Drives: slow
E-Brake clunk?
I've noticed that if I apply the e-brake while moving (slow or fast), the very first time there's quite a loud clunk in the rear of the car.
If I do it again, there's no noise. It only clunks if I've been driving for a while (presumable been using my brakes or reversing the load on the axle / hubs) Does this happen for anyone else? |
#2 |
Drives: '24 GR86
Totally normal
#3 |
Drives: slow
why? what is it?
#4 |
It's the drum brake engaging. It'll clunk every time you engage it.
Question is, why are you engaging it while you're moving?
#5 | |
Drives: slow
It's not something I do a lot, but the noise concerned me a bit. |
#6 |
DRIFT BUILD
Drives: 2013 FRS
Normal on most cars. Happens when i drift on the track when i start a drift with the e brake
2013 FRS Rocket bunny- PETE |
#7 |
Drives: Attitude
It's play in the assembly and totally normal.
#8 |
Drives: GBS BRZ Limited
This freaked me out so bad when I first got the car. Best to use it only as a parking brake or in real emergencies. (cop=emergency)
#9 |
Shorter of breath
Drives: a soft bargain
#10 |
Drives: Blue BRZ
Umm..probably better to just let off the gas.... and if you are really going that fast, maybe drop down a gear....
#11 |
Toyota Master Tech
Drives: Whiteout MT
Adjust your parking shoes (at the rear rotor). mine had the initial clunk as well until i adjusted them
| Coilover Clunk (Brand new) | white86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 59 | 02-10-2016 11:24 PM |
| rear suspension clunk | Gen | Issues | Warranty | Recalls / TSB | 67 | 04-03-2015 09:52 PM |
| Clunk when going into first gear? | huma | BRZ First-Gen (2012+) — General Topics | 22 | 07-24-2014 06:49 PM |
| Parking brake clunk | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-28-2012 01:10 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 12:43 PM |
