neutron256, Robftss
Old 07-09-2013, 11:07 PM   #29
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by mid_life_crisis View Post
There was a good reason for wanting to know the motor speed but I can't remember it right now. Sucks getting old. It'll come back to me eventually though.
Motor overspeed maybe? Or perhaps compressor surge?
Old 07-09-2013, 11:21 PM   #30
jamesm
Originally Posted by Calum View Post
Tuning gain is great, but a system like this would require the ability to correct offset as well. Otherwise the system could settle out at the wrong boost pressure and as long as the error signal (feedback compared to setpoint) is steady then the system wouldn't correct for it.
I've calibrated and rebuilt more then my fair share of pneumatic controllers that can do this, but I have no idea how to do it in the digital world. Basically for this to work well a controller that can do both proportional and integral adjustment is what to look for. A full PID wouldn't be required though, I don't think.
Or am I an idiot and that's already in the code above?
Also, I really think we need to get past the idea of boosting to the back of a partially closed throttle. That's inefficient and with a setup like this shouldn't be required. If BRZ edit could be used to remap the throttle plate vs. pedal maps, then you could just set WOT to something lower in the pedals travel range then 100% and then use the rest of the pedal's travel to increase boost pressure to a max.
The code above, as over-simplified as it is, will not settle outside of the target unless the target is unreachable due to a hardware limitation. It's pretty simple, basically says "keep increasing motor speed by x until map == target boost, them quit, if map >= target boost, reduce motor speed by x". Rinse and repeat. Again very simplified and not representative of a full implementation, but that's the idea, and it works well enough to control head speed to within 1 or 2 rpm @ 3k rpm.
Certainly there are improvements to be made, just advocating the general idea of using a boost target and a feedback loop.
The Following User Says Thank You to jamesm For This Useful Post:
Calum (07-10-2013)
Old 07-09-2013, 11:32 PM   #31
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Ahhaha programming drives me nuts. I've never had a knack for it. I'll stick with the hardware/electronics side of things.
Old 07-09-2013, 11:38 PM   #32
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm still of the notion that I don't want to have to reprogram the car's ecu. With a 3-d table we can set the boost at low rpms and partial throttle positions to levels that won't trip a code.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 07-09-2013, 11:38 PM   #33
jamesm
Please do, we need that even more
Old 07-09-2013, 11:44 PM   #34
jamesm
Yep. You could have any boost at any combination of rpm and throttle position, within the limits of the system. You could set it up any way you like, and alter it as needed when you upgrade in the future. It's a pretty exciting idea really.
Old 07-09-2013, 11:48 PM   #35
DAEMANO
Time Traveller
Unichip?
Old 07-09-2013, 11:57 PM   #36
mid_life_crisis
Originally Posted by DAEMANO View Post
Unichip?
The idea here is to have a kit that requires no additional purchases that we can just hook up and have it work. You buy a list of parts and put it together. We would make available the code with instructions on how to load it. I bet there would be members who would build them for a small price for those who either can't or don't want to.
Old 07-10-2013, 12:00 AM   #37
DAEMANO
Time Traveller
Old 07-10-2013, 12:03 AM   #38
neutron256
neutron256's Avatar
That's easy. I expect I'll have the hardware prototype ready to test in a couple weeks depending on my free time and motivation.
Unichip?
I'm currently running Unichip and I think this is a great idea. It supports this type of mapping, it's already getting the most of the data needed, and could probably directly output a control signal to the motor controller.
If I recall correctly its $200 for the tunner software/hardware. Not bad if I knew for sure I could get it to work.
Old 07-10-2013, 12:11 AM   #39
mid_life_crisis
So now I have to look up Unichip and learn about those so I can participate in those discussions. sigh...
Old 07-10-2013, 12:41 AM   #40
jamesm
the problem is that it is proprietary. it would be great if it could be controlled by as many engine management systems as possible, but you wouldn't want to require it.
Old 07-10-2013, 03:02 AM   #41
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Why not a Microsquirt. Literally 200 $ and you could output one of the ignition channels or whatever and have lots of additional output or inputs for other toys.
Toma is offline   Reply With Quote
Old 07-10-2013, 03:45 AM   #42
ft_sjo
Drives: GT86
Is this more of a programming exercise than an automotive engineering one?
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 06:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 03:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 03:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 10:20 PM
