| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2013 SCION FR-S
+1 tried my stock lugs before getting aftermarkets and confirmed they fit perfectly fine, I eventually went with some aftermarket lugs because I didn't like the color of the stock lugs on my RPF1s LOL
#16 |
Registered you sir
Drives: 99 impreza coupe
+1 wouldnt waste mounting those tires back onto ANY rims. Rubber is one of the best bang for your buck and noticeable upgrades you can get for your car.
#17 |
Drives: 2013 Raven Fr-s
Finally got everything mounted, looks so much better than stock
Went with Hankook V12's 225/45/17, for some reason I could break these loose a hell of a lot quicker than the stock Bridgestones. Hopefully that wears off after breaking them in. |
| The Following User Says Thank You to Faceless For This Useful Post: | normancw (06-15-2013) |
#18 |
Drives: WR Blue BRZ, 240Z
Well Faceless, I think your photos just sealed the deal for me. That combo looks great. Was the ride compromised in any way? Does the +35 offset affect handling?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#19 |
The only thing I feel that is different is that with the slightly taller tires I feel as though I'm sitting a little higher. The extra 3-4 lbs off each corner is definitely noticeable, and with the extra rubber I feel a little bit more weight in the steering which I love. I would recommend this set-up to anyone.
#20 |
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
I can't really see it well, but are the spokes sticking out?
I.G. @mytoy86
#22 |
Tuloy po kayo!
I see' as long as they're flushed with the bead, I'm fine with it.
I.G. @mytoy86
| The Following User Says Thank You to pinoy_dorifto For This Useful Post: | karma003 (07-18-2013) |
#23 |
Drives: FR-S Argento and 2006 Scion tC RS2
#24 |
Tuloy po kayo!
Very nice. On the +35 with your drop, do the wheels stick out of either on the front or rear?
I.G. @mytoy86
#25 | |
Drives: 128i
#26 |
NW Region Moderator
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
#27 |
Drives: S2000
do the 17x8 rpf1's fit our car better as +35 offset or +45 offset?
obviously +35 fits the rear better, but what about the fronts? will it poke in the front? or better to play it safe and go with +45. |
#28 |
On an 8" wheel without measuring, I would guess that at stock height and stock camber a +40 would be about dead flush up front. +35 will poke a bit and +45 isn't quite flush. +35 with ~2* of camber will probably look perfect though.
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 07:31 AM |
| Wheel Directory: Enkei RPF1 17x8.0 +45 | track_warrior | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 163 | 03-17-2022 03:00 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Wheel Directory: Enkei RSM9 17x8.0 +48 | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 02-17-2014 07:50 AM |
| Wheel Directory: Enkei RS+M 17x8.0 +35 | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 02-12-2014 05:26 PM |
