AVOturboworld
Old 05-26-2014, 03:19 PM   #2955
onzippy
Drives: 2014 FRS
Yikes.. That's pretty obvious.
Keep us posted on how it works out.
onzippy is offline   Reply With Quote
Old 05-26-2014, 03:23 PM   #2956
protpibe
protpibe's Avatar
Yeah, it's not exactly minor lol.
My guess on the header warpage issue after experiencing it is that the header needs to be installed correctly the first time. Proper gaskets, proper torque pattern, and re-torquing as it's heat cycled. It seems like it's warping if it weight distribution isn't near perfect the first time it's installed, and once it's warped it's warped. Just my own personal opinion, I'm not sure how much validity there is to it.
Old 05-26-2014, 03:41 PM   #2957
onzippy
Drives: 2014 FRS
Well.... I can be quite ham-fisted with tools sometimes. Couldn't find my torque wrench so they were tight getting off, I made them tight when I put them on. But I did go back a few days later to check and had to tighten them once more because the were loose. "Tight" being the measurement of what I remembered when taking them off several days prior. So far so good.
I have found my torque wrench since then.
So you throw a spacer in with the new gasket and let it warp back. In couple weeks take the spacer out... I'm half serious. Probably something I would try if I was doing the labor on my own car and all the other option required the outlay of more cash. Metallurgy is a little weird so...
Old 05-26-2014, 04:29 PM   #2958
protpibe
protpibe's Avatar
That's something I would probably try if I bought the kit used. Having bought new and plan on keeping it for a long time, I don't think I should resort to warping a part back into place lol.
Admittedly, it does sound like it might work though
Old 05-26-2014, 06:31 PM   #2959
onzippy
Drives: 2014 FRS
If i missed it, I'm sorry, but I wonder how much value added there is to bolting the manifold to a third mount point that must align in a perfect plane with two other surfaces. Sure there's some additional torsional stress with the weight of the turbo but I've had motorcycle exhaust bust a mount on the can and the whole damn thing is hanging from the header. That's about 4ft of stuff hanging in the wind from the manifold bolts for unknown period of time.
R&D knows best so if there's a risk, kudos to AVO for putting it in the design.
Old 05-27-2014, 07:31 PM   #2960
aaguirre123
Drives: sti 2012 sedan
Yeah I'm thinking avo gaskets may be part of the fix, but also if the header is already warped, I'm thinking I will need a new header. Not sure what effect the AVO header studs would have, but they now offer those on their website too.
The leak is pretty clear once you stick your head under the car
That was about 3 weeks ago I think, about a week after I had the OEM gaskets installed. I'm sure it's much worse now.
edit: Oh, and I have about 4,000km on the kit now.
i really like the AVO kit. the design makes the most sense. but when i see something like this... very disappointing. would you still recomend this kit? i was so looking forward to buying this kit.
aaguirre123 is offline   Reply With Quote
Old 05-27-2014, 07:43 PM   #2961
protpibe
protpibe's Avatar
If the issue gets resolved by AVO in a timely manner, then yes, I would still recommend it.
I like the design and layout of the kit, I just don't want little issues cropping up. Everything else about the kit seems solid so I figure once this is resolved, it should be worry free from here on in. I did use Grimmspeed gaskets on the initial install and did not shim the bracket, so that may have caused it to slightly warp in on itself. The install was done prior to AVO modifying their kit and including their own gaskets so my expectation is that I'll be shipped a new header.
Old 05-28-2014, 01:05 AM   #2962
aaguirre123
i hope it gets resolved or else i'll be hesitant to buy their kit. by the way did you buy it directly from paul?
Old 05-28-2014, 09:31 AM   #2963
protpibe
protpibe's Avatar
No, but I spoke with him a lot about it before I actually did buy it. He's a good guy and very knowledgeable.
I ended up going through a local shop just to make everything easier. I'm in Canada so they took care of all the customs, brokerage, etc.
Old 05-29-2014, 10:48 AM   #2964
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
My AVO kit was fitted last August, and I have done about 10,000 miles with it, and no blowing issues. I believe that AVO are working on a thicker flange to eliminate the problem. With their level of customer support, I am sure any faulty manifold would be replaced. I would not hesitate is buying the kit all over again, if I had to make the choice.
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
kbogarto (05-29-2014)
Old 05-30-2014, 08:29 PM   #2965
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
AVO has been great for my customer service so far.
Old 06-04-2014, 12:19 PM   #2966
kbogarto
Drives: 2013 BRZ limited WRB
So add me to the list of leaking header gaskets. It was initially installed with Grimmspeed gaskets but done before the support bracket shimming post was made. Everything was torqued and re-torqued after heat cycling a few times. I'm thinking maybe the header warped in that time without the spacer on the bracket? I've recently switched to OEM gaskets but the leak came back, I'm guessing due to warpage from the initial install. I'm currently awaiting word from Paul on the fix, but I'm thinking I may just get the header flanges planed to see if that will fix it. The small noise it makes honestly drives me nuts. Maybe I have OCD or something but I can't drive with my windows open with it leaking even a little bit
I'll post up results on how I get it fixed
Did you get your header fixed? Curious on any word from AVO about this. Thanks
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 06-04-2014, 01:24 PM   #2967
protpibe
protpibe's Avatar
Yup Paul looked after me.
Sent from my HTC One using Tapatalk
The Following User Says Thank You to protpibe For This Useful Post:
kbogarto (06-04-2014)
Old 06-06-2014, 10:46 PM   #2968
Astroboy
Astroboy's Avatar
Drives: None
I want to hear from former 86 owners w/ avo kit on where they sliced their t valve for their boost gauge and where's the best line to connect it to.. please
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
