| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#99 | |
Good info, good info ! thanks a ton ! I want to run it square with 255/35-18's and -3.0 ! Aint gonna happen. (maybe a 10mm spacer)...but fuq that, not on a track car..for me. Hmnnn. Might have to do a 18x8 +35 on a 245/35-18 FRONT and 265/35-18 REAR. Mw |
#100 | |
#101 |
If you guys do miata.net and the tire tool here on the site, you'll find 245/35/18 to be the optimal tire for 18x9.5 for accurate speedometer readings. I went with that on these same wheels and absolutely love it. 245 is as big as you can go on stock suspension. 255's need coils for sure. I recommend coilovers with these wheels for safe clearance and the ability to do 245's with plenty of clearance for hard cornering.
| The Following User Says Thank You to FR-S Matt For This Useful Post: | akahenry (01-01-2014) |
#102 |
Tony Angelo Enkei RPF1 18x9.5 +38 - FT-86 SpeedFactory - PICS!!!!
We got the opportunity to get in 40 of the Tony Angelo Limited Edition Enkei RPF1's wheels and could not resist the opportunity to mount a set and show off how great they look.
These are a custom run for us in the FRS/BRZ community with a fitment that is PERFECT for our cars. Details: Enkei RPF1 Size: 18x9.5 Offset: +38mm Hub Bore: 73mm Bolt Pattern: 5x100 Weight: 17.6lbs <- SUPER LIGHT!!! Color: Black We mounted up 265/35/18 Hankook RS3 tires in the love of keeping grip on the road. More good news is we have verified it fits the AP Racing Sprint kit, which is one of the largest out there as far as caliper thickness goes. This means they will fit most other BBK's as well. ![]() Time to take a look at how SEXY this combo is! Off the Car: |
| The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post: |
#103 |
Drives: bucket
i freakin' love your car. saw it 86Expo and kept going back to look again. my gf said your 17s had "too much tire and not enough wheel." i guess i can show her these pics and tell her you must have heard her talkin mess.
#104 | |
| The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post: | humanshield (06-26-2013) |
#105 |
48 came into the USA and 40 are on those pallets in the photos.
#106 |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Wow those are freaking light for 18x9.5s... Price info?
EDIT: Found it on your website. Here's the link for anybody interested: http://ft86speedfactory.com/enkei-rp...-4pcs-929.html |
#107 |
Drives: 2013 Scion FRS
how much camber you guys running up front? car got to feel under powered with 265 rs3 on it!
Pew |
#108 |
Drives: 2013 Scion FR-S Whiteout White
Sunuvabitch....I waited for months and hunted down probably 15 vendors, could never get black rpf1's in 18x9.5. I buy wheels a week ago and this pops up...
#109 |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
speechless, simplicity and perfection. Looks way better then the regular black ones that you guys had at the 86 expo
| The Following User Says Thank You to R2RO For This Useful Post: | FT-86 SpeedFactory (06-27-2013) |
#110 |
#111 |
Drives: Scion Fr-s
#112 |
Drives: JRSC'd Asphalt FR-S
^^ I'm also curious, whats the Tony Angelo Limited Edition difference vs regular ones? I do love the black with the bright highlighter yellow stickers though.
| Tags |
| ft-86 speedfactory |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 11:34 AM |
| WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 | Touge Factory | Wheels and Tires | 2 | 02-05-2013 04:53 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
