Old 07-22-2013, 10:54 AM   #1
swift996
swift996's Avatar
FI Dyno thread
I wanted to make an archive of people's best dyno run with their configuration.
Please ONLY POST a DYNO (there is no need to comment)
Format:
- Name/Screen Name
- Force Inducted Kit
- Fuel Type
- Max Boost
- Other Mods
- Other Notes/Conditions, Tuner, etc. (include link to other thread where people can go comment/ask questions if desired)
- PIC OF DYNO
If you have any comments or suggestions feel free to PM me, let's try and keep this clean and a valuable resource.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following 11 Users Say Thank You to swift996 For This Useful Post:
diss7 (07-23-2013), GhostOp86 (12-10-2015), MadFRS (07-22-2013), mwjcyber (08-04-2013), PineappleFriedRice (07-23-2013), R/T Tuning (10-15-2013), Ross (07-25-2013), SkAsphalt (09-03-2013), slates74 (07-23-2013), Sportsguy83 (07-22-2013), WHITE (07-22-2013)
Old 07-22-2013, 10:56 AM   #2
swift996
swift996's Avatar
- Jon Swift/Swift996
- Innovate Supercharger (Tuner Kit - Stage 1) Tuned by Moto-East
- E50
- Provided Pulley ~7PSI
- K&N Drop-In Filter, FA20Club Catted Header, FA20Club Resonated Front Pipe, 700CC Injectors
- 4th gear pulls, 102F degree ambient temps (ran 180whp on different DynoJet prior to supercharger)
86_Insider (07-23-2013), akuhei (07-22-2013), cmss2000 (07-22-2013), Jtymay92 (07-22-2013), lexusb3 (07-22-2013), mwjcyber (09-07-2014), NickFRS (07-23-2013), nix (07-22-2013), normancw (11-01-2013), RedAlert (07-23-2013), Sportsguy83 (07-22-2013)
Old 07-22-2013, 11:16 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
- Chris Tuttell / King Tut
- Full Blown Motorsports Stage 1 Base Turbo Kit
- 93 Octane/Bosch 550cc Port Injectors/Full Blown Fuel Pump
- 12.5 psi
- Garrett GT2871R Oil/Water Cooled Ball Bearing Turbo, Precision Turbo 39 mm External Wastegate, Tial 50 mm Q Blow Off Valve, Go Fast Bits G-Force II Electronic Boost Controller, JDL Auto Design 2.5" Overpipe, JDL Auto Design 2.5" Frontpipe, GReddy Evo3 Exhaust, ACT Heavy Duty Pressure Plate/6 Pad Sprung Race Disc Clutch, ACT XACT Prolite Flywheel, D3 Performance Engineering Catch Can
- 90F+ Temps, Rain, 4th Gear Pull
The Following 12 Users Say Thank You to King Tut For This Useful Post:
akuhei (07-22-2013), arxm (05-24-2018), Boris_Petrov (07-05-2019), ChrisD (01-02-2016), cmss2000 (07-22-2013), lexusb3 (07-22-2013), mack4477 (07-23-2013), NickFRS (07-23-2013), nix (07-22-2013), Sivtec (07-23-2013), Sportsguy83 (07-22-2013), swift996 (07-22-2013)
Old 07-22-2013, 11:40 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Dave / Sportsguy83
- AVO Stage 2+ Turbo Kit
- 93 Octane/SIR 500cc Port Injectors/DW 65c Fuel Pump
- 14 psi
- AVO 18/49 Oil/Water Cooled Turbo (TD05 18g) internally gated, AVO 50/50 BOV, Perrin Manual Boost Controller, Nameless 3" OP/DP, Midpipe and Axleback, Clutchmasters FX350 Clutch Kit, D3 Performance Engineering Catch Can
- 90F+ Temps and Rain, 4th Gear Pulls.
- Will be doing E85 Dyno tune soon, will update post with new numbers ASAP.
