#71 | |
.if you don't intend to have others contribute, i would use whatever your most comfortable with. |
#72 | |
Drives: Raven FRS
That why they use blow off valve in turbo application, the actuator can not react fast enougth+compressor wheel can not change speed to fast(due to is weight). |
#73 |
Drives: 2013 FR-S whiteout
Arduino clones could be had for <$10, even in small quantities. Just sayin'. The ability for and end-user to reflash easily would be a plus...Not saying that's not possible with other solutions.
#74 |
absolutely. i think both should be supported: arduino with a custom circuit, or an integrated board that runs the same atmega. this would allow people with an arduino to 'DIY' and others who want simplicity could buy an inexpensive integrated board. they're not mutually exclusive, it's more of a packaging concern than one of development.
#75 |
Drives: Raven FRS
An other thing you will have to design/buy is for the charging of the Capacitor, you will have regulate the charging current if you do not want to surcharge the alternator/electrical system of the car when they are empty/low voltage. The system you are designing is similar to what Im use to design, where you need a constant current input in the cap and a large discharge current in short burst at your load.
When you will designing your power stage(depending on what type of motor you choose), always think that wire in the motor are like long water pipe, you can stop feeding them abrutly, or you will endup with high voltage spike destroying the FET |
#76 | |
Drives: '13 GBS Subaru BRZ
Maps are great idea but right now I'm just looking at a prototype. It's hard to make a map when you don't even know things like what sort of max boost you can get. Also keep in mind that this system is limited, and you most likely will be maxing out the motor very quickly as you move up through gears/revs. At that point your boost pressure will just start to fall no matter what your map says
#77 | |
i'm led to believe this by knowing that if you cut the belt on a centrifugal supercharger and it's just sitting there dead in the intake tract, the car will run and drive like a stock, non-supercharged vehicle. it doesn't seem to create significant intake restriction. don't ask how i know
#78 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#79 | |
We are effectively building an EBC that changes motor rpm instead of the position of a bleed valve. |
#80 |
Toma pointed something out in the other thread that we need to keep in mind over here.
In the immortal words of Montgomery Scott: "The more they over think the plumbing, the easier it is to stop up the drain." I'm mostly concerned with adding bypasses and things like that.
#81 |
Exactly. No effectively about it. This is exactly what we are doing.
#82 |
Drives: Raven FRS
I am starting to be mixup on what you want to built, is it a short burst WOT system or to you want to emulate a belt driven supercharger that can constantly pressurized the intake?
#83 | |
I'd like to be in 6th on the interstate, give it some throttle and get *some* boost (1-2psi would be great) without having to go WOT and getting full boost, then level off to cruising speed and recharging. |
#84 | |
I think the mapping ideas are great but I think it's over engineering for what I want. From my prospective I only want this boost during hard acceleration, and I want as much as it will give me so what is the point of a map? The other side is when the system is in standby to keep it running at a minimum speed to prevent the compressor from causing restriction in intake. I think this is something that will require some testing to determine how best to go about this, and if it really is a benefit at all.
| Tags |
| hairdyerperformance, only pulls hard one gear |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 07:42 PM |
| DUP THREAD MODZ PLZ DELETE KTHX | SloS14 | Forced Induction | 0 | 07-09-2013 06:41 PM |
| Electric Turbocharger | Shankenstein | Forced Induction | 91 | 06-24-2013 03:47 PM |
| Electric 86 | frosty86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-10-2012 03:16 PM |
| WRX Electric turbo | Neilus | Engine, Exhaust, Transmission | 42 | 05-03-2012 10:20 PM |
