#85 |
Yea I wasn't too concerned about the filter, just curious what the startup cause could be. Like people have said, it could just be the switch to summer blend.. higher E85 content in the fuel plus all that stuff about fuel pressure/vapor/cranking enrichment, I'm sure that's a contributing factor.
The fuel filter degradation sounds like an isolated incident on a specific tracked car in very specific conditions. My car runs better than ever on E85 so no way I'm shying away from it now.
#86 | ||
Drives: N/A
I had my doubts that ethanol might be to blame but people running pure Gas have seen crickets come back. Crickets usually happen after the engine is warmed up and especially during idle, that marks ethanol off the list since it would chirp all the time if that were the cause. Quote:
#87 | |
#88 |
Drives: N/A
The increased risk of corrosion between E85 and E10 is minimal though. Modern RF Gasoline is already very corrosive due to aromatics. And new fuel systems are pretty durable in regards to Ethanol resistance. Because if something is not, it will fail, doesn't matter if it's E10 or E98.
#89 | |
#90 |
Filters
Since alcohol-based fuels tend to carry more water than gasoline, the filters can't be water-soluble. Paper is more sensitive to exposure to water than other materials, so they should be avoided unless the manufacturer states it is alcohol friendly. Most of the top-shelf filters use a metal or plastic screen to catch debris. Another issue with the filters can be the O-ring style fittings. Some O-rings not designed to work with alcohol will dry out. Read more: http://www.popularhotrodding.com/tec...#ixzz2YcIUgrDw Our cars have paper filters and the photos of the failed fuel filter in this thread are proof. People have been using ethanol way before these cars so no this is not a game of speculation, there are countless examples of this if you would just take the time to look. Yes we have paper filters and it would also be safe to assume that any o-rings in the fuel system are not designed to work with alcohol based fuels and will eventually dry out and leak. You may be fine for awhile but I know that I would love to run e85 in my FR-S but i would only do so if i made the proper modifications to avoid creating a big problem down the road leaving me with my nice brand new car out of commission. Last edited by DYOLF26; 07-10-2013 at 02:25 AM. Reason: . |
| The Following User Says Thank You to DYOLF26 For This Useful Post: | Fast_Freddy (07-10-2013) |
#91 |
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#92 | |
| The Following 3 Users Say Thank You to jamesm For This Useful Post: |
#93 | |
John |
#94 | ||
Drives: N/A
All it would take is some Toulene to eat through a paper filter. Quote:
| The Following User Says Thank You to Allch Chcar For This Useful Post: | texasbound972 (08-02-2014) |
#95 |
Drives: 14 BRZ, SC300
bumping this tread from the dead, is there anymore info from regarding the filter now?
| The Following User Says Thank You to BRZYOLO For This Useful Post: | Clipdat (07-28-2014) |
#96 | |
Proud of BOXER
Drives: Subaru Boxer
Yes please. Can anyone comment on the possible long term detriments of running E85? I'm about to order a OFT and would like to know.
#97 | ||
| The Following User Says Thank You to mkivsoopra For This Useful Post: | Clipdat (07-28-2014) |
| Tags |
| e85, filter degradation |
| AEM High Flow In-Tank Fuel Pump | JPxM0Dz | Engine, Exhaust, Transmission | 0 | 04-13-2013 01:15 PM |
| “saddle-shaped” fuel tank | ft86Fan | Engine, Exhaust, Transmission | 13 | 06-26-2012 05:22 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 03:40 PM |
