Old 06-30-2013, 03:14 AM   #15
Gen
Drives: Scion FR-S
Originally Posted by whitefrs View Post
Awesome
I had a bung welded on to the intake before the turbo. The kit really should have come this way. You don't want to plug it.
Gen is offline   Reply With Quote
Old 06-30-2013, 03:15 AM   #16
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Can u show me a pic?
Old 06-30-2013, 08:19 AM   #17
Frs300
Frs300's Avatar
Drives: Pile of junk
why not just vent it to atmosphere
Frs300 is offline   Reply With Quote
Old 06-30-2013, 12:16 PM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I did added a filter
Old 06-30-2013, 04:05 PM   #19
Gen
Drives: Scion FR-S
Car is being worked on at the moment, so I can't snap a pic until tomorrow, but in regard to venting to atmosphere, when I spoke to Crawford about this they indicated you'd lose power and it's generally not something desirable to do.
Old 06-30-2013, 04:52 PM   #20
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Yep they told me the same thing but i then why do D3 performance and many other has them to blow to the atmosphere
Old 06-30-2013, 05:14 PM   #21
Gen
Drives: Scion FR-S
Quite honestly I don't know enough about it to answer intelligibly and defer to others that have a better understanding. From what Crawford explained, you want the crankcase to be under vacuum and you don't want oil leaking onto the road. As far as D3 goes, no idea.
Old 07-01-2013, 08:20 AM   #22
mad_sb
Drives: 2013 Asphalt FR-S
They don't have any diagrams of the inside of the can so it's difficult to tell for sure how you need to connect it with a boosted application.. but i am guessing, since any oil caught is supposed to drain out the bottom port, the can has no internal separation and as a result it's not doing anything good in the current configuration.
Fairly sure the way that is plumbed right now you are sucking unmetered air into the intake manifold when off boost and blowing metered air our the when under boost. That may be part of the reason your fuel trims are all over the place.
For the time being, you should take the can out of the equation and put the system back like it was before you installed the can.
For that can to work properly it needs to be a closed system. You will need a bung pre turbo (as others have said) to connect to the port that is open. you also want a good check valve between the can and the intake manifold port so it will not pressurize the can under boost pressure. The stock pcv valve is on the block side so as soon as you go in boost the charge is filling the can and running out the open port and back into the block on the connected intake side port.
I honestly think you would be better off with 2 separate 2 port cans and a couple of crankvents (http://www.et-performance.com/automotive.html)... the idea draining the caught nasty back into the oil system is.. well... nasty.
The Following User Says Thank You to mad_sb For This Useful Post:
blackfireball5 (06-27-2014)
Old 07-01-2013, 08:38 AM   #23
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Will take it off tonight and will go with d3 performance one
Old 07-01-2013, 09:57 AM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
They have also blown motors and had their car performing poorly in two videos now, so I don't know that I would take my advice from them. Venting to atmosphere definitely won't hurt your car. If you plug that extra port then the vacuum from the back of the intake manifold should still pull on both the PCV and the front port.
Old 07-01-2013, 09:59 AM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Until someone shows me gains when pulling vacuum on the crankcase, then I will stick with vented. I don't want that oily air going through my engine.
IBill4You (07-21-2015)
Old 07-01-2013, 10:15 AM   #26
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
So having a filter is ok?
Old 07-01-2013, 10:29 AM   #27
Gen
Drives: Scion FR-S
Fair enough--last I heard, they were up to 4.
Old 07-01-2013, 10:56 AM   #28
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
4 engines??? Holy shit
Crawford Edition FRS??? CAMBAM_6 Scion FR-S / Toyota 86 GT86 General Forum 11 06-23-2013 07:36 PM
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 ngabdala Engine, Exhaust, Bolt-Ons 11 06-10-2013 09:22 PM
FS: Crawford AOS xwd Engine, Exhaust, Bolt-Ons 6 04-07-2013 07:44 PM
Need help Crawford AOS install ngabdala Engine, Exhaust, Transmission 19 11-21-2012 08:04 AM
