Old 06-21-2013, 11:12 AM   #785
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Okay, I'm just going to summarize all my issues since I'm betting I'm not the only one...
1) Format a 32gb sd card as FAT32, put only the rom files from the original post on it, insert it, hold volume plus menu and it does do the update, over and over again, it just updates, reboots, updates, reboots, updates, etc. Is this normal? I have to pop the sd card out to get it to boot?
2) Can't calibrate touch screen, it goes to the black screen with the cross you're supposed to touch, no matter what I do it won't register that I'm touching it (touch screen works fine though)
3) MCU update goes fine but when it reboots it tries to reload the rom and I have to do it all over again. Have to pop the SD card out as soon as it shuts down.
4) Wifi works great on the front port (haven't tried the back yet)
5) Plugged bluetooth adapter in, load the quick bluetooth lite app, everytime i hit turn bluetooth on it flickers and unchecks the box. I'm assuming this means I have an unsupported device?
6) App store keeps giving Insufficient space error OR 942 error for ~50% of apps, though I can probably load the apk directly so this isn't a huge issue.
7) Trying to get my HSPA working, took the sim card out of my phone (Telus) and entered all the APN info, won't find the signal so still playing with that.
I love the unit so far, just need to work on figuring out some minor issues and tweaks to make it 100%
pheoxs is offline   Reply With Quote
Old 06-21-2013, 11:54 AM   #786
Tobz
Tobz's Avatar
Drives: Toyota 86 GTS
See responses below
Seems very very odd. Maybe try a smaller ad card? Also are the files directly on the sd card or in a folder? If in a folder remove the files from the folder.
See 1?
Make sure u use a good hub!
Has to be plugged in while the unit is off and then if the adaptor is compatible it will work here. If not it will flicker on and off.
The included modem is only for the 2100mhz spectrum, that could be your issue? (Looks like telus runs on 800 and 1900mhz)
Sent from my HTC One using Tapatalk 2
Tobz is offline   Reply With Quote
The Following User Says Thank You to Tobz For This Useful Post:
pheoxs (06-21-2013)
Old 06-21-2013, 11:58 AM   #787
Tobz
Tobz's Avatar
Originally Posted by krikke View Post
Fixed the issue of the dvd viewing protection by going into the bluetooth settings, change device name and going into a 'manufacturers setting page'. Just a OFF selection and now it plays dvd's always...
Inside the settings menu there were other interesting things that could be changed: illumination behaviour, fan control, radio sensitivity, dvd park brake protection, car logo, radio region, etc...
Can anyone confirm how to get to the manufacturers setting page? I totally can't find this section in my head unit!
Old 06-21-2013, 12:10 PM   #788
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
type in extra settings :123456 enter
you gain access to options
Sent by iPhone with Tapatalk
Trap63 is offline   Reply With Quote
The Following 2 Users Say Thank You to Trap63 For This Useful Post:
Ghostmerlott (06-22-2013), Tobz (06-21-2013)
Old 06-21-2013, 12:34 PM   #789
Tobz
Tobz's Avatar
Thanks heaps!!! Worked a treat!!!@
Old 06-21-2013, 03:01 PM   #790
pheoxs
See responses below
Much appreciated!!! Will try when I'm home
Old 06-21-2013, 07:35 PM   #791
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Here's another question for the Android gurus.
I've loaded google maps but every time i go in it says login failed. Can't actually see where I can login to my google account other than in the browser. I'm logged in there in google but still get the login failed in the google maps app.
I've looked at the menu options in there and no luck.
nzer is offline   Reply With Quote
Old 06-21-2013, 08:16 PM   #792
nzer
nzer's Avatar
Originally Posted by yhng View Post
I'm going with the Tun21A as well. The extra buttons and with a few others using the same unit made me more inclined to pick it. Ultimately it was the Toyota startup logo on a BRZ that decided it though lol
@Ghostmerlott, out of interest would you be able to take some photos of the bundle of the Tun21A? Just so that I know what I'm up for with the installation.
SELECTING A SUBARU STARTUP LOGO FOR THE BRZ ON T7019A
Just found on the T7019A you can change the startup logo to a variety of logos including SUBARU!
Settings, General Settings, Extra Settings, type in 123456.
Bottom option is logo. Select what logo you want and save it. Comes with many of the major manufacturers incl Subaru, Toyota, VW...
Startup logo is now what you want - eg: Subaru for you BRZ owners or Toyota for the 86 or FRS owners. Didn't look to see it there was a Scion logo.
The Following User Says Thank You to nzer For This Useful Post:
Old 06-21-2013, 08:19 PM   #793
nzer
nzer's Avatar
Originally Posted by Trap63 View Post
I got the same trouble, I download Tomtom.apk from web and later I installed from SD card.So I solved. after , tomtom downloads ITALY map (430 Mb).
If you see in HU memory (internal) you will find all Sygis contents over more than 1,5 Gb (all world). I free the Oceania, Usa and Latin America maps to gain space.
@Trap63 where did you find the Sygic maps you didn't need to delete. I've looked through file manager and can't find a Sygic directory. Can you point me in the right direction please?
Old 06-21-2013, 08:39 PM   #794
Tobz
Tobz's Avatar
They are in a folder called "Aura"
nzer (06-21-2013)
Old 06-22-2013, 12:21 PM   #795
Ghostmerlott
Drives: GT86
this is cool... how did you figured that out?! the 123456 part.. wonder if there are any other codes
Ghostmerlott is offline   Reply With Quote
Old 06-22-2013, 12:22 PM   #796
Ghostmerlott
Drives: GT86
ok, so I went and updated Youtube to 4.5.17.... nw it says video format not supported...for everything...... how can i turn back things? not rooted
Old 06-22-2013, 01:12 PM   #797
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I'm very interested in this but I suck at electronics. Is there a detailed DIY? Or is this plug and play?
YamahaR86 is offline   Reply With Quote
Old 06-22-2013, 02:37 PM   #798
nzer
nzer's Avatar
I found the menu but can't take credit for the 123456 bit.
Got that from post 788 above from @Trap63
http://www.ft86club.com/forums/showp...&postcount=788
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-20-2013 12:51 AM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 11:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 04:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 06:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 11:47 PM
