Old 07-09-2013, 10:22 AM   #29
cb7tuner
Drives: 2013 whiteout FR-S
Originally Posted by cb7tuner View Post
It may work but I'm unsure. Im hesitant on it without the ridges/lips though, I figure they are there for a reason. I also think the kit needs a slightly smaller belt to. After the upgraded compressors were released with the 9psi pulleys the belts were still never changed. So with a slightly smaller pulley I figure the tensioner isn't as tight. I think the gates belt is 98.110" long , maybe a 97.5" or 98" would be better
I truly don't think this is a rubbing issue, at least in my case I know it wasn't. Just a random bad idler pulley is the culprit. May just be a bad batch
cb7tuner is offline   Reply With Quote
Old 07-09-2013, 10:23 AM   #30
nelsmar
Originally Posted by skatery1989 View Post
I checked mine this morning. There's a little wear spot on the pipe but I notices if you make sure to push it in till it hits the throttle biddy it self there's alot more room. I do have to say I am disappointed in Vortech service latley I have been trying to contact the guy that sold me my kit for about two months now.
who sold you the kit?
And i had my few bits and issues i still need to talk to Brian again i just havent gotten an organized list. I as well had pushed my pipe as close to the throttle as i could if i remember correctly. I was just trying to make sure i had enough "slip room" in my coupler.
My flickr - Canibeat
Local magazine scout
Old 07-09-2013, 10:27 AM   #31
cb7tuner
Hell I still don't even have the revised alternator bracket. I had to grind a good but out of my alternator casting to get it to fit properly
Old 07-09-2013, 10:36 AM   #32
charged86
charged86's Avatar
My pulley has not touched anything, i don't even think the pipe could touch the idler pulley if I wanted it to. It's ground down because the belt has jumped from the idler wiggling (because bearings failed) and caused the belt to ride on the lip of the idler. Then causing the idler to act like a saw hacking up the belt and taking chunks of the lip with it. My pulley hasn't touched anything. Oh and mine was in perfect shape a few days ago as well.....then it happened. No way it could be installation error. The pulley is pre installed on the blower assembly (but every bolt was checked to be tight before installation like the instructions say to do so) and nothing was loose when I removed the bad parts. I'm an A&P licensed aircraft mechanic. I'm very methodical in my installations. Like I've already stated, its really not that big a deal to me because it was a cheap easy fix. I just don't like how the situation was treated in my personal case by vortech and I would like to warn others of potential future problems and where to get replacement parts with part #s
Ok well that's good for you. What I meant was for the people who have rubbing pulleys in pipes that's instalation error. Just because you are an aircraft mechanic dose not make you immune to "mistakes". Apparently you got a bad pulley. Also the installation error would be installing the pipe too close to the pulley
Also if people start putting in metal pulleys and that pulley rubs the pipe it may rub through the pipe. So take care to anyone who installs a metal pulley.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following 2 Users Say Thank You to charged86 For This Useful Post:
F1point4 (07-09-2013), skatery1989 (07-09-2013)
Old 07-09-2013, 10:51 AM   #33
cb7tuner
My point is... This thread is about failing pulleys and defective parts, it wasn't started because of a pulley rubbing on pipes (i agree that is install error) but it is somewhat related . And not once did I say I don't make mistakes but in my line of work, mistakes cost people their lives. So I tend to triple check things and be more thorough than a lot of others I know. Never said you or anyone else don't know what your doing so no need to get defensive
Old 07-09-2013, 10:54 AM   #34
jamesm
the dude in the video is lucky he checked it when he did. doesn't look like it'd have been long before that pipe had rubbed all the way though, probably sending all sort of little metal bits through the throttle body in the process.
Old 07-09-2013, 11:05 AM   #35
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Here is mine this morning. Had some strange looks from my neighbors as I was swearing at my phone to take the damn picture
Top side. Both edges of the pulley look good.
20130709-VortechBeltClearance-001 by VictorN07, on Flickr
The engine was completely cold, but I have clearance
20130709-VortechBeltClearance-002 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
Drift-Office (07-09-2013), Pete (07-09-2013)
Old 07-09-2013, 11:27 AM   #36
cb7tuner
It may be beneficial to put a very small indention into the pipe where the contact points are closest to the 2 pulleys for the rubbing issue. It couldn't effect flow that much and I'd rather have that compared to a pipe with a hole in it
Old 07-09-2013, 11:41 AM   #37
charged86
charged86's Avatar
Exclamation
I was thinking this too heat up the aluminum a little and give it a tap with a dead blow. Emphasis on the word tap. Hahha so do you think the metal pulley would have better bearings because the pulley is heavier than the plastic
Old 07-09-2013, 11:43 AM   #38
Pete
Pete's Avatar
Drives: 22 BRZ
I checked mine just now in the parking lot, belt & pulley both look good. I took some pics but I can't post 'em till I get home.
Does it sound reasonable to you guys that I may have more clearance because I swapped engine mounts?
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 07-09-2013, 11:49 AM   #39
cb7tuner
Exactly how i would do it, but as far as the metal pulley goes I have no clue. Just because its metal doesn't mean the bearings are any better. Someone be the guinea pig
Old 07-09-2013, 12:07 PM   #40
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
I'm curious to see how many people are having issues due to an actual part failure such as the bearing in the pully seizing. So far we know of one instance and some others are just having issues with the pully rubbing the intake pipe. I checked mine last night immediately after looking at this thread and everything looks good with clearance between the pipe and pulley.
reyruiz191 is offline   Reply With Quote
Old 07-09-2013, 12:17 PM   #41
cb7tuner
I Believe member "tg_1981" pulley seized up on him and broke his belt to
Old 07-09-2013, 12:22 PM   #42
charged86
charged86's Avatar
Fa20club turbo kit looking real dam good about now
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 02:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 09:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 10:57 PM
