Old 06-19-2013, 10:54 AM   #239
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
So this issue can be a camshaft sensor?
Old 06-19-2013, 11:04 AM   #240
ft_sjo
Drives: GT86
I wonder what the previous TSB's were which this has replaced? Shimming out CPS is not a new activity to those running aftermarket management on some engines. Unusual to see it on a production engine though, but it is what it is (apparently!).
Old 06-19-2013, 11:05 AM   #241
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
@ xjohnx, Thanks man
I re-attached them as one file pdf and uploaded on my google.
11-130-13R
Old 06-19-2013, 11:17 AM   #242
zc06_kisstherain
Drives: SWP BRZ
I just read 11-130-13R TSB and VIN# starting @ D*607924.
so if VIN# is after 607924, vehicle doesn't need to perform this TSB? only applies to VIN# before 607924 ??
I am also wondering this TSB can be performed even though there is no problem on DI.
hope som people provide us update after TSB is serviced
Old 06-19-2013, 11:19 AM   #243
xjohnx
Grip>Slip
xjohnx's Avatar
Subaru window switch TSB is #07-73-13; I do not have the PDF.
PM'ing you.
OrbitalEllipses (06-19-2013)
Old 06-19-2013, 11:19 AM   #244
OrbitalEllipses
Drives: Attitude
This TSB doesn't really have to do with DI, from what I've seen about it. It's related to poor starting; the misfires MAY be related to our DI failure thread issues, but they may not be.
As far as VIN ranges go, cars outside of the VIN range have had the fix applied to production BUT numbers CLOSE to the production fix starting VIN range MAY not have had the fix due to changes on the line.
Old 06-19-2013, 02:07 PM   #245
Tirewarmer
For those of you having confirmed injector issues: Did you have a sound that resembled a ball hitting one of these beach boom racquets before the fireworks sounds started?
Two days ago, I heard a faint booming noise when lifting completely off of the throttle above 3000 rpm in 3rd through 6th gear. I can repeat the sound by lifting pretty much at will. Sometimes it was faint, sometimes slightly louder, but very repeatable.
Not suspension or other component related IMHO since I can't replicate it by shifting weight with the brakes, turning, or acceleration, only by lifting off the throttle at ~3000 rpm and up. The sound generator tube has been removed and capped on the intake side, but not the firewall side yet, so the sound could be easily heard through that hole while driving.
Replacing the noise tube setup and bringing the car into the dealer tomorrow.
I'm a very early BRZ, production number 1326 and I have 16XXX miles.
Tirewarmer is offline   Reply With Quote
Old 06-19-2013, 03:20 PM   #246
zc06_kisstherain
Drives: SWP BRZ
so only way to fix this DI issue is ECU reflash??
Old 06-19-2013, 05:22 PM   #247
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Depends on what you mean by "fix" if the seals are already damaged flashing the ECU will prolong the process but they will cause damage eventually.
ECU reflash could prevent the seals from being damaged in the first place making this issue go away.
ineedyourdiddly
Old 06-19-2013, 09:26 PM   #248
zc06_kisstherain
Drives: SWP BRZ
You are right. I never said damaged parts will fix it self.
Sent from my Galaxy Nexus using Tapatalk 2
Old 06-20-2013, 01:43 AM   #249
Dezoris
Dezoris's Avatar
All of this is an assumption from a TSB in Africa that a flash will fix it. Or does it just slow down the process? Are the seals incorrectly installed from the factory on some cars which make them more prone to failure? Poor installation? Defective injectors or stratified flow causing cylinders to overheat and melt down the seals?
Too many variables, and since we dont see anyone pulling their own injectors for inspection we have no data to really compare.
All we have is a hand full of people with actual information. 6 or 7 tops?
The Following User Says Thank You to Dezoris For This Useful Post:
strat61caster (06-20-2013)
Old 06-20-2013, 09:00 AM   #250
regal
Drives: Scion FR-S/Toyota Yaris
11-130-13R
This TSB is absolutely nuts. Its way over the head of an average Subaru dealer's capabilities and they only credit 0.6 hrs for the work that would take days to set up. Most dealer will punt, that means check the box and hope the customers engine doesn't blow up before 60k.
Seriously those of us with the affected VINs are better off running the piss out of this engine and blow it up before 60k than expect a yocal mechanic to decipher this mess of a TSB. For Scion dealerships who have little knowledge of an H-4 the situation is even more difficult. The dealers really got shafted here, hopefully Toyota/Scion will do the right thing and replace the cylinder head rather than jerry rigging a shim.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following 2 Users Say Thank You to regal For This Useful Post:
ill86 (06-20-2013), whtchocla7e (06-20-2013)
Old 06-20-2013, 09:15 AM   #251
ft_sjo
Drives: GT86
I'm not really sure why a VVT related TSB is being posted in a fuel injector thread.
The Following User Says Thank You to ft_sjo For This Useful Post:
ill86 (06-20-2013)
Old 06-20-2013, 09:19 AM   #252
mad_sb
Drives: 2013 Asphalt FR-S
Personally, i think the seals are fine right up until the boundary layer breaks down, as it does during detonation, at which point they over heat and melt. So, in my opinion there are two issues, seal material and detonation prevention, that need to be addressed. Detonation will happen from time to time on any engine. The mapping change from the TSB was intended to help prevent detonation during a specific set of circumstances and probably should have been included in all factory tunes to begin with. But I do not think it is THE solution. It will certainly cut down on the number of cars that have this issue, but it will not prevent seal failure for everyone.
The Following User Says Thank You to mad_sb For This Useful Post:
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
