#841 |
Drives: Toyota 86 GTS
Have u tried it on a computer? Could he the dongle is not compatible with the head unit
Sent from my HTC One using Tapatalk 2 |
#842 | |
Drives: Slowly
Did pop the SIM into the modem that came with unit. No joy there either. A word of warning about Kogan. I email support a week or two ago. Still waiting for more than the auto response. |
#843 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
I now have TomTom NZ working but can't find the maps. I copied both directories to a directory called TomTom on the internal SDcard but still no luck. What files do I have to copy and where to so that the maps I have work At the moment I have two subdirectories off the TomTom directory. Do I need to copy them out of the subdirectories?
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#844 |
When TomTom installed it should have made a folder called "files" in the TomTom folder. U replace that folder with the folder called "files" from the download
#845 | |
Hopefully it will work for you when you receive it. Merry early Christmas!
#846 |
Drives: Brz WRB - Europe LHD
SUPER OT ...more or less...
Anyone knows EVOSCAN? for Android? I read about their homesite is there, but is sold on bundle...(more than $200,00)......is there chance to find...free? and test
#847 | |
Drives: 98 Buick Century Custom
PS I have the exact same unit as in the first post |
#848 |
Drives: Grey GT
@AndroidHead
Try plugging bluetooth before you turn headunit on.. that worked for me. Is anyone using microSD card slot on the left side..? whats that for? can I just plug any microSD card in there? |
#849 | |
Do you have android super user icon when you go into apps? If you do then it is rooted. Have you plugged in a bluetooth dongle? Might seem a silly question but I thought bluetooth would be internal initially and didn't realise you needed one. Bluetooth dongle neds to be compatible. See my post here for some that are readily available http://www.ft86club.com/forums/showp...&postcount=828 Try an app like quick bluetooth or similar to check whether you can turn bluetooth on. Then, as mentioned earlier make sure the dongle is plugged in before turning the unit on. Also, try it directly plugged into the rear USB cable, not with a hub.
#850 | |
Beware the right micro SD slot - on my unit it is just a hole and the micro SD card will disappear into your unit. On mine the left micro USB is the only slot that actually is a micro SD slot. I have a 32GB one in there but actually use USB for music storage.
#851 |
[/QUOTE]No offence, but I'll go through the basics just in case you are missing something.
Do you have android super user icon when you go into apps? If you do then it is rooted. Have you plugged in a bluetooth dongle? Might seem a silly question but I thought bluetooth would be internal initially and didn't realise you needed one. Bluetooth dongle neds to be compatible. See my post here for some that are readily available http://www.ft86club.com/forums/showp...&postcount=828 Try an app like quick bluetooth or similar to check whether you can turn bluetooth on. Then, as mentioned earlier make sure the dongle is plugged in before turning the unit on. Also, try it directly plugged into the rear USB cable, not with a hub.[/QUOTE] I don't have any super user icon so I guess the root failed. I copied the file to a blank sd card, ran the update on startup, and it said success in like one second. then I ran MCU update, clicked ok. nothing happened that I could see. I installed a bluetooth widget that takes you right to the bt settings. I click "turn bluetooth on" and it just flashes once quick. Yes, the bluetooth dongle was in the rear cable at startup. I guess I'll just have to keep using torque on my Android smartphone for my trip to VA tomorrow |
#852 | |
#853 |
What head unit are you using TUN21A or T7019A?
#854 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
T7019A, my left side has the actual slot, right side is just an empty hole that leads into the head unit and bye bye forever.
Also I tested it and my rear USB does NOT work at all for data it seems. My phone will charge from it, but the USB wifi adapter will not work. It works fine on the front though. I've tried booting with it plugged in, plugging in after booted, reflashing the rom, etc. Going to try and download the rooted rom again from a different source and try one last attempt to get this thing working. |
| Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) | JPxM0Dz | Canada Classifieds | 2 | 01-19-2013 11:51 PM |
| chinese man sues wife for being ugly: wins | wrxgoose | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-07-2012 10:58 AM |
| Counterfeit Chinese Airbags | @Art_Mighty | Other Vehicles & General Automotive Discussions | 11 | 11-03-2012 03:20 AM |
| JDM Vs. KnockOff | SIRvive | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 03-05-2012 05:32 PM |
| Gang of Chinese kick, yell, and drag a little caucasian boy | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 01-20-2012 10:47 PM |
