Old 09-10-2012, 05:16 PM   #57
UM FRS
Drives: UltraMarine Scion FR-S
no rubbing on the front
haven't done an alignment yet
there is no camber adjustment on the KW's in the rear.
UM FRS is offline   Reply With Quote
Old 09-10-2012, 05:22 PM   #58
xAgentzero13
Drives: genesis coupe
like the color combo
xAgentzero13 is offline   Reply With Quote
Old 09-10-2012, 05:53 PM   #59
UM FRS
thanks
Old 09-10-2012, 06:38 PM   #60
Billman
Billman's Avatar
Drives: 00 Honda S2000
Originally Posted by ebphoto View Post
what are your alignment specs?... fenders rolled anymore than they come stock?
looks like very little camber.
I can't wait for the first moron who tries to roll the fenders more. Works look good in black.
Billman is offline   Reply With Quote
Old 09-10-2012, 06:47 PM   #61
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
You'll need some adjustable lower control arms to correct your camber. If you drop it too much, you'll be running around -3º which will kill your tires and make your handling sub-optimal. You might find though that after you fix your camber in the rear to where it should be, the 245 wide tires might also rub.
Mark Slide Squad is offline   Reply With Quote
Old 09-11-2012, 12:07 AM   #62
RavSpec
Drives: Rx7
With -2.5 camber , 245/35 tires will work.
RavSpec is offline   Reply With Quote
Old 09-12-2012, 01:03 PM   #63
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged another thread with the same staggered fitment of this wheel owned by @UM FRS.
Old 01-27-2013, 11:41 PM   #64
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
Originally Posted by FML View Post
18x8.5 +47 225/40/18 Toyo T1R
18x9.5 +38 245/35/18 Toyo T1R
1 Inch drop
Back poking out about 1/2 - 1 inch didnt really measure it
+47 in the front is pretty flush. I think +38 will poke out like the rear
Riding on 18s I notice the car seems a bit more sluggish during take off. I was worried about understeer with the staggered fitment but the handling does not seem to have been affected much other than having way more grip. I dont notice any understeer but this is just my daily driver and I'm not a track nut/expert
Hope this helps anyone trying to decide on offsets.
Hello, question, do you need to modificate something in the rear o front if i eant to fit 18' x 9.5 +38 ?
Toyota GT 86 is offline   Reply With Quote
Old 01-27-2013, 11:44 PM   #65
Toyota GT 86
My KW V3's and Work Wheels on Michelin Super Sports finally came in. Installed everything over the weekend. Unfortunately, we went a little too aggressive with the tire fitment(225's in front and 255's in the rear) and they rubbed a bit with the drop. So, we have a set of 245's coming, should help fix that prob.
As she sits.....until the tires come
Do you needed to modificate something or use coilover with your rear wheels ? 18x9.5 ? It looks freeking awesome.... What offset are them?
Old 02-21-2013, 06:21 PM   #66
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
What rubbed exactly? Ive seen people fit wider wheels on this setup without any problems.
Tansey86 is offline   Reply With Quote
Old 03-21-2013, 02:54 PM   #67
Skurj
Drives: SOLD...
WORK Kiwami GTS 18x8.5 18x9.5 +38 - WRB BRZ
225/40/18 and 255/35/18 Hankook evo v12
Wheels in GTS finish. Oops also dropped on Eibach Pro-kit
I'll have some pokey pics up shortly..
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 03-21-2013, 03:46 PM   #68
GregV
Drives: Kia Stinger GT2
Looks nice! Needs some clear side markers
GregV is offline   Reply With Quote
Old 03-21-2013, 03:51 PM   #69
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Looks great!
MVJ1975 is offline   Reply With Quote
Old 03-23-2013, 11:01 PM   #70
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Moooaarr Please. Photos of the sides! Looks good
Scaldy is offline   Reply With Quote
Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 03-21-2018 05:18 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 04:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
