neutron256, Robftss
Old 07-10-2013, 10:53 AM   #57
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
So as I lay awake with a bout of insomnia last night I was working out the basic control concept I wanted for my prototype. Simple is the key at this point and should be easily done with a PICaxe microcontroller, and inputs from the Throttle Position Sensor, and a MAP sensor.
Fun with flow charts!
The Following User Says Thank You to neutron256 For This Useful Post:
No Limit Motorsport (07-11-2013)
Old 07-10-2013, 10:56 AM   #58
jamesm
Originally Posted by Toma View Post
Why not a Microsquirt. Literally 200 $ and you could output one of the ignition channels or whatever and have lots of additional output or inputs for other toys.
that's a great idea. my only argument would be that, being that megasquirt isn't very useful as an FI tuning tool on these cars (wish it was, but with a subaru the stock ecu can be reflashed, rendering it unnecessary), it doesn't really serve any purpose that couldn't be accomplished much simpler and cheaper with a bespoke atmega board and some code.
i would suggest that we prototype the whole thing on an arduino then move to having bespoke boards printed. that will result in the lowest possible cost, can be completely open source (megasquirt is not, very important detail), and it will allow people with an arduino at home to wire their own circuit and use it as is.
with an open source project it is extremely important that there are no proprietary dependencies. every link in the chain must be something like GPL or MIT licensed.
The Following User Says Thank You to jamesm For This Useful Post:
Frs300 (07-10-2013)
Old 07-10-2013, 11:08 AM   #59
mid_life_crisis
Drives: FR-S 10 #103 AT
The one part of this I would alter is the very last about setting the motor speed (pressure).
Cross reference throttle position and engine rpm to find boost target.
This way you have absolute control over what rpm and/or throttle position sets what boost level. The level of control is far greater.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 07-10-2013, 11:10 AM   #60
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
What would be wrong with having a tiny off-the-shelf arduino (or similar)?
Old 07-10-2013, 11:11 AM   #61
SloS14
SloS14's Avatar
With an SDCard reader, the user could load a .CSV with boost targets
Old 07-10-2013, 11:29 AM   #62
neutron256
neutron256's Avatar
I did consider using boost level and I think that may be a good option down the road, but for my prototype I need a more simplistic system. Since I don't even know what sort of boost it will actually produce I need something more straight forward and throttle position will give a nice liner response starting at zero, and ending at full RPM's at WOT.
Old 07-10-2013, 11:36 AM   #63
neutron256
neutron256's Avatar
I think arduino's are a good option and very capiable, but for my prototype it's really more then I need.
I favor the PICAxe for a few reasons:
1. I'm used to working with them
2. They use BASIC so they are stupid simple to program even for non-programmers like me.
3. They are dirt cheap. I mean like $3 cheap.
Old 07-10-2013, 11:42 AM   #64
ML
ML's Avatar
Drives: 13 White MT FR-S
What about power source? 24v like the Phantom, or more? I had some old industrial UPS wet cell batteries I was thinking would work, although they are heavy.
Old 07-10-2013, 11:53 AM   #65
neutron256
neutron256's Avatar
I'm sure most people will just go with SLA's. I'm going to try Ultracapacitors both because they are excelent for this sort of high drain setup, and because I've been wanting to play around with them. The down side is they aren't cheap.
Voltage really depends on what motor you decide to use. I'm looking at around 36V but I'm still researching that side of things.
Old 07-10-2013, 12:18 PM   #66
mid_life_crisis
I'm not sure I was clear. What I was trying to suggest is that you could monitor the engine rpm and the throttle position. Using those two values, you reference a table that provides the target boost pressure, or motor rpm if you prefer. The result is the same: you regulate your motor based off two input variables instead of one and have a far more powerful system with minimal extra effort.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
jamesm (07-10-2013)
Old 07-10-2013, 12:21 PM   #67
jamesm
mainly just that it costs more than it has to. you're paying for a uart-serial chip that you won't need, and a few other things. with an atmega on a bespoke board we could get the cost down below $10 probably.
Old 07-10-2013, 12:22 PM   #68
jamesm
i would argue against using a picaxe for the same reason you argue for it: BASIC lol.
Old 07-10-2013, 12:25 PM   #69
jamesm
i agree with most of that. my main point of contention would be throttling down when the system detects it has reached target. it would be best to just return early and let it loop over, no need for unnecessary motor control (one of the most computationally expensive operations in the system), and it will result in oscillation in all cases.
of course when the system is armed a simple scaling of throttle percentage to motor speed is less than ideal as well, as we're not concerned with motor speed, we're concerned with boost. it should read map, then compare to a boost target referenced from rpm and throttle position. this is a far more flexible design, imho.
mid_life_crisis (07-10-2013)
Old 07-10-2013, 12:30 PM   #70
solma
Drives: Raven FRS
Funny, would said thing for 2 option. A PIC uc program in Assembler, way more efficient and simple, but that because I am use to program in assembler, I think best is to go with what you know best.
solma is offline   Reply With Quote
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 06:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 03:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 03:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 10:20 PM
