AVOturboworld
Old 09-27-2012, 08:38 PM   #659
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by Jeff86 View Post
Thanks for the teaser. The scavenge pump is my biggest concern about your setup and I like the fact that I couldn't hear a noisy electric pump. Very curious to see what you are doing. I've heard of mechanical pumps driven off of cam gear. Is there going to be a reservoir? One of my worries is the pump being too efficient and running the turbo dry.
There will be a reservoir, of course. That's the only way to design it.
We don't like the sound of a electric pump either. And with an electric pump, you don't have the control over pump speed that you need (idle vs. higher rpm).
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
Jeff86 (09-27-2012)
Old 09-27-2012, 09:40 PM   #660
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by Batman View Post
@AVOturboworld
Is there any chance of an external wastegate setup on this?
They stated that they would not be using one, since the internal wastegate they use on their exhaust housings perform as designed, and control boost fine.
That being said any qualified tuner shop should be able to add an external wastegate to the kit. Just weld the internal closed, and weld a flange/wastegate to the exhaust manifold manifold.
No Limit Motorsport is offline   Reply With Quote
Old 09-28-2012, 02:02 AM   #661
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
Thanks, I'm somewhat new to the aftermarket turbo world, I've always tuned up stock turbo setups. Loving this kit so far though!
Batman is offline   Reply With Quote
Old 09-28-2012, 09:34 AM   #662
djdnz
1337
Drives: 2013 BRZ WRB S/C
Having run an external wastegate on my last car, it's really not worth it on low boost. More piping needed, more weight, more cost, more potential for squeaks. Internal wastegate is the way to go with a low boost application.
djdnz is offline   Reply With Quote
Old 09-28-2012, 10:03 AM   #663
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
yea def, an ewg is not going to be needed. it won't benefit anything, besides noise.
VSGTS14 is offline   Reply With Quote
Old 09-28-2012, 04:05 PM   #664
Batman
Easy, Tiger.
Batman's Avatar
Haha well I'm all about noise, but its nothing a good straight pipe can't fix. I'm used to the 22 psi on my TT so its a new experience. Thanks!
Old 09-28-2012, 05:04 PM   #665
dsmx17
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
An external wastegate is ideal for low boost applications. (just to clear that statement up)
dsmx17 is offline   Reply With Quote
Old 09-28-2012, 05:11 PM   #666
djdnz
1337
That's exactly the opposite of what I just said...
Internal wastegate is less complexity, less cost, less weight, smaller space envelope. My own opinion is to stay internal until you are running high enough boost that the internal wastegate can't flow enough.
The way i see it, the AVO kit is not really aiming for pure power numbers, it's a fairly balanced and easily streetable setup. I'd imagine that a nice 8psi will give you a 280whp output, which an internal is more than capable of handling. Not to say this kit isn't capable of more, just with the components they have shown off that's my guess as to where AVO had planned to go.
Now, AVO some updates please!
The Following User Says Thank You to djdnz For This Useful Post:
Drift-Office (09-28-2012)
Old 09-28-2012, 05:26 PM   #667
dsmx17
4g63>rotards
I understand its not what you said, im at work so I tend to type less than an entire thought sometimes.
An external wastegate with larger diameter ports than most internal wastegates is more capable of controlling low boost applications with low to zero risk of boost creep.
IE: once the exhaust is free flowing post turbine, a small internal wastegate has trouble opening soon enough/and large enough to keep boost at low pressure. Where compared to a 44mm external wastegate, regulating low pressure regardless of exhaust flow/turbine speed is easily maintained.
*Edit try blowing air into a baloon consistently with a small hole in it VS a large hole and imagine which would cause the baloon to fill more.
Old 09-28-2012, 05:35 PM   #668
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
^^^ QFT...
^^^ Indeed! You should have like Friday updates for all of us every week until this kit comes to market!
Bob
Drift-Office is offline   Reply With Quote
Old 09-28-2012, 05:38 PM   #669
djdnz
1337
Agreed, the external will provide better control, however in an application where cost, weight and packaging are to be considered, that is only one part of the equation.
Boost creep can be accommodated for if designed correctly, and ultimately kept within safe limits.
Old 09-29-2012, 05:13 PM   #670
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How much boost can the internal on Handel?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 09-29-2012, 05:40 PM   #671
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Haha I love all your bitching it's laughable.....I know that alot of followers in here don't read before they think or type for that matter.
The best part about this kit is it was designed on JDM model RHD and that all the US companies are developing on LHD...AVO are smart enough to think that both RHD and LHD customers will want this kit.
I get the feeling that alot of US tuners only see the US as the whole picture and this makes me think the R & D of this kit is top notch.
My only downside to this UEL Header design is the boxer burble which being a Toyota Fan I was hoping to avoid on the car just to separate the WRX typecast. This is not a whine just a personal touch I would have avoided if I could.
I am interested Paul in working out the scavenger oil return will there need to be a hole made in the sump for return?
GC GTS Aero Kit is offline   Reply With Quote
Old 09-29-2012, 07:12 PM   #672
Celica00
Celica00's Avatar
Drives: 86
soo... thats just as much whining as anyone else is doing here. sometimes, people have gripes and wording it conservatively doesnt change the fact that its a gripe. either way, it'll be a great kit and definitely one i'm rooting for.
Celica00 is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
