Old 06-12-2013, 10:20 AM   #57
TOZER
Drives: 2013 Whiteout FR-S
TOZER is offline   Reply With Quote
Old 06-15-2013, 09:26 PM   #58
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
People do motor swaps because they don't know how to make power with the stock motor, or they just bought the wrong car.... just sayn.
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
The Following User Says Thank You to usptwins For This Useful Post:
Shit Luck (06-16-2013)
Old 06-15-2013, 09:37 PM   #59
wrxgoose
WUB WUB
Drives: 2013 Firestorm
my friend and I were talking, we wanted to do an EJ25t swap into the back of a mini cooper. AWD, mid-engine. would be beastly
wrxgoose is offline   Reply With Quote
Old 06-15-2013, 10:30 PM   #60
wparsons
wparsons's Avatar
How in the world would you make it AWD if you put the engine in the back?
If you want something good to put an EJ25T into, look at this:
http://www.factoryfive.com/kits/proj...what-you-need/
flickr
Old 06-15-2013, 10:50 PM   #61
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
X51 3.8l (from a 997) in a 987 Cayman. Then a turbo.
jack43 is offline   Reply With Quote
Old 06-15-2013, 11:02 PM   #62
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I want to put an LS2JZ into EVERYTHING!!! *yawn*
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following User Says Thank You to fuddbutter For This Useful Post:
LSxJunkie (06-21-2013)
Old 06-16-2013, 03:27 AM   #63
OrbitalEllipses
Drives: Attitude
I dream of this swap, but I think I'd rather have the NA GT3/RS engine.
Old 06-16-2013, 03:36 AM   #64
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
http://www.hotrod.com/featuredvehicl...r/viewall.html
1929 Ford Model A with Group 4 Ford Escort Motor.
ZC6BRZ is offline   Reply With Quote
Old 06-16-2013, 04:47 PM   #65
wrxgoose
WUB WUB
never underestimate the power of people with tools and crazy ideas
Old 06-16-2013, 05:22 PM   #66
Luis_GT
I've seen plenty of LS1 swapped E39's
May do that to mine if I get a nice paying job... or just rebuild the stock engine and boost it...
Old 06-16-2013, 08:04 PM   #67
wparsons
wparsons's Avatar
If you put the EJ25 with AWD drivetrain into it with the motor in the back you would have to mount it backwards compared to normal, which would give you 1 forward gear and 5 or 6 reverse gears.
No amount of ingenuity will make an engine spin backwards.
It would spin the right way if you also installed it upside down but that would be a disaster having the oil pan on the top of the engine constantly draining into the crankcase.
flickr
Old 06-16-2013, 08:25 PM   #68
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Pretty sure you can just 'flip' the differentials. I know it's more involved than that makes it sound, but that will reverse the direction of the wheels vs the driveshaft.
-Justin
Justin.b is offline   Reply With Quote
Old 06-16-2013, 08:29 PM   #69
wparsons
wparsons's Avatar
-Justin
You can flip the rear end, but you can't just flip the transmission (which houses the front diff) since it'll only bolt to the engine in one orientation. The only way to get the wheels spinning in the right direction would be to build a custom bell housing so the engine sits right way up with the transmission upside down, but then the shifter will be on the bottom too.
flickr
Old 06-18-2013, 04:21 PM   #70
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Only engine swap i can see being justified, is a newer motor in an older car that it came with. Or, at least stick with the same manufacturer. In extreme cases, if you have to do a motor swap with a diff brand, then you bought the wrong car/truck.
Engine Swaps Available 88blacktop Scion FR-S / Toyota 86 GT86 General Forum 2 05-04-2012 07:45 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 03:18 PM
Engine Swaps and Kit Cars! merlin2111 Other Vehicles & General Automotive Discussions 27 01-27-2012 06:18 PM
The AS1 and engine swaps Syldrin Engine, Exhaust, Transmission 36 01-25-2012 11:45 AM
engine swap thread aspera Engine Swaps 231 03-15-2011 06:10 PM
