #77
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
my rearview mirror ate shit today! wtf scared the bejeezus outta me when I was cornering -_____-"
Subaru dealerships better give it a perma fix for free or else I'd be really really pissed.
KelvinBRZ is offline   Reply With Quote
Old 08-04-2013, 10:40 AM   #78
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Fixed mine myself, dealership hemmed and hawwed about it but did little to fix it once they figured the part was stripped. (Hadwin White in Myrtle Beach, living up to their reputation for poor service). I used the opportunity to upgrade from the Auto Dimming mirror to a Homelink and fixed it myself with a new adapter kit. When it eventually fails, I'll use bigger screws that don't taper.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 08-04-2013, 10:45 AM   #79
BRZnut
Drives: BRZ DGM Limited
I also fixed mine myself with JP weld and black caulk. Looks fine and no wiggles over rough roads.
Good to know they have a Subaru dealership in the Myrtle Beach area.....we spend a lot of time in Murrells Inlet which will be our home in a few years
Old 08-04-2013, 11:34 AM   #80
WolfSongX
WolfSongX's Avatar
I live in Surfside so feel free to look me up the next time you come down. My wife takes her Outback to the dealership in Charleston since Hadwin-White hit strike 3 with her after screwing up her first service. My amp for the door speakers just went bad, so if the service is bad this time, I'll be going there as well.
With the mirror, I stopped by the day the mirror fell off, before the service department closed to be turned away by the service manager, so I found the general manager who got the parts manager to take a look. When they figured it was stripped, they told me they would find the parts ASAP. I didn't hear from them and did my own research on here. I decided to finally call them with the necessary part numbers a week later, then still didn't hear back from them. There was enough time for me to lose patience, locate, order, receive and install the parts and to this day I STILL haven't heard back from them.
To me, this is horrible service showing a total disregard for the customer. My previous car was a Civic Si and I had some of the best service, I've ever had from a local dealer, and a problem like this, especially involving essential safety equipment like this, would've been handled with the highest priority, and I have never had to call them to follow up on a warranty issue after bringing the car by, they would call with constant updates until the issue was resolved.
Derek
Old 08-04-2013, 11:45 AM   #81
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
This happened to me awhile back as well. Started with the homelink mirror wiggling on it's mount, then when crusing on the highway it started to rattle. Stopped at a gas station and wiggled it a bit more then it literally just popped off - luckily I was able to catch it. Tried to screw it back in, but after reading this topic beforehand, I knew there wasn't much i could do since the holes were stripped. Managed to get it to dangle off of the mount and the next day took it in for maintenance. Told the service manager what happened, had it fixed same day. Haven't had a problem since.
Had I not had the opportunity to visit the dealership, I probably would've just put some Loctite threadlocker on the screws, it might've fixed it temporarily.
mikeTee is offline   Reply With Quote
Old 08-04-2013, 02:46 PM   #82
xjohnx
Grip>Slip
xjohnx's Avatar
Got the new part in the mail on Friday, will be installing it tomorrow and will report back. The screws are in fact different this time around.
Old 08-04-2013, 09:55 PM   #83
WATCHMEHEAL
WATCHMEHEAL's Avatar
Drives: 2015 Subaru WRX STI Ltd
I am also having the same issue. They re installed it but now it is still shaking.
I will setup another appointment when I do my oil change and get them to switch it again until this fucking shit is fixed.
WATCHMEHEAL is offline   Reply With Quote
Old 08-04-2013, 10:45 PM   #84
Vten
Drives: Too heavy
I found that the screws that bolted to the base are somewhat too short , I may go to a hardware store tomorow to find a longer bolts .
For now I double tape the metal part on the base so it doesn't move around. If you part open the base you'll know what I'm talking about
Vten is offline   Reply With Quote
Yen to Dollar conversion link whataboutbob Scion FR-S / Toyota 86 GT86 General Forum 2 08-31-2012 12:51 PM
Gearbox: Cable Link or Mechanical Link? Marrk BRZ First-Gen (2012+) — General Topics 42 07-02-2012 12:45 AM
Saw a car, fell in love, deposit down.... Did I do alright?? Chewie4299 Scion FR-S / Toyota 86 GT86 General Forum 13 06-22-2012 12:52 AM
