Old 07-22-2013, 10:18 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Tyre size for 18x8.5 +44 F 18x9.5 +44 R
Seeking some advice about which tyre size for 18x8.5 +44 F 18x9.5 +44 R setup. I'd prefer to run square tyres, on the staggered rims.
I'll probably lower about an inch from stock.
I was thinking 235/40's all around (have confirmed that I can legally put this on a 9.5 rim) but to be honest, I think the low profile tyre / stretch thing looks a little average, and they do look stretched on a 9.5 rim.
So am thinking also about 255/35 all round. But I'm concerned about these rubbing. They have less OD than the 235/40's, and the 255/35's end up being super close to my stock OD. But I'm seeing setups that have to dial in quite a bit of camber to get these tyres to tuck in, although these were +40 or +38 setups, so my offset works in my favour here.
Thoughts?
diss7 is offline   Reply With Quote
Old 07-22-2013, 10:25 PM   #2
diss7
Or whether I should just give up the idea of running a square tyre setup, and go 225/40 on the front and 255/35 on the back.
Old 07-23-2013, 01:34 AM   #3
pumice
Drives: Argento FRS
My Enkei Raijins are 18x8.5 front and 18x9.5, +45 all around. I ended up going 225/40 up front and 255/25 in the rear. I almost went 245/35 up front, but changed my mind at the last minute. I'm very happy with how it looks.
http://www.ft86club.com/forums/showthread.php?t=42066
pumice is offline   Reply With Quote
The Following User Says Thank You to pumice For This Useful Post:
diss7 (07-23-2013)
Old 11-19-2014, 04:44 PM   #4
kylethomas23
kylethomas23's Avatar
Drives: 2014 brz
Do you have a picture of this setup? Looking for tire size for same wheels
kylethomas23 is offline   Reply With Quote
Wheel Directory: XXR 531 18x8.5 +35 / 18x9.5 +35 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-07-2013 01:43 PM
Considering going from 18x8.5ft/18x9.5back to 18x9.5 squared what to expect?? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-18-2013 11:10 AM
Tire size for 18x8 wheels?225/40 or 245/35 FT86RGV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 06-06-2013 02:24 PM
Hub Size for 18x9.5 TE37SL in 5x100? shu5892001 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-25-2013 04:59 AM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 10:52 AM
