AVOturboworld
Old 06-12-2014, 06:49 PM   #2983
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Originally Posted by AVOturboworld View Post
We saw the issues on stock cars w/stock tune - those pictures are from a stock engine we took apart to find what was going on.
Could this be responsible for the periodic drops or surges at idle I experience after coming to a stop, or is this normal for FA20s?
Whatabouteggs is offline   Reply With Quote
Old 06-12-2014, 07:49 PM   #2984
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
From my experience over a great variety of BRZ's and FR-S's, there is a bit of dip when coming to a stop, and that is relatively normal. If it's enough to cause the car to stall, then it's an issue that needs to be looked at. If the air conditioning is on, it'll do it when it cycles on and off.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
SkAsphalt (06-13-2014)
Old 06-13-2014, 10:24 AM   #2985
DD_FT86
Drives: 10 Series Scion FR-S
New to the forum and have been looking for a reasonable Daily Driver FI upgrade. This turbo kit is peaking my interest so I have a few questions:
1) Does the stock crash beam remain intact?
2) For the Stage 1 kit, would upgrading to the billet turbo be worth it? What are the advantages?
3) Any good installers/tuners in South Florida that have previously installed these kits on the FR-S/BRZ?
4) As a daily driver, MPG is still important. Do you have any figures on that?
Thank you!
DD_FT86 is offline   Reply With Quote
Old 06-13-2014, 10:35 AM   #2986
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thank you!
1. Yes
2. Worth it is a relative question. They wouldn't offer it if it wasn't worth it to someone.
3. @Sportsguy83
4. All turbo kits will get similar MPG it will come down to your tune and how you drive the car. Expect a 10% loss in MPG.
You're welcome!
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Draco_PR23 (06-14-2014), SkAsphalt (06-13-2014)
Old 06-13-2014, 11:01 AM   #2987
DD_FT86
Thank you. One unanswered question: What advantage does the billet turbo have over the non-billet?
Old 06-13-2014, 11:01 AM   #2988
AJPG
Drives: 22RE, FA20, 4G63
Mine use to do the erratic idle stoke, went FI and it continue, start using race gas as DD and improve a little, change TUNER a couple of times and presto it run like you may expect from a new car with the latest in technology.
I'm not a certify master tuner but been tuning my cars since 1994, is fun, time consuming, at times frustaiting... And will need a secondary car.
AJPG is offline   Reply With Quote
Old 06-13-2014, 11:26 AM   #2989
AJPG
Power! higher boost capability, can run higher boost pressures more reliably simply because they are less susceptible to fatigue. The same compressor (billet vs cast) at the same boost almost the same CFM.
Old 06-13-2014, 02:38 PM   #2990
AVOturboworld
The thing to keep in mind here is that Subaru/Toyota has been updating the ROM's of the cars, from 700 to A00, then A01, then B00 and B01. It's likely that you were experiencing the idle issue because of the ROM revision in your car was an earlier one, and the last tunes were updated to the latest ROM revision by the tuner.
Ecutek does it's best to keep up with updates from the manufacturer for this reason, often the manufacturer is making changes to the ROM files to fix issues that were on the early release models.
AJPG (06-14-2014)
Old 06-13-2014, 02:42 PM   #2991
AVOturboworld
The main advantage of the billet turbo will be seen at higher boost levels. It's best to plan any FI build around your power goals. If you are planning to stay on pump gas (91-93 octane), then it is fairly easy to plan it out. On pump gas you'll max out at 300-320whp, which is easily attained with the standard turbo setup with upgrades to surrounding components (exhaust, fueling). So no overriding reason to upgrade to a billet turbocharger.
However, if you are planning on an e85 build and are looking to do 400+whp, then the billet turbocharger would be good to start with. It would probably be the least of your costs given all the supporting mods and upgrades you'll also need.
AJPG (06-14-2014)
Old 06-14-2014, 06:29 AM   #2992
AJPG
Completely agree!
Do some back and fwd with the different tunes (from different tuners) and there is almost the same idle with each one, rpms, AFR, ac on and off, but only with the more recent tunes.
Old 06-14-2014, 07:21 AM   #2993
s2d4
s2d4's Avatar
]change TUNER a couple of times and presto it run like you may expect from a new car with the latest in technology.
I'm not a certify master tuner but been tuning my cars since 1994.
If so, why not tune your own car?
Old 06-14-2014, 07:56 AM   #2994
AJPG
From 1994 to 2010 I was a student so have plenty of time and little or no money, now I do have work but almost no time plus I got married.
Changing part is easy ( except for the fuel pump ) but to make an good tune take a lot of time, ann outstanding tune even more time, this platform have tuners to chose so why not? If we talk about the 22re or the 4G63T with piggyback then my friend, there is no way some one would email some tune...
Old 06-20-2014, 01:19 PM   #2995
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by protpibe View Post
Yeah I'm thinking avo gaskets may be part of the fix, but also if the header is already warped, I'm thinking I will need a new header. Not sure what effect the AVO header studs would have, but they now offer those on their website too.
The leak is pretty clear once you stick your head under the car
That was about 3 weeks ago I think, about a week after I had the OEM gaskets installed. I'm sure it's much worse now.
edit: Oh, and I have about 4,000km on the kit now.
No need to post the same pictures, but mine appears to be leaking about the same if not a little less... not affecting anything it seems, but certainly a bit of a leak. I thought it was my downpipe matting up to my SRT headerback that was leaking, but i see the black off of the headers. I will drop it all sometime soon and cut some custom gaskets - its a bit old fashion, but it worked in my dad's turbo 350 small block and that thing was pushing 2-3 times my boost.
Note for clarity Still loving this kit. Thinking of picking up a EBC and delicious tuning SD maps
Old 06-21-2014, 12:30 PM   #2996
onzippy
Drives: 2014 FRS
Same boat here. Woe is me...
2k miles since I last looked under the car (3k total AVO miles) and today, while installing my shiny new perrin over pipe, I see little soot marks on both heads... and a gnarly coolant leak from a banjo bolt. I thought was the lucky one.
Just going to let it ride for a while. Can't hear it yet.
(I'll post the same pictures again... )
onzippy is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