- Turbo Experience Thread
- Member Car Journal
The Following 8 Users Say Thank You to Sportsguy83 For This Useful Post:
akuhei (07-22-2013), cmss2000 (07-22-2013), DesertFrs (10-14-2013), lexusb3 (07-22-2013), mack4477 (07-23-2013), nix (07-22-2013), sw20kosh (07-22-2013), swift996 (07-22-2013)
Old 07-22-2013, 12:15 PM   #5
lexusb3
Drives: FRS
Brandon/lexusb3
Fa20club.com kit
e85
16psi
3inch exhaust custom, fuel pump, 550 injectors
90degrees 29 humidity -_-
Signature has my build ( just click it)
lexusb3 is offline   Reply With Quote
The Following 9 Users Say Thank You to lexusb3 For This Useful Post:
86_Insider (07-23-2013), akuhei (07-22-2013), cmss2000 (07-22-2013), Jtymay92 (07-22-2013), mack4477 (07-23-2013), NickFRS (07-23-2013), nix (07-22-2013), Sportsguy83 (07-22-2013), swift996 (07-22-2013)
Old 07-22-2013, 01:08 PM   #6
nix
nix's Avatar
Drives: AVO BRZ
- nix
- AVO turbo kit
- Flex fuel (98 RON to e85)
- 14.7 psi
- Stage 1: AVO air filter, AVO oil breather tank, Perrin 2.5" catted unresonated exhaust, Perrin crank pulley.
- Stage 2: + Omni map sensor, Spray it Racing 500cc port injectors, SPD290 Fuel pump, Zeitronix flex sensor.
- Driveline: ACS chromoly flywheel & 830kg DCB clutch kit, STI engine & trans mounts, whiteline diff & outrigger inserts.
- Journal thread
-Baseline of 108kw = 145 hp. Dyno reads ~15% lower than dynojet. Original & converted dynojet numbers below for comparison.
Stage 1 AVO base map (98 RON, 4.5 psi) vs stock baseline (98 RON). 140 rwkw / 188 whp / 215whp.
*This was from Ross Wilson @ AVO JDM.
Morpowa flex tune E78% - AVO stage 2 actuator - 8.5 psi. 217 rwkw / 291 whp / 335 whp.
Power starting to top out on e70 and 14.7 psi. 247 rwkw / 331 whp / 380 whp.
nix is offline   Reply With Quote
The Following 8 Users Say Thank You to nix For This Useful Post:
86_Insider (07-23-2013), akuhei (07-22-2013), cmss2000 (07-22-2013), dabocx (07-23-2013), DesertFrs (10-14-2013), lexusb3 (07-22-2013), Sportsguy83 (07-22-2013), swift996 (07-22-2013)
Old 07-22-2013, 01:14 PM   #7
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Michael/WRXgoose
Innovate SC
93 oct
7.5psi iirc
Borla UEL headers, Perrin 3" header back exhaust
note: this is not a finalized tune, I need to get back and have it fine tuned to where I want it.
wrxgoose is offline   Reply With Quote
The Following 8 Users Say Thank You to wrxgoose For This Useful Post:
86_Insider (07-23-2013), cmss2000 (07-22-2013), lexusb3 (07-22-2013), NickFRS (07-23-2013), Sportsguy83 (07-22-2013), sw20kosh (07-22-2013), swift996 (07-22-2013), WHITE (07-22-2013)
Old 07-22-2013, 07:36 PM   #8
AVOturboworld
- Paul Hansen/AVOturboworld
- AVO Turbocharger Kit Stage 1.8.2
- 92 octane (10% ethanol)
- 10.92
- AVO header-back exhaust, AVO high-flow Panel Filter
- http://www.ft86club.com/forums/showthread.php?t=13156
Note: This is an old chart, currently working on the bigger/better/faster version.
