AVOturboworld
Old 08-29-2012, 09:15 AM   #323
subatoy
subatoy's Avatar
Drives: subatoy
Originally Posted by AVOturboworld View Post
OEM Turbochargers are, in general, internally wastegated to bleed off boost pressure into the exhaust. It is easier to package that way, and is quieter.
External wastegates became popular because many aftermarket turbochargers simply use an OEM or off the shelf exhaust housing, and the internal wastegate wasn't large enough to keep up with the higher boost of larger compressor wheels that were fit. It would overpower the small wastegates, and boost creep would come into play. The solution was to simply move that to an external wastegate setup.
There is, of course, another solution - make a larger exhaust housing with larger wastegate. However, that solution requires somebody to actually cast and mill the housings themselves. To toot our own horn, and to be also totally blunt about it, we are one of the few that make our own exhaust and compressor housings. Thus we haven't gone down the external wastegate path - if there were boost creep issues, we'd engineer that issue out on the exhaust housings. That's why our AVO380's are running just fine at 30psi on diesel racing trucks on an internal wastegate setup.
But lets be realistic here - a 12:1 compression 2.0-liter engine isn't going to run 30psi, other than on very exotic builds. 5-10psi is likely the limit on a "street" build that's both daily driver friendly and reliable. At those psi/boost levels internal vs. external wastegating is not much of an issue.
I'm happy with whatever keeps the prices down.
I will NEVER pay $5k for a turbo kit plus installation.
I'm aiming to have $5k as a budget with the kit installed.
subatoy is offline   Reply With Quote
The Following User Says Thank You to subatoy For This Useful Post:
civicdrivr (08-29-2012)
Old 08-29-2012, 10:01 AM   #324
Gen
Drives: Scion FR-S
All said and done, you're probably not going to be under 5k with this one either. (tuning, install, etc.)
Gen is offline   Reply With Quote
Old 08-29-2012, 10:19 AM   #325
bakerr6
Drives: 2013 raven black fr-s
I'd throw that budget out the window. Anyone that plans on spending xxx amount of dollars on a kit, and doesn't understand what adding more power does to vehicles. Things are going to break when extra parts are added. Just keep this in mind
bakerr6 is offline   Reply With Quote
Old 08-29-2012, 10:30 AM   #326
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by 2forme View Post
This is awesome news for us with the SRT header back exhaust system already.
This kit looks like it would be a snap to install/take off if going to the dealer for anything. The price is certainly right. All I need is a dyno graph and I'm sold. Then I can finally steal @Visconti for a day and we can have our own turbo fun haha
I wouldn't plan on the following occurring at the same time:
1. Having a turbo
2. Getting warranty work
3. Having a warranty at all
4. Passing emissions in cities
Are you just going to remove the entire turbo kit and reflash a stock tune every time something bad happens? Good luck, I've never seen anyone work that hard or pull it off. Not to mention if they are trying to warranty something big like powertrain related, they'll search the flash-counter. And if you are t-charged, then your counter is likely to be a sky high number from tuning.
Old 08-29-2012, 10:42 AM   #327
2forme
1. Having a turbo
see below quote...
I don't mean to jump in your thread but the EcuTek tune is not detectable at the dealership level ( reconfirmed last week).
There is also no built in flash counter in the ECU - EcuTek has their own flash counter that dealer tools do not see or understand.
When the car comes in for a warranty flash update the dealer tools puts a flash count on the ecu. Only dealer tools can see or change this flash count - much like EcuTeks own flash count.
If there was a flash update available you most likely hear from me first but nothing to worry about. If and when this happens you will backup your new dealer flash with a EcuTek cable so it can be put back in at a later time.
Also with the EcuTek tune the dealer tools or any other flash tools will not be able to override the flash - basically you can not lose your tune when going in for service work.
If you have anymore technical questions about the ecutek tuning tools feel free to take a look at my flash info thread in the ecu technical section as it contains a lot info about this stuff.
John
In addition, removing the header + turbo + piping looks to be fairly straightforward and rather easy on this motor setup.
Old 08-29-2012, 10:58 AM   #328
Synack
Boosted
Synack's Avatar
Drives: Sideways
see below quote...
My point is, you can only fool the dealership for so long.
Old 08-29-2012, 11:04 AM   #329
2forme
Don's done more then 200 dyno runs on 5-8 psi without issue so hopefully it wouldn't have to go to the dealer haha
I get what ya mean though.
Old 08-29-2012, 11:36 AM   #330
subatoy
subatoy's Avatar
Drives: subatoy
yeah but the differences is that this kit is aimed to cost $3,600
so you are ALREADY starting with $1,400 on your pocket vs all other kits that cost $5k.
I've either purchased turbo cars or turbocharged them all my life. Installation wise if you know the right people then it's cheap.
tuning is another story.
Old 08-29-2012, 11:38 AM   #331
subatoy
subatoy's Avatar
Drives: subatoy
you need to understand that when you add FI to a car is because you are willing to lose your warranty PERIOD.
thats why you look for the msot realiable option out there.
running 430whp IS NOT reliable on a tiny engine with such high compression.
this is why I want to stay at 5psi.
coyote (08-29-2012)
Old 08-29-2012, 02:48 PM   #332
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Sure it is! E85 baby!
I agree somewhat, I mean if you look at it from other cars. Take a corvette for example the base model has 430hp. Double that with some slick turbo setup and you're looking at 860hp. That's crazy and probably not reliable.
So doubling the output from any car is crazy, if you can do this safely with the FRS, give maybe a 1 year parts warranty, I'd be sold.
Ironsquid is offline   Reply With Quote
Old 08-29-2012, 02:54 PM   #333
xxscaxx
Drives: 2013 SWP BRZ
We don't know that yet. Look at the f series in the s2000. People run 2x the amount of power on that all day, reliably.
Until someone pops a motor, it's moot. Even then, there are many factors that will play into what made it blow. It's too early to tell.
I wish it wasn't though, lol.
xxscaxx is offline   Reply With Quote
Old 08-29-2012, 03:00 PM   #334
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
like modding any car, the stock block is only going to last so long.
VSGTS14 is offline   Reply With Quote
Old 08-29-2012, 03:04 PM   #335
subatoy
subatoy's Avatar
Drives: subatoy
Trust me I really want to be wrong but I'll believe it when I see it.
Old 08-29-2012, 11:02 PM   #336
xxscaxx
I agree, just trying to be optimistic lol.
5psi daily I think will be enough anyways. You have the right idea.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
