| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: Toyota
Ok. Thanks. I wish to know how much lighter the CF hood of the BRZ STI is, compared to the aluminuim hood of the BRZ.
PS: Isn't CF an abrev. for CFRP? |
#30 | |
Wiring Nerd
Drives: 1994 Supra
I'm sure we all want to know that, but at the end of the day, the aluminum hood will probably weigh 8 to 12 lbs, and the carbon hood maybe a few lbs lighter. Its just bragging rights, not really function IMO. The carbon roof has more merit, if the steel roof structure can be reduced from the use of carbon. It also has chassis rigidity merits, as carbon has very high compression strength. |
#31 | ||
Drives: 2009 BMW 335i
![]() AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma |
#32 |
Drives: 2003 BMW M3, 2006 Scion xB
Here is an example of weight savings through CFRP. The BMW M3 CRT used CFRP for it's hood and stated a 75% reduction in weight vs. steel. Aluminum is about 50% lighter than steel, so CFRP is a further 50% reduction from aluminum.
Rough Example: Steel Hood: 40lb Aluminum Hood: 20lb CFRP Hood: 10lb Here's a cross section of the CFRP hood
2003 BMW M3 | 2010 Audi A4 Avant | 2006 Scion xB | PAST - 1986 MB 190E 2.3-16, 2005 Volvo S60 2.5T
#33 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#34 | |
Here is an example of a cost analysis between steel and aluminum. They say there is about a 40% difference in weight(sorry I was off a little) after all the inner structure is trimmed away. The purpose of CFRP is that the structure is built-in. There is no externally added structure as many times happens with CF.
#35 |
Drives: 1984 Mustang SVO
it's a bit disingenuous to say that 'aluminum is 50% the weight of steel' or 'aluminum is 1/3 the weight of steel' when referring to car parts, since this does not imply that an aluminum hood will actually weigh half as much as a steel hood.
as an example of what i mean, look at a copper radiator vs. an aluminum radiator. copper is significantly heavier, and also more expensive than aluminum. but you can make an efficient copper radiator using less copper than you'd have to use of aluminum for similar heat dissipation results. copper is more than 3 times heavier than aluminum, and about that much more expensive too, yet an aluminum radiator doesn't really weigh 1/3 of what a copper radiator weighs. at best, it might weigh half, but typically closer to 60% |
#36 |
Drives: Toyota
Saying CF is heavier than ALU is like saying an 18" rim is lighter than a 17" rim.
It depends on construction not material, and when you make a part of CF instead of METAL, it is in the aim of being lighter, not to look good. If this thread is about CF look, then I am off-topic, and this is a ricers thread. |
#37 |
Rocket Surgeon
Drives: PSM GGA OMG
Exactly. What previous posters have been saying is that the vast majority of "carbon fiber" hoods/trunks etc. are made cheaply with a layer of carbon over fiberglass and are usually laid up wet (excessive resin = a heavy part). These parts are much heavier than they could be if done properly but are still lighter than their steel counterparts. It's this cut-price "carbon" that is heavier than an aluminum panel. Properly made cfrp parts are indeed lighter than the aluminum equivalents, but they come with such a high price tag that they are the exception rather than the rule.
#38 |
Kuruma Otaku
^ Fiberglass hoods with CF appearance layer...
Because titanium. |
#39 |
I'm a Carcissist
Drives: JERRV , 11 STI, 07 FJ
If you really want to save weight, do it the red neck way.... take the effing hood and decklid off!
#40 | |
Site Moderator
Drives: Stuff
I have yet to see any reasonable priced CF hood be 50% lighter than an OEM aluminum piece.
-Dave
#41 | |
Site Moderator
Drives: Stuff
-Dave
#42 | |
Wiring Nerd
Drives: 1994 Supra
Correct. Hypothetically the carbon fiber can never be more than 37% lighter than aluminum, let alone 50%. All construction methods aside, just looking at density. A 20 lb steel hood, if made entirely of aluminum, would weigh 6.8 lbs. The equivalent hood in CFRP would weigh 4.32 pounds. Which leads me back to my very first argument. Why spend $1000 + to save a couple pounds? |
| No Carbon Fiber Roof!? | Slide | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 07-15-2012 10:16 PM |
| What you want under the hood of a higher performance OEM variant of the AS1? | MrVito | BRZ First-Gen (2012+) — General Topics | 26 | 12-26-2011 11:07 PM |
| Trunk space? | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 04-13-2011 12:29 PM |
| Toyota, Subaru and... Carbon Fiber! | virobloc | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 10-16-2010 11:46 PM |
| Can someone do a chop with the hood 5cm higher as described in the Autocar interview? | devtec | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 37 | 06-08-2010 12:11 AM |
