AVOturboworld
Old 04-07-2014, 11:49 AM   #2871
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by protpibe View Post
Isn't it the fitting and not the line that's the problem ?
That is exactly what I was thinking when I read Paul's response.
Old 04-07-2014, 12:19 PM   #2872
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
They are sending the fitting. I believe that was cleared up between AVO and myself over PM. The fitting is what was incorrect.
Also missing a the barb'd T fitting for the BOV to brake booster line, so thankfully they are including that with the fitting.
Also related, SRT header back exhaust has a terrible flange that may or may not have sealed up well to the down-pipe from the turbo. I will not know for a few days (until I can start the car) but damn that is an annoying bit of news too. Explains why MrJay switched it up
Old 04-07-2014, 12:33 PM   #2873
protpibe
protpibe's Avatar
I used RTV + a new gasket on the downpipe, overpipe, and front pipe flanges just to be 100% sure there are no leaks. That might increase the chances of having it seal with a sketchy flange
I would highly recommend a vacuum manifold as opposed to just tee'ing off what you need. It's a little more work upfront, but it will make things much easier down the road and clean up the area around the brake booster. I also got a custom tee hardline made up to tap in behind the intake manifold as opposed to just chopping the line itself. So much cleaner!
Old 04-07-2014, 01:25 PM   #2874
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Question guys, the air line that we pull off the factory inlet pipping (it connects to a 90 degree fitting right before the throttle body), what do we do with that line? It was not clear in the instructions.
This is one of my remaining questions left with my install.
Old 04-07-2014, 01:30 PM   #2875
protpibe
protpibe's Avatar
There should be a giant nipple coming off of the airbox piping just after the 90 degree bend that points towards the throttle body, and a dual male barb fitting to link the two hoses.
The Following User Says Thank You to protpibe For This Useful Post:
SkAsphalt (04-07-2014)
Old 04-07-2014, 01:32 PM   #2876
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Oh ok, well that is easy enough (and explains the positioning)
So then the long rubber hose that came with the car (that connects to the oil reservoir off the turbo) connects to what? I do not have a breather tank of any sort?
This forum rocks
Old 04-07-2014, 01:35 PM   #2877
protpibe
protpibe's Avatar
You'll have to tee the crank vent line and oil reservoir vent line together. The other option is get a crank case vent filter for the oil reservoir line until you get an air oil separator.
Old 04-07-2014, 01:52 PM   #2878
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
It will be iffy. I know of another SRT + AVO owner who had the SRT cut and redone to make work whos forum name escapes me at the moment.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
Old 04-07-2014, 02:49 PM   #2879
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
It basically looks like either a lot of RTV gasket goop to help me out along the bottom, or possibly tack wield on the spot that's leaking. My exhaust sounds pretty great - I would like to keep it... but man - they should have made it with flanges and not vbands and slide on pipes.
Old 04-08-2014, 02:08 PM   #2880
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Car was taken apart on Friday, today is Tuesday...joys of missing parts. Thank goodness I do not have to pay storage or shop fees. One positive here.
Edit Paul from AVO is doing his part in getting the shipment to me. Administrative red tape got the packaged delayed at UPS and push everything. Looking at a Wednesday or Thursday completion now. Not exactly what I was planning for.
The Following 3 Users Say Thank You to SkAsphalt For This Useful Post:
Astroboy (04-08-2014), AVOturboworld (04-08-2014), Sportsguy83 (04-08-2014)
Old 04-08-2014, 07:04 PM   #2881
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Damn missing parts eh? I hope @AVOturboworld takes care of you!
Out of the FRS game
Old 04-08-2014, 08:56 PM   #2882
Astroboy
Astroboy's Avatar
Drives: None
Was the avo turbo kit stage 1 suppose to come with anything connecting these two pipes together? I have nothing left to insert in there and that is all I need other than a tune to get her running 😑
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-08-2014, 09:20 PM   #2883
protpibe
protpibe's Avatar
No, they wouldn't have supplied any caps. You'll have to improvise, literally. Make sure the cap fits over top of the pipe and not inside. Also, make sure they're clamped down tight.
I would suggest ordering the OEM style bov from AVO and do it properly.
http://www.avoturboworld.com/avoshop...rbo-p-198.html
The Following 3 Users Say Thank You to protpibe For This Useful Post:
Astroboy (04-08-2014), SkAsphalt (04-08-2014), Sportsguy83 (04-09-2014)
Old 04-09-2014, 02:22 AM   #2884
protpibe
protpibe's Avatar
Attachment 73658
What kind of oil cooler sandwich plate is that?? That thing is huge
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
