#2605 |
Drives: Honda Fit
^^In terms of idle and engine performance, is it truly fixed, or is it merely better than it was?
| The Following User Says Thank You to Marrk For This Useful Post: | eurospeed (08-17-2013) |
#2606 |
Drives: GT-86
Problem fixed with the ecu flash no problems
#2607 | |
Done
Drives: WRB BRZ
I found a great mechanic that is worth the drive and will no longer visit a dealer for anything. I had faith in them with my ecu issue but lost it with minor maintenance. |
| The Following User Says Thank You to ftc~brz For This Useful Post: | Marrk (07-10-2013) |
#2608 |
Drives: Honda Fit
^^I haven't seen your posts in a while, so I may have missed something. Did the dealer resolve your ecu/idle issue, or did your mechanic come up with the remedy?
Thanks. |
#2609 |
Done
Drives: WRB BRZ
yes it has been a long time!!! 2 sets of codes, new cams and valves, more codes then ecu flash. After the flash all was well so the dealer resolved that and subaru was very understanding. I have since done some things and had a tune and still no issue. Hit 13k last night on my way home from work!
| The Following User Says Thank You to ftc~brz For This Useful Post: | Marrk (07-11-2013) |
#2610 |
Drives: Moped
See if you can find out which ECU you have...the number ends in 10, 11, or 12 (being the newest)
#2611 |
Drives: Toyota GT86
Hey guys, I don't really know if this is a problem, but a lot of users are complaining about rear axels which are braking after some period.
I am doing some slalom and sporty driving, so mine broke up at 6,500km. |
#2612 | |
Drives: Honda Fit
Are you running a stock powertrain? Stock rear suspension? Stock rims, tires, spacers? Alignment? Just tryng to get the complete picture. Thanks. |
#2613 |
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Looks like I will have to put off my Innovate supercharger install. My CEL just came on with error codes of P0303 and P219A. I pulled them with the torque app on my phone so I am not sure how accurate they are. Will be going to the dealership tomorrow hopefully it wont take to long to fix. Engine also seems to be running really rough and making a lot of valve train chatter. Does not sound good..
| The Following User Says Thank You to MattF For This Useful Post: | eurospeed (08-17-2013) |
#2614 |
I got the check engine light and traction control light at about 3000m. I took it to the dealer and they said it was because my gas cap was lose. I know that makes sense for the check engine light, but the traction light in combination???
#2615 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
I usually check the gas cap first thing when the CEL comes on and when I take in to the dealer to look at it I tell them that I checked it. Keep an eye on it, if it doesn't come back on you are lucky, but if it does take right back to the dealer.
#2616 |
CEL
What I am curious about is would - COULD a loose gas cap make the traction light come on??? (in combination with the CEL)
#2617 | |
Drives: 82 MkII Supra
A loose/missing gas cap usually triggers a EVAP Large leak code. This is considered a severe fault as you have a leak severe enough to possibly allow raw fuel out. Ford years ago added a second EVAP test valve to the gas filler that triggered a gas cap light on the dash. When I was a mechanic I would get almost 1 case a month for engine code diag due to gas caps being left off or loose. It happens.. |
| NW Owner List & Event Archive | DarrenDriven | Northwest | 1643 | 08-05-2016 07:48 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 11:42 AM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 02:40 AM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| An unofficial message from TMCA | Courtz1074 | AUSTRALIA | 25 | 05-17-2012 11:00 AM |
