View Poll Results: What F/E numbers are you seeing and why you think that it is what it is
Under 20mpg: I've yet to use a gear past 4th 3 1.96%
20~25: City driving / heavy foot 37 24.18%
25~30: I don't understand: I don't tach it out past 4k?! 66 43.14%
30~35: I enjoy the occasional fun, but usually I'm taking it easy 44 28.76%
35~40: Rule of 10's - 10 under the speed limit or 10' off the rear of a semi 3 1.96%
Voters: 153. You may not vote on this poll
Old 06-15-2013, 12:13 PM   #43
FRiSson
Drives: FR-S MT
Originally Posted by Mister View Post
I get about 32 averaged out in a tank. My commute to work is 0.8 miles so typically I do not drive and this keeps it higher, when I actually drive to work my average drops to 25-26.
MT
How does not driving keep your MPG high? I understand if it was "hours per gallon".
FRiSson is offline   Reply With Quote
Old 06-15-2013, 12:56 PM   #44
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
The average mpg readout is resetable with press and hold. So if you have never reset it, it will show lifetime average and as such be less sensitive to very good or very poor occurances of FE.
I reset every tank, so I can get a better idea of how driving circumstances for that tank impact the observation on the readout and the calculation results from the tank fill.
My lifetime is 7.6 l/100km(30.9mpusg) so far after 23 fills, worst tank was 9.33(25.3), best 5.0(47) based on tank fill calculations. Short trip city driving in winter produces the worst observations as would be expected. What I find questionable are the observation where folks consistently report 30-35mpusg MT with near 100% city driving, and foot to the floor! I suspect there may be very differing opinions on what folks consider to be city driving vs. highway driving. But I also believe MT has a little better city FE than the AT, while it is pretty much accepted that the AT is better on the hwy due to gearing.
smbrm is offline   Reply With Quote
Old 06-15-2013, 01:27 PM   #45
FRiSson
Drives: FR-S MT
Originally Posted by Kwaziekeller View Post
I calculate it out and use Fuelly. Most of my driving is rural (55mph) and small town stuff (35-45mph, very few stop lights etc). I've gotten 35mpg for a tank in the summer, with the AC on, on a very flat and boring section of I-40, drafting semi's here and there. I learned a long time ago that factory mpg estimates/readouts/displays were usually a bit off. Did enjoy that in diagnostic mode with the EVIC trip computer in my Charger it would have a display for how much fuel is in the tank in pints... yes pints... ran it down to 6 pints once, and it was quite accurate lol.
It doesn't really matter. The trip computer is usually optimistic, but by a consistent amount. In my car it is off about 4-5%, or about 1 mile per gallon under average conditions.
I think there is something about the on-off nature of the dual fueling system that reduces mpg under the kind of rural/small town conditions you described. The system seems calibrated to flatten the torque curve, not to maximize mpg under conditions where you are changing gears and revolutions - even gradually.
Old 06-15-2013, 01:52 PM   #46
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Yeah, from my experience the car MPG calculator has always been on the optimistic side, at least on Toyotas. In my 2005 4Runner, it told me I was getting on average 18-19mpg when in fact I got closer to 16-17mpg. I was hoping this technology would have gotten a little more accurate over 8 years, but not so much so. However, I do think the instantaneous MPG reading from the twins give a relatively accurate reading.
mit_peid is offline   Reply With Quote
Old 06-15-2013, 02:30 PM   #47
TM
TM's Avatar
Drives: DGM BRZ 6MT
I think he meant that usually he does not drive to work, since the short driving commute would bring down his mpg, but drives other times
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
Mister (06-16-2013)
Old 06-15-2013, 02:51 PM   #48
cfusionpm
Drives: Firestorm 6MT Scion FR-S
I'm pretty pleased with this, considering 80-90% city driving.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 06-16-2013, 01:25 PM   #49
kbi
kbi's Avatar
Drives: 2013 FRS
30.5 to about 33.0 mpg's ( taking I66 and I495 ) and the occsional back street's (hilly) on the way home at night.
Ive also use luca's #10576 Ethynol treatment and have been using it on all my vehicle's for the past 3 yr's and when I dont use it Ive seen my mileage drop.
kbi is offline   Reply With Quote
Old 06-16-2013, 04:17 PM   #50
FRiSson
Drives: FR-S MT
How much is the Ethynol treatment? How much do you use per fill-up? How much better is your MPG after you use it?
Old 06-16-2013, 05:12 PM   #51
kbi
kbi's Avatar
Drives: 2013 FRS
$10.00 a 16 ounce bottle
If I forget to pour it in Im under 29 mpg's
1 ounce per 5 gallons ( usually 10.5-11 gallons per fill up )
Looking at my reciepht's from when I 1st got the car last june to now
Im seeing 28.59-29.75 back last june-sept when I 1st got it and was breaking it in ( 1st manual ) and leaving rockville md during rush hour traffic at night .
And from oct/november 2012 when my hours got changed to earlier in earlier out Im seeing 30.3 , 30.46 , 30.99 , 30.94 , 31.2 and a few 32.26 and way better when I go in at like 5am and and on 495 at about 2pm .
Id say 31.0 to 31.5 is a baseline and I always have a pen and bottle of luca's stabilzer in the door pocket for water bottle's.
Average tank range has been 355 , 363 , 359
Ive tried to get family to run the Luca's stuff but they seem to be lazy and when I ask them about the mileage there like duh!
Old 06-16-2013, 06:54 PM   #52
Mister
Mister's Avatar
Drives: Firestorm FRS
It keeps it down because I avoid such short drive. If I drive to work every day at 0.8 miles in each direction, my gas mileage is horrible per tank. By biking/walking I save the car from such short drives and my MPG for a tank is considerably higher.
Mister is offline   Reply With Quote
Old 01-05-2014, 04:55 PM   #53
dssence
Drives: Toyota FT/MT 86
Hi I'm really worried about fuel consumption on my new FT 86 , I'm in argentina. So this version it's the same as SCION FRS. I'm getting around 25 litres every 100km where it should be around 7.8 for every 100km .
I've got the manual version , am I driving badly. I enabled the G on feature which tells you the proper timing to shift the gears. I pressume I might have a bad batch. Can you guys help me out. I've already used a 1/4 of the fuel tank and I've done 30km max.
What should I do?
dssence is offline   Reply With Quote
Why isn't the fuel economy better? White Shadow Scion FR-S / Toyota 86 GT86 General Forum 495 10-28-2019 09:21 AM
First Hwy Run... Fuel Economy Report PNW FRS Scion FR-S / Toyota 86 GT86 General Forum 18 06-10-2013 11:04 PM
Fuel economy ozne99 BRZ First-Gen (2012+) — General Topics 48 12-11-2012 01:55 PM
Optimistic fuel economy? nubbster927 BRZ First-Gen (2012+) — General Topics 15 07-05-2012 09:50 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 04:50 PM