The Following 10 Users Say Thank You to AVOturboworld For This Useful Post:
cmss2000 (07-22-2013), dabocx (07-22-2013), DesertFrs (10-14-2013), mwjcyber (09-07-2014), NickFRS (07-23-2013), nix (07-22-2013), Pete156 (07-23-2013), SkAsphalt (09-03-2013), Sportsguy83 (07-23-2013), swift996 (07-22-2013)
Old 07-22-2013, 10:32 PM   #9
fenton
- fenton
- Phantom Electric supercharger
- 94oct(10% ethanol)
- 4psi - 1.6psi at peak power
- Otherwise stock
- First designed kit, new compressor in development. - Build thread - http://www.ft86club.com/forums/showthread.php?t=39719
fenton is offline   Reply With Quote
The Following 8 Users Say Thank You to fenton For This Useful Post:
86_Insider (07-23-2013), ATL BRZ (08-08-2013), cmss2000 (07-23-2013), DAEMANO (02-11-2014), nonicname (07-23-2013), SkAsphalt (09-03-2013), slaxx (10-24-2015), swift996 (07-22-2013)
Old 07-23-2013, 09:45 AM   #10
mack4477
Drives: 2013 Firestorm FR-S
-Chris/mack4477
-FBM Stage 1 Base Kit with GTX2867 upgrade
-E85 @ 16 psi
-93 pump @ 10 psi
-Dyno tuned by LJ @FullBlown
-FBM 3" exhaust, 1000cc injectors, upgraded fuel pump
mack4477 is offline   Reply With Quote
The Following 5 Users Say Thank You to mack4477 For This Useful Post:
86_Insider (07-23-2013), cmss2000 (08-04-2013), dabocx (07-23-2013), nix (08-03-2013), swift996 (07-25-2013)
Old 07-23-2013, 04:05 PM   #11
Ross
Drives: 85 corolla gts
Owners name: Fabron / Fabron757
Kit: Custom kit built by Trust Automotive using efr 7064
Fuel: e85
Other mods: fuel pump, injectors, catch can with drain back to oil pan, full 3" turbo back exhaust w/ no muffler only cat and resonator, all hot parts coated, Koyo Radiator, Spal fans, remote mount oil filter and large oil cooler, aem wideband fail safe, CLutch Masters FX400
Tuned by: Trust Automotive using EcuTek Race Rom, tuned on 16 psi
http://www.ft86club.com/forums/showthread.php?t=31807
Ross is offline   Reply With Quote
The Following 9 Users Say Thank You to Ross For This Useful Post:
86_Insider (07-23-2013), BRZPDX (07-25-2013), lexusb3 (07-23-2013), mack4477 (07-23-2013), nix (07-23-2013), pmccut (07-25-2013), Raven604 (07-23-2013), sw20kosh (07-23-2013), swift996 (07-23-2013)
Old 07-23-2013, 05:58 PM   #12
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Vortech supercharger, 8.5psi pully moto-east tuned
92 WAWA gas
Borla header, perrin cat back
Stock injectors/pump
Terminated dyno tuning early, upgrades were on the way, needed something that ran.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following 3 Users Say Thank You to Adeets For This Useful Post:
Brian@Vortech (07-25-2013), swift996 (07-23-2013), Tr1huynh (04-25-2015)
Old 07-25-2013, 01:29 PM   #13
Adeets
OEDC
Adeets's Avatar
No more?
My BRZ FI Build
Old 07-25-2013, 02:37 PM   #14
Pete
Pete's Avatar
Drives: 22 BRZ
- Pete
- Vortech Kit
- 93 octane
- 9 PSI
- Borla UEL headers, Perrin Headerback
- Perrin Tune
- Blue line is old 7 PSI blower, not sold anymore
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following 4 Users Say Thank You to Pete For This Useful Post:
Brian@Vortech (07-25-2013), SkAsphalt (09-03-2013), Sportsguy83 (07-25-2013), swift996 (07-25-2013)
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 11:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
