Old 07-10-2013, 02:47 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Aftermarket Front Pipe Restriction
Has anyone been measuring their front pipe diameters? The way they are designed to mate up to the midpipe, it looks like there is a restriction. I see it on every front pipe designed to hook up to the stock midpipe.
I was thinking of removing that small piece of pipe that is sticking out of the front pipe and using a gasket to mate up with the mid pipe. Has anyone found a solution like this?
Or am I tripin about this downsizing? I have FI and I would feel better about not having the pipe go from 2.5 ---> 2.2 just so it can interface with the stock midpipe (which is not even there on my car).
Old 07-10-2013, 03:03 PM   #2
qoncept
qoncept's Avatar
I don't know what gains you'd see but you don't ever want to decrease exhaust diameter after the collector (or turbo). Ideally the diameter gets bigger.
qoncept is offline   Reply With Quote
Old 07-10-2013, 04:52 PM   #3
mrk1
Drives: Sterling BRZ Ltd
thats really an extremely minimal reduction, its there to work with the factory donut gasket.
You could cut it off a use a normal 2 bolt gasket but the donuts allow for bit of misalignment and flex under impact. That is when they are installed correctly.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-10-2013, 05:13 PM   #4
qoncept
qoncept's Avatar
It's a 20% reduction in cross section and a source of turbulence. The real world gains may or may not be worthwhile but it's clearly not ideal.
Old 07-10-2013, 05:30 PM   #5
FAER
Drives: Silver BRZ
I would like to see Companys release full 3" systems with their kits. (well the kits that will make big power) no "this will bolt up to stock... blah blah.." crap
FAER is offline   Reply With Quote
Old 07-10-2013, 05:31 PM   #6
qoncept
qoncept's Avatar
Totally. Who is replacing their overpipe before anything else?
Old 07-10-2013, 05:58 PM   #7
coyote
coyote's Avatar
Drives: Slowly
We sent our first brand X front pipe back and replaced it with brand Y, which we modified to ensure smooth flow from the brand Y over pipe.
We then modified the centre section of the brand X cat back to taper the step down from the brand Y front pipe.
Brand X was advertised as 2.5", but it was 60mm and less at the join. We deemed 60mm as sufficient once the gas was half way down the car and a lot cooler, but those big step downs are undoubtedly costing people power.
Why bother paying for beautiful smooth welds when at the joins you're smashing gas into a smaller pipe?
coyote is offline   Reply With Quote
Old 07-10-2013, 06:38 PM   #8
sw20kosh
yeah and it is not a smooth step down from 2.5 to 2.2. It is literally a 2.2" pipe inserted into a 2.5" pipe. There is a lip created in there with an actual gap between the two pipes of 2-3 mm all the way around.
That can't be ideal for flow? Especially if you are nearing the limits of 2.5" piping with FI... Boggles my mind. I think I'll modify mine and take out that 2.2" pipe.
Old 07-10-2013, 06:57 PM   #9
coyote
coyote's Avatar
Drives: Slowly
Yep. It actually made me wonder, if they think that's okay ... what do the muffler internals look like?
The stuff is so much cheaper than what you could make it for yourself though.
Old 07-10-2013, 07:46 PM   #10
jamesm
I installed a j2 front pipe yesterday and it doesn't have the piece out past the flange like the one in that picture (and like the stock piece has). It just mates flat to the mid pipe and overpipe.
Old 07-11-2013, 06:36 PM   #11
sw20kosh
I am going to gut mine!!!!
Old 08-24-2013, 05:51 PM   #12
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Does anyone not mind all the vendors advertising a 2.5" frontpipe, yet they fail to mention the 2.2" bottleneck?
I was pretty disappointed when I got my over/frontpipe to see this horrible and abrupt step down to 2.2", not to mention the craptacular fitment.
Anyway, doesnt seem like any shop is making a proper full 2.5" system, they're just letting people assume thats what they're getting. All about the $$$ I guess.
RiskyTrousers is offline   Reply With Quote
Old 08-24-2013, 06:06 PM   #13
mad_sb
Drives: 2013 Asphalt FR-S
I've been thinking about this as well.. I know my nameless frontpipe uses the stock gasket.. I'll have to figure out what to do when i do my custom catback. I'll probably modify the nameless and the catback and leave the stock stuff alone.
Old 08-24-2013, 06:10 PM   #14
sw20kosh
I ended up grinding that restriction out and re-used the donut gadget. Works fine.
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
