#15 |
Drives: 2013 Scion FR-S (Hot Lava)
I just had this issue today. I think it happened because I kept trying to fill it after the pump automatically shut off. In order to resolve the issue I had to disconnect the negative terminal of the battery to reset the car. This did fix it, though it issue is quite concerning.
#16 |
Mechanical Guru
Drives: 2013 Scion FR-S (Argento) M/T
I had this issues as well... SkitterSkotter is right, if you pull the battery it is fixed. I believe I did the same thing he did by over filling. I was just in doubt because sometimes the gas pump stops for no darn reason when I know it is not full... Haha. Just try not to overfill... It can backup into the charcoal cannister in the Evap system and that won't be good. :P
| The Following User Says Thank You to Surakusa For This Useful Post: | SkitterSkotter (10-22-2012) |
#17 |
Drives: TR2,CooperS,BRZ
If you've had a Subaru you know never top up the gas tank after the auto shut off.
#18 | |
Thanks for the advice, I've never owned a Subaru before...noted! |
#19 |
Reap the BReeZe
Drives: 04 LandShark STi
#20 |
Aloha!
Drives: Whiteout
Yup it's you disconnect the negative and reattach. Fixed!
#21 |
Drives: 2020 GMC Canyon Denali Diesel
The reason the gauge does this is the tank is more like two separate tanks, one on either side of the driveshaft connected by a transfer tube, like a bloated n. Each side of the tank has it's own sending unit and fuel pump (primary & secondary). The ECU takes the resistance from each sending unit and uses a predetermined formula to calculate the actual fuel level. Since the filler only goes to one side of the tank, especially if the pump is a fast pump you can potentially have more gas in one side of the tank than the other, and then you'll get a funky reading. As the gas settles, from driving or over time it should correct itself. Filling with more gas just confuses it more.
Hope this helps.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | chanomatik (08-29-2014) |
#22 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Typical of most RWD cars (and most trucks) today. Tanks are mid-way under car (each side of driveshaft) to minimize the old 'Pinto' problem of the single rear-mounted tanks exploding when rear-ended.
My Mustang, MX-5 and now the FR-S often mis-read immediately after filling. After sitting a while, all is fine as everything comes back into equalibrium. Nothing to worry about unless it never corrects itself.
"You'll never know if you don't try" - Shinroko Momose |
#23 |
Drives: FR-S 6MT
I had this issue with my vette... Would get false reading or no reading on the gauge.. Was told to switch brands of gas.. Which I did... And the problem never reappeared.. Was told that some additives mess up the sensor reading.. Never had an issue after that even going back to the same brand..
| The Following User Says Thank You to Mikem53 For This Useful Post: | FR-S Hot Lava (05-23-2013) |
#24 |
Drives: BRZ DGM Limited
I just had this tonight...wanted to top off for trip..gauge was between full and 1/4 down. Added 2 gallons and gauge did not move.
#25 | |
Pharmasaurus Magnificus
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85 2015 Nissan GTR |
#26 |
Drives: FR-S Hot Lava (AT)
I have found that if I top off the car and the gauge is reading just above the 3/4 mark it will not move, but if the gauge is reading after the 3/4 mark then the gauge will move to full.
| The Following User Says Thank You to FR-S Hot Lava For This Useful Post: | chanomatik (08-29-2014) |
#27 |
Just returned from the trip and gauge came down normally and at the following fill ups from nearly empty went up to full as it should
#28 |
Drives: 13 BRZ WRB
Thanks for the help folks. My gauge maxed out at 3/4 full for the last two fills and so i reset the ECU and now it is reading spot on
| oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 06:46 PM |
| Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) — General Topics | 40 | 08-19-2012 05:29 PM |
| European fuel/coolant gauge face | arbnpx | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 05-31-2012 01:23 AM |
| How To Properly Carve a Canyon | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 64 | 05-21-2012 03:17 AM |
| ... reading the reviews? | Buggy51 | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 04-26-2012 10:08 AM |
