#1079 |
Drives: Very very slowly
I understand e85 helps, but this is waaaaay beyond the scope of published specs. 300hp at the engine at 1 bar is the published spec. So at less than half the boost pressure, you are making as much as the max at 1 bar? Does e85 compensate 100%? And all this is non intercooled! I'm sorry that I am skeptical, but the numbers do not add up in a major way. I would love to be proven wrong, and I will even put away my flame suit if it turns out I'm completely off-base. But so far, this is not passing the basic sniff test.
budi |
#1080 | |
Drives: 2013 Black FR-S
![]() I think you forget what E85 did on the vortech kit... 245 whp on pump -------> to 365 whp E85 no knock. |
#1081 | |
I Love custom Turbo kits
Drives: Limited BRZ
#1082 |
Drives: Limited BRZ
That's not completely true. It was done at a different PSI, so the difference was not ONLY E85 it was more variables.
#1083 | |
![]() I am surprised no one has produced an E85 dyno on the base vortech kit. With the timing advance you can run with E85 I'd speculate a bump up from 245 to 280-290 ish whp. |
#1084 |
Naw sw20kosh, I am an adult capable of taking criticisms. I would love a realistic discussion. And if I'm wrong, I will freely admit it. But your respond neither moves the discussion along, nor really refutes any of my assertions.
![]() budi |
#1085 |
Drives: Limited BRZ
Yes.... I believe a good amount of people know that here already. That does not change the fact Robi is at 7 psi, and there is a ceiling to how much timing you can run, its not endless.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | buditjoenawan (06-20-2013) |
#1086 | |
Add lightness!
Drives: 17' WRX
#1087 | |
Drives: Limited BRZ
Whenever the kit is released we will all see what the fuss is about
#1088 | |
Sorry you didn't find it comical... Anyways, as someone who saw the car in question get dyno'd, I am gently telling you that your "assertions" are incorrect. |
#1089 | |
budi |
#1090 | |
budi |
#1091 | |
budi |
#1092 | |
Add lightness!
Drives: 17' WRX
![]() Are you kidding me? |
| Bullet/Sprintex/Innovate on the bullet website | JoeBoxer | Forced Induction | 333 | 04-18-2013 10:07 AM |
| Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 10:32 AM |
| Bullet SC 86 | Loki556 | AUSTRALIA | 9 | 08-08-2012 01:39 AM |
| Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 04:40 PM |
