Old 07-27-2013, 03:00 AM   #15
NinjaRxMan
NinjaRxMan's Avatar
What if the car is left in gear when you remote start with a manual transmission? Is the system smart enough not to start the car?
Old 07-27-2013, 11:55 AM   #16
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Interesting...nice to know us regular FRS folks can also have a push start if we wanted one..now for that fancy climate control system
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
Old 07-27-2013, 11:59 AM   #17
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
In a typical installation with manual transmission. The car has to be in "reservation mode" for it to be remote started. That is foot on brake, hand brake up, foot off brake, key out, get out of car, car turns off when the door closes.
I never installed a remote start in a manual car with push button though.
projek_01 is offline   Reply With Quote
Old 07-27-2013, 01:18 PM   #18
thill
Originally Posted by Nevermore View Post
How much does that easygo system cost? I might be interested in that in the future!
Some folks have messed with this on the forum and did not have good results with it.
The Following User Says Thank You to thill For This Useful Post:
Nevermore (07-27-2013)
Old 07-27-2013, 02:06 PM   #19
Dustin2JZ
StatusLow
Dustin2JZ's Avatar
Drives: 2013 10 Series FRS
Originally Posted by projek_01 View Post
The only issue with a alarm/starter combo with the smart key is how the car will react when you get in the car with your key. The second you press the brake pedal, the starter brain will cut out. Either the car stays on and the real key takes over or the car shuts off. I am going to guess the car will get confused and turn off. We may have to wait till idatalink figures it out.... may be why its taking forever to release.
The way the Xpresskit Universal Proximity Key Bypass works is it temporarily powers a second key to be able to start the car, then stops powering while the car stays running. Removing the key then getting in with another key does not make the car shut off. Nothing changes except it will beep after the first key stops being powered to let you know the car is running but does not detect a key in range.
As for the Manual Transmission, @projek_01 Was right And while all remote starts dont have "reservation mode" they all have a "Nuetral/Hand Brake Safety Switch" So in an automatic its wired to the Nuetral switch, in a manual its wired to the Hand brake and will not start unless the brake is applied. The onwer has to have a bit of intelligence as well, don';t leave it in gear if you want to remote start.
Even without remote start I have had a manual for 10 years and have never left it parked in gear, just no point.
Dustin2JZ is offline   Reply With Quote
Old 09-23-2013, 09:11 PM   #20
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Sorry to necro this thread, but did you ever get the remote start working in your car?
Prog is offline   Reply With Quote
Old 09-27-2013, 11:20 AM   #21
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
We are actually pretty lucky. Our cars have a neutral signal built into the MANUAL transmission. If you tap into this wire the car will not start if it is in gear. I have had a couple cars with remote start on manual transmissions and to be honest it isn't smart. I left it in automatic mode so I didn't have to deal with the pedal dance bs. I thought I ALWAYS left my car in neutral until one day I didn't. Easily overpowered the e brake and plowed into a fence post came out to the starter going and the wheel spinning. (Dirt). Oops. I am interested to see what you find. I've been looking for a solution and haven't found it yet.
calispec is offline   Reply With Quote
Old 10-17-2013, 08:54 AM   #22
Jay_viper
Drives: none
Hello all I'm new here and I don't own brz or fr-s but I do think they are a very nice vehicle inside and out. I am also a Autotech with Best buy and I was searching threads the past couple of weeks to find information about doing a viper 5904 on a 2013 brz limited push to start manual trans. as I had an Install set up for one this past week. I'll tell you that there is not a lot of info on this car for adding aftermarket Remote start. Well after doing some research and physically looking at the vehicles wiring I got the viper 5904 Installed and fully functional. I will tell you the dei tech documents for this vehicle are missing some info. I did have to use the dei 1101t but there was a little more to it to get it to work(4 extra relays and 9 diodes). The wiring info was a little off but was easy enough to figure out. While doing research I came across this post and wanted to know has anyone else has done a viper remote start on a brz limited with the PTS and manual trans.? If so any issues that you ran into so far? Well I'll also be checking in to see what you all say.
Jay_viper is offline   Reply With Quote
Old 10-17-2013, 09:13 AM   #23
calispec
calispec's Avatar
When you use the 1101t and the car is started, if someone were to get into the car somehow what would keep them from just driving away? If you start the car, get out and leave your keys in the house the car works fine until you get to your destination and can't start your car again. I am a few weeks from attempting a smart start. I was an AutoTech as well.
Old 10-18-2013, 01:06 PM   #24
Jay_viper
Drives: none
The 1101t has a built in battery for the factory key fob. You will have to solder the wires directly to the circuit board in the fob. The 1101t will only allow the key fob to be powered when remote started. There is a little more wiring you have to do to get it to work for take over mode. But once the door is unlocked with the aftermarket system you have 30-45 sec to hit brake for take over and it must see the second key fob or it will shut the car down. That is with the 5904 any way. The smart start may not work for take over if you are using a vss3000 or vss4000. You need 3 programmable aux outputs to get take over to work. I would recommend either the vss3001 or a 5 series viper system with add on smart start. I took very detailed notes while I was Installing it so if you have any questions feel free to ask.
The Following User Says Thank You to Jay_viper For This Useful Post:
calispec (10-24-2013)
Old 02-17-2014, 04:44 PM   #25
Greenhorn
Greenhorn's Avatar
Drives: 2013 FR-S 10-Series #1394
Looking to do this exact same thing with a Viper 5806V and a VSM250. Can the OP, @TheBatman, or @calispec elaborate on your experience actually installing your r/s?
Greenhorn is offline   Reply With Quote
Old 02-17-2014, 04:46 PM   #26
Greenhorn
Greenhorn's Avatar
Does this still require using an interface like the FLCAN for the keyless entry?
Old 02-18-2014, 09:54 AM   #27
calispec
calispec's Avatar
Originally Posted by Greenhorn View Post
Looking to do this exact same thing with a Viper 5806V and a VSM250. Can the OP, @TheBatman, or @calispec elaborate on your experience actually installation your r/s?
I used the 1101t for my smart start install. It does not take over and there is no way to turn the car off via the phone or fob once it has been remote started. Someone could potentially brake the window and drive the car away if they wanted to but I have insurance for that. I planned on fixing all that with an arduino but never got around to it. I will when it gets warm and post the code in my build thread. The factory fob is ignored once the car is started so you will have to carry around a viper key fob (or phone) and the factory key fob. The install was pretty easy. Check out my build thread for a little more info.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
Old 02-21-2014, 12:15 AM   #28
Greenhorn
Greenhorn's Avatar
Looked through your build thread - definitely some helpful info. Any idea what @Jay_viper is talking about with the secondary fob take over? Which remote start module did you use? One of the all-in-one smart start guys, or a 'normal' one and the smart start add-on?
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 03:43 PM
Scion Factory Remote Start? mikeg7827 Electronics | Audio | NAV | Infotainment 16 12-24-2013 02:00 AM
Request remote start info Fallen hero Scion FR-S / Toyota 86 GT86 General Forum 0 12-21-2012 01:32 PM
Schematic for remote start install? empower-auto Electronics | Audio | NAV | Infotainment 3 07-31-2012 06:13 PM
Compustar needs a BRZ w/PTS for remote start info. burnt_rice Northwest 2 06-19-2012 06:31 PM
