AVOturboworld
Old 10-31-2012, 01:14 PM   #1247
djdnz
1337
Drives: 2013 BRZ WRB S/C
Originally Posted by AVOturboworld View Post
It bolts on.
No, seriously. It does. It's amazing. Both oil return and feed bolt onto the head. We did some serious work with this kit.
That really does sound nice, I want to see how this works for my own curiosity's sake.
djdnz is offline   Reply With Quote
Old 10-31-2012, 02:00 PM   #1248
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Avo posted this pic on facebook earlier
JoeBoxer is offline   Reply With Quote
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
Calum (10-31-2012), Klar (10-31-2012)
Old 10-31-2012, 02:49 PM   #1249
mact
Drives: 13 GTI
Is this where the pump attaches? Where the metal cover is to the right..
http://www.ft86club.com/forums/attac...1&d=1330656949
mact is offline   Reply With Quote
Old 10-31-2012, 02:52 PM   #1250
2forme
Judging by the wiring harness just above, I'd say yes.
Old 10-31-2012, 03:07 PM   #1251
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
When will your Turboback UEL Exhaust be released?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 10-31-2012, 04:09 PM   #1252
djdnz
1337
Turboback UEL exhaust? You mean turboback exhaust? The manifold is UEL already.
The Following User Says Thank You to djdnz For This Useful Post:
ngabdala (11-01-2012)
Old 10-31-2012, 04:32 PM   #1253
SkullWorks
Drives: SSM LT MT BRZ
so with that pump placement does this become a manual trans only kit? or do you have a way to mount the AT vacuum pump and this?
SkullWorks is offline   Reply With Quote
The Following User Says Thank You to SkullWorks For This Useful Post:
RYU (10-31-2012)
Old 10-31-2012, 04:50 PM   #1254
mact
Drives: 13 GTI
Here's another shot of where the pump goes. Behind the passenger side head..
I wonder if this is where the pump would go on the factory turbocharged version of the FA20..
Old 10-31-2012, 05:06 PM   #1255
RYU
RYU's Avatar
Drives: really slow...
Interested in knowing performance on AT with this kit as well. This is currently top on my list of power adders
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
ToxicSneakers (10-31-2012)
Old 10-31-2012, 06:28 PM   #1256
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
The same way on a standard turbocharged vehicle, via an electronic or manual boost controller, or with a higher psi boost actuator. AVO has new billet actuators coming out with adjustable springs. Actuators set the minimum psi the turbocharger will run at before it cracks the wastegate open to bleed off unneeded boost.
Good to know that there is room for upgrading in the years ahead
Would this work? http://www.avoturboworld.com/avoshop...ler-p-132.html
Looks like it would fit in the little whole in the dash below the AC controls.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-31-2012, 07:32 PM   #1257
TemeCal
Drives: 86
@AVOturboworld-
What is the aprox install time for an average Joe? I'm by no means a mechanic, but have experience doing top-ends and turbo installs on my off road vehicles. I have no issues doing the work myself, and pulling in some friends if need be. Just curious to know how much time would be involved...
Thanks!
TemeCal is offline   Reply With Quote
Old 10-31-2012, 08:09 PM   #1258
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
Originally Posted by Tansey86 View Post
Can this kit be externally gated?
I asked this very early on, and the answer is with a little work yes it can be made external. One of my friends here is very experienced with cutting and welding the external mods onto them, and he is confident about this setup as well. as for a quick bolt on external.. I was told not applicable.
Batman is offline   Reply With Quote
Old 10-31-2012, 08:51 PM   #1259
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by TemeCal View Post
@AVOturboworld-
Thanks!
Ross could probably do an install in 3-4 hours, because he knows where everything goes and how it got there. Somebody doing it for the first time with the instructions is probably going to be between 6-12 hours depending on preparation and mechanical skills.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
TemeCal (11-01-2012)
Old 10-31-2012, 09:30 PM   #1260
AVOTurboworldJapan
Yes this will be a future upgrade on the kit
AVOTurboworldJapan is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
