| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,101 | 85.22% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.78% |
| Voters: 3639. You may not vote on this poll | |||
#2339 |
Drives: 2014 GLI Autobahn/Nav
#2340 |
Drives: Skoda Yeti DSG diesel 4x4
Here's another convincing coincidence for the ethanol connection for those that need it.
The poll at the start of this thread has 83% with the chirps. The poll below, asking who uses which fuel, has 82% using E5, E10 or E85 http://www.ft86club.com/forums/showt...light=crickets |
| The Following User Says Thank You to sierra For This Useful Post: | DylanFRS (07-20-2013) |
#2341 | |
Drives: Argento FR-S
It doesn't work for some, but it does work for most you have tried it. I never said it was a "magic bullet" but clearly its more effective than having the pump changed or whining about it. |
| The Following 2 Users Say Thank You to Silver86 For This Useful Post: | Carwhisperer (07-20-2013), DylanFRS (07-20-2013) |
#2342 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
| The Following User Says Thank You to DylanFRS For This Useful Post: | Silver86 (07-20-2013) |
#2343 |
Drives: 2013 Scion FR-S in Ultramarine
I just wanted to report that after having my High Pressure Fuel Pump changed out (1-1/2 weeks ago) I have not had any chirping. However, as a just in case measure I have been adding "Lucas Oil" to my gas as a lubricating measure. I do not have "pure" gas in my area to test a gas only solution like some of you. If the chirping comes back regardless of the fact that I am using Lucas Oil I'll try adding 2 ounces of 2-cycle oil to my gas as reported in another thread to see if that will lubricate the washer that was reported to be the cause of our noisy problems.
Hopefully, Toyota/Scion/Subaru will pay attention to our reports and come up with a real "Mechanical" solution to our problems.
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
#2344 |
Drives: BRZ Limited WR Blue Pearl 6MT
I've had my BRZ for one full week now. Almost 500 highway miles later, and the chirp set in on the last 5 minutes of my drive. I was at a stop light and noticed a change in the sound of the car. I put my window down to get a better listen (96 degrees outside) and immediately recognized it as the famous chirp I had heard on a BRZ that had been on the lot of the dealer I test drove the car at. It's quite apparent at this point. I've filled up with 93 with less than 10% ethanol, but I don't know what was filled when I drove off the lot. Granted, the chirp started after I was 3/4 the way through my tank of 93 that I put in it.
#2345 |
Lost in Kansas
I would like to note that just because the gas station doesn't have the placard that says it contains ethanol doesn't mean it is actually ethanol-free. Gas stations in a handful of states (CA included) do not have to label that their gas contains ethanol. In most other states, gas stations only have to label ethanol content once there is a certain percentage.
In other words, some of the people that are having the crickets on "ethanol-free" gas could still be getting gas with ethanol in it, it just isn't labelled because they don't have to label it. If you aren't filling up at a station that says in huge print "100% ethanol free gas" or "No ethanol in our gas" or etc, then you are most likely getting some ethanol content in your gas. More info on the state laws here: http://www.fuel-testers.com/state_gu...anol_laws.html |
#2346 |
For the record the place where I get ethanol free gas has huge signs stating so and the pumps are labeled. Finally it's listed on the ethanol free gas website. So unless there is one hell of a rouse going on, it's ethanol free. Still have the cricket sound here.
#2347 |
Drives: 2013 Raven FR-S
I've dealt with this chirping noise for some time as well. I've done the proper thing though and have it addressed, and hopefully everyone on here will do the same thing. By Taking the car into toyota and have the part replaced(high fuel pressure pump #SU003-00328). This part wont fix the vehicle though, because all they do is put in a new pump, not changed in any way. As toyota has no actual fix for it yet.
Then after a few hundred miles of break in it then began to chirp once more(yes all the while i fill it with 93) Its often questioned if its the fuel doing this. The answer is no, its a mechanism in the part causing the chirp so says the master mechanic that replaced the part in the first place. If this is happening to you don't hesitate to take it in, it only prolongs the importance of toyota to fix the vehicle. |
#2348 |
#2349 |
Drives: 2013 FRS Whiteout
Have 4700k on it and chirp was getting really loud took it in and they are gonna replace the fuel pump
#2350 | |
Could you ask the master mechanic to get one of the HP pumps they supply to the countries where they don't get the chirp? The same countries where ethanol is almost unheard of but that must be a coincidence. |
#2351 |
Drives: 13 frs
I switched to shell 91 v no ethanol no chirping,i think ethanol is the problem
| The Following User Says Thank You to mafrs1 For This Useful Post: | Silver86 (07-21-2013) |
#2352 | |
That could be your issue. You might ask them if all grades are E0. You could be getting a bit of the E10 gas in with your E0 fill up if so. |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
