#15 |
Drives: 2015 STi and '93 Sentra Se-r
any updates? I started hearing this about two days ago and I was planning on going in for the new tsb on our fuel pump issue and have them check out this "tick/click" issue. any input is appreciated. thanks!
#16 |
Mine makes the tick after every shift. I had a similar noise back when I had my S2K and with that car it needed the axle nut to be retorqued
| The Following User Says Thank You to Hanakuso For This Useful Post: | Carwhisperer (06-17-2013) |
#17 |
Drives: A lot of supercars.
Mines does the exact same aswell. Hanakuso, but even just while accelerating.
#18 |
[ame="http://www.youtube.com/watch?v=OCyJ5-10QyE"]VID 20130616 175852 - YouTube[/ame] mines gotten much "worse" its starting to Tick' tink' a lot more than usual.
#19 |
Drives: 2018 BMW M2
I have the same exact problem. Noticed it today in traffic when i let off the throttle and decelerate to 5mph and you hear a click under the shifter. Mine's an AT btw.
| The Following User Says Thank You to sprintertrueno86 For This Useful Post: | whataboutbob (07-06-2013) |
#20 | |
Lowered Lifestyle
Drives: Scion Fr-S
Sent from my HTC One |
#21 |
Drives: FR-S and 240Z
This clunk has been bothering me since I bought the car last September. Two dealerships have looked at it and the best I get is "We don't have another one here to compare to", or "Just let the clutch out slower". Getting pretty sick of this. This video is where I suspect the problem is coming from. The parking brake set and transmission in neutral, and I am able to rotate the drive shaft a good 20-30 degrees. Can anyone else try this out and post a video to compare?
[ame="https://www.youtube.com/watch?v=1JmFtv5c82s"]FR-S differential backlash - YouTube[/ame] |
| The Following 3 Users Say Thank You to dschock For This Useful Post: |
#22 | |
AutoX-10/10ths every run
#23 |
Drives: Toyota GT86
any update please ?
i am having the same problem |
#24 |
Drives: 2013 FRS Asphalt
It's coming from the rear axles. Go to the dealer. Some had success in just torquing down the axle nut. Others have had the inner joint assembly's break in two. And they have been denied warranty. I had mine looked at today he re-torqued it. Helped for a few miles then it was back. Going back on Monday.
2013 Scion FR-S AT Picked up 5/30/2012
#25 | |
Drives: Toyota GT86
Also any picture of which part need to be retorq ? Thanks ! |
#26 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
Ticking common before this failure:
So many modders have more cents than sense!
#27 |
Red wine
Drives: Subaru BRZ(R.I.P)
I noticed the ticking on mines too when I set the gear to Neutral while pressing the clutch and releasing it. When I am parked in my garage I do a constant press/depress on the clutch and notice the ticking sound but immediately after I shut off the engine the tick goes away.
It's got something to do while the engine is still running.
#28 | |
My axle but was torqued down by the dealer today. Still doing it. The assembly is probably cracked right now. Going back Monday No tsb yet. Also they have been dyning warrantys both Subaru and Toyota
| lifter tick? | DarkCard | Issues | Warranty | Recalls / TSB | 11 | 02-07-2016 02:51 PM |
| Tick tick tick from the dash | FRiSson | Issues | Warranty | Recalls / TSB | 23 | 06-12-2013 06:11 PM |
| Tick Click Tick (injector orgy) | empower-auto | Issues | Warranty | Recalls / TSB | 4 | 08-27-2012 03:28 PM |
| Tick Tick | injuryexpert | Engine, Exhaust, Transmission | 3 | 08-21-2012 09:31 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 08:54 PM |
