Old 01-02-2012, 05:52 PM   #169
catharsis
Drives: honda civic si 08
Originally Posted by arghx7 View Post
Somebody has to crack the ECU before any of that happens.
If the ecu is from subaru it should be cracked shortly by cobb. Scubbie ecu's in the past have been easy to unlock.
catharsis is offline   Reply With Quote
Old 01-02-2012, 06:06 PM   #170
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
CyberFormula is offline   Reply With Quote
Old 01-02-2012, 06:33 PM   #171
serialk11r
Drives: '06 AM V8V Coupe
So I noticed on some other forum arghx[7 here presumably?] wrote that simply increasing port fueling would overheat the direct injectors... Can anyone explain? At high load the direct injectors are the only ones turned on, so fueling would be direct injector limited in this case :O
Old 01-02-2012, 10:56 PM   #172
arghx7
Drives: car
Originally Posted by blur View Post
How do you crack an unlocked ECU...
allow me to clarify. What I meant was "disassemble and reverse engineer" the ECU. They have to figure out what all the tables do, even if it doesn't have some actual lock on it.
Let me preface this by saying that I don't have a crystal ball and I don't know what will happen in the real world when somebody actually tries to crank up the port injectors at full load and high rpm repeatedly. There might be increased wear of the direct injectors in a slow and noticeable fashion. There might be random and catastrophic failures. There may be some negative effect that is difficult to quantify and barely noticeable--negligible in essence.
With all that out of the way, allow me to post the material directly from the source paper on the IS350 2GR-FSE engine:
Old 01-03-2012, 04:51 AM   #173
serialk11r
Do you have any idea as to what causes that? I have heard of direct injectors being fired at intake stroke, beginning of compression, or later in compression. If it's later in the compression stroke then mixed fueling would mean less fuel for the direct injector, and that the injector would have less cool down time while the cylinder temperature is high. Injecting more fuel during the end of compression stroke would allow the injector to stay cooler when ignition happens and probably would keep temperature down. The dish guided spray thing seems to suggest injection happening at either beginning of intake stroke or end of compression stroke, the only 2 times you can put fuel in and have the piston near the top.
The problem is I seem to remember being confused about these D4-S articles because there was conflicting information on how the injectors actually operated... At any rate, I have trouble seeing why increased port fueling while keeping the direct injector running the same could cause overheating. More fuel, even through the port, would be expected to lower temperatures across the board I think that article is talking about why they necessarily HAD to run 100% direct injection at higher speed. I guess that brings a second issue though, forced induction would increase cylinder temperatures considerably and 150C sounds pretty easy to hit if they are relying on the fuel to cool it down during the very short time that injection happens in :O
Old 01-03-2012, 12:36 PM   #174
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Sounds similar to urea injection issues that were happening with diesels...deposits and temp regulating. As stated, higher fuel flow will help keep temp down. Then we also can keep in mind for FI that the peak temps are higher but not necessarily as hot as long.
For now it's all speculation to limits, etc. Seems Denso is running higher DI duty cycle because they can't make an injector to take the temps.
Homemade WRX is offline   Reply With Quote
Old 01-20-2012, 07:14 PM   #175
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
ECU Reflash
Be nice to see Cobb Accessport to come!!
I ran Cobb AP on last 3 STi's , great OT reflash and simple!
So will TRD Blower be available in US or GT 86 Japan only?
Exciting stuff!! Esp as this car is like 500lbs lighter than 370Z
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 01-24-2012, 07:18 PM   #176
groupb
Drives: sw20
the ECU is Toyota- it cannot be reflashed like other car manufacturers
groupb is offline   Reply With Quote
Old 01-24-2012, 08:19 PM   #177
MarkRacerX
MarkRacerX's Avatar
Toyota ECU
Well that's no FUN , But all will come with time. Just like Cobb figured out the BMW ecu to crack and run an Accessport. I was just hoping Subaru, since they have many yrs of Exp with those.
Thanks for info!
Old 01-24-2012, 08:44 PM   #178
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
They announced many months ago that the ECU would be unlocked and easy to modify...
- The Ancient BRZ Sacrament
by Zaku
Old 01-24-2012, 08:48 PM   #179
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i think we are starting to get band wagoners ... lol...
just wait ill people buy an 86 find this forum and try and act like they know everything about it just because they bought one... and ill 1 up them buy telling them ive bought two :P... maybe a second one down the road... im greedy
i wonder if i fly anywhere ill be able to get a 86 to rent while im on business???
but yes UNLOCKED ECU's EVERYONE!!!!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 01-24-2012, 08:56 PM   #180
Guff
Guff's Avatar
Drives: BRZ LZR
lol, we should make it our mission to have more than everyone else! Three or four perhaps!
and Thank You for the big sign haha. Hopefully nobody will think twice now...
by Zaku
Old 01-25-2012, 03:04 PM   #181
carbonBLUE
Reverse Burnouts
yeah i think everyone should know by now that it is, theres still a lot of people joining the forum recently as the release date closes in
the ECU is an open platform, many of us know how smart toyota ecus are and what a hassle they are, this is a enthusiast's car, everything about it was built around the average weekend warrior but was also built as a great starting platform for serious race teams
what most people dont know how to tune is BOTH direct and port injection working harmoniously
back on topic, as for a supercharger goes, i hope if there is a need for larger injectors for a TRD supercharger, the only thing we will be changing out would be the port injectors, that is the one advange of having both types of injection.... larger injectors can easily be added tot he ports vs trying to buy overpriced larger direct injectors...
i personally love this engine, i only plan on going maybe 100hp over stock that would put me in power to weight of a 5.0L mustang, which is more than enough for me
(wont forget you)
2011 Infiniti G37x
Old 01-25-2012, 03:30 PM   #182
Homemade WRX
I don't think it'll be that hard for people once they understand the purpose and strategy that the port injection is used for. I do however foresee some issues in people making large changes with DI...
scion fr-s supercharger, subaru brz supercharger, super brz supercharged, supercharged scion fr-s, supercharged subaru brz, supercharged toyota 86, toyota 86 supercharged, toyota 86 supercharger
Toyota FT-86 @ VLN : report / pictures Michel Scion FR-S / Toyota 86 GT86 General Forum 312 10-31-2011 01:31 PM
Report: Toyota FT-86 Sedan Version Coming Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 62 09-24-2010 09:45 PM
Report: Toyota FT-86 will move up in price and age demographic ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 201 06-02-2010 03:36 AM
Report: Baby Toyota FT-86 also in the works Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 60 05-17-2010 07:41 PM
Report: Toyota chooses alternative Toyota FT-86 design (by Calty studio)! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 128 02-19-2010 11:36 AM
