Old 06-22-2013, 09:16 PM   #29
Tromatic
Intersting.
Old 06-22-2013, 09:43 PM   #30
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
Originally Posted by topazsparrow View Post
I don't get anything like that. When you say neutral do you mean in gear with the clutch depressed? Or do you mean the shifter is in neutral and your foot is off the clutch?
The diff is known to be a bit noisy but shouldn't be making any noises unless you're turning.
the shifter in neutral, and i get to a stop then it makes the noise before i hit 0 mph
ric342 is offline   Reply With Quote
Old 06-24-2013, 02:08 PM   #31
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Originally Posted by Cyau View Post
I was told from multiple people, first gear is only to get the car moving, once you start moving you should go second. Never drive in first, unless you're just in parking lot and needs to move 10feet to park
Nothing wrong with driving in first if your going extremely slow....its just 1st gear is usually very short so anything over 12mph is gonna be high rpm, i normally shift in between 3-4k during normal driving...if your in 2nd gear at under 2k then your potentially going to get some engine shaking/bogging like the engine is about to die so sometimes you need first gear (like california stop and go traffic)
CAMBAM_6 is offline   Reply With Quote
Old 06-25-2013, 02:26 AM   #32
SC David
Bloberator
Drives: 2013 Asphalt FR-S 6MT
Lots of weird speculation in this thread. It's a normal noise that the twins make, especially during deceleration when engine speed is under 2k RPM. The "jar of marbles" or whatever you want to call it. I hear that sound a million times a day, since I'm always in first or second gear engine braking down the countless steep hills here, and I keep the car in gear until engine speed drops below 1k RPM. Thumb tacks in a kettle drum all day long, son.
SC David is offline   Reply With Quote
Old 06-25-2013, 02:35 AM   #33
OrbitalEllipses
Drives: Attitude
I redline first gear multiple times per day; you're missing out.
Old 06-25-2013, 01:13 PM   #34
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
It hurts when I do this
Doctor: "Don't do that"
Old 06-25-2013, 09:55 PM   #35
Cyau
Cyau's Avatar
Drives: UltraMarine FRS MT
I red lined on second, not missing out on anything.
Cyau is offline   Reply With Quote
Old 04-20-2014, 02:45 AM   #36
mattbenich
mattbenich's Avatar
Drives: 2014 FRS Monogram
I am pretty sure that that noise you are talking about is the throw out bearing in the clutch assembly.
I do a lot of low speed driving and lug the engine a little bit and I have had other cars that have done the same thing...
Anybody else agree?
mattbenich is offline   Reply With Quote
Old 04-20-2014, 03:13 AM   #37
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Lightweight flywheel makes it worse.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following 2 Users Say Thank You to Reaper For This Useful Post:
blackfireball5 (04-21-2014), supramkivtt2jz (04-21-2014)
Old 04-20-2014, 09:30 AM   #38
Mikem53
Drives: FR-S 6MT
Anybody else agree?
Yes.. Had this with my vettes as well.. Same noise under the same circumstances.. It's either the springs found on the clutch disk.. Or part of the throw out bearing assembly.. Either way, it's quite normal. This car has minimal insulation and the clutch assembly is very close to the driver..
Mikem53 is offline   Reply With Quote
Old 04-20-2014, 11:19 AM   #39
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Seems to me there's a pretty simple solution to your problem, Topazsparrow...don't lug the engine! (lugging = very bad)
Here's a quote from a different thread that seems to apply very well here:
Yes, you're lugging the engine below it's RPM/torque capabilities. Yes, this will often cause knock in other cars, so I don't see a reason it wouldn't in this car. More gas, lower gear, problem solved. This car has no bottom end torque and isn't happy at low RPMs like a Mustang is. I rarely get below 2500 RPM and it's happier with me for not putting excess load/strain on the engine, as most cars are.
billwot is offline   Reply With Quote
Old 04-20-2014, 12:35 PM   #40
extrashaky
Drives: 2014 BRZ Limited
Anybody else agree?
I agree that this thread is 10 months old. By now I suspect the OP has grown comfortable with the sound or learned how to avoid it.
Old 04-20-2014, 01:37 PM   #41
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
For second gear idle cruising and you want to accelerate, than don't give it so much gas, ease into the throttle and let the engine kind of naturally rev up as you pick up speed....the sound should stop. What your doing when you mash the gas at 1000 rpms in a tall gear is asking for 100% FP and the engine simply can't deliver and your overloading the rings causing a bit of knocking from the piston slapping the cylinder wall.
Gords_zenith is offline   Reply With Quote
The Following User Says Thank You to Gords_zenith For This Useful Post:
mattbenich (04-21-2014)
Old 04-21-2014, 02:03 PM   #42
FRiSson
Drives: FR-S MT
There are two kinds of lugging.
One is when you get the engine under 1,600 RPM when you are in 2nd-6th gear. You can hear and feel it as harmful to the engine.
The second is when you put a significant load on the engine, either a hill or rapid acceleration when the rev's are between 1,600 and 2,000.
The first condition is bad all the time.
However, it does not harm the engine to operate in the 1,600-2,000 rev range as long as there is no significant load. At moderate highway speeds on level or declining terrain it only takes a few horsepower to keep the car moving so keeping the revs high is just a waste of gas under most conditions. That's why most modern automatics have an overdrive function that runs the car at low rpms when there is light load on the engine. With a manual, just be sure to downshift when approaching a hill or before you accelerate rapidly.
FRiSson is offline   Reply With Quote
The Following 2 Users Say Thank You to FRiSson For This Useful Post:
mattbenich (04-21-2014), re-animator (05-29-2018)
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
