AVOturboworld
Old 02-13-2014, 03:31 PM   #2815
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by qtwre View Post
Which gasket will you be supplying? Just the standard one that is already on the car, or something like the turbo Forester gasket? Having just bought my kit last week and not yet installed it, I'm obviously missing this new piece but I'd like to make sure I'm getting this kit set up right.
We will be shipping them with the JDM Subaru STI Spec C (GDB) 2.0 metal gaskets.
AVOturboworld is offline   Reply With Quote
Old 02-13-2014, 07:36 PM   #2816
Bigmaxy
Drives: Pegasus GTS86
Hi @AVOturboworld
Would you be able to recommend a drop in fuel pump and injectors to run your stage 2 kit on E85?
Cheers.
Bigmaxy is offline   Reply With Quote
Old 02-13-2014, 07:37 PM   #2817
AVOturboworld
That depends entirely on your intended WHP goals.
Old 02-13-2014, 07:47 PM   #2818
Bigmaxy
I guess that is a fair response. What would you suggest is a reasonable boost pressure and power figure for this turbo and engine?
DW65 and 700cc injectors. 300WHP?
I thought you guys were developing a drop in replacement pump. Is that still happening or am I mistaken? Thanks.
Old 02-13-2014, 07:59 PM   #2819
AVOturboworld
300whp is available on the stock injectors and the upgraded fuel pump on 92+ octane gas (98 octane in Australia). E85 is generally looked at for those 350+whp builds.
Old 02-13-2014, 08:50 PM   #2820
Bigmaxy
ok. How about 350+whp? The reason I want to go E85 is for emissions testing rather than power. But not going to pass that opportunity up either. :-)
Old 02-14-2014, 04:47 PM   #2821
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Im running E85 with around 350whp on my AVO kit.
Fuel pump is a DW65c
And for injectors the ID850
gdrider77 is offline   Reply With Quote
The Following 2 Users Say Thank You to gdrider77 For This Useful Post:
Bigmaxy (02-14-2014), CxG (06-25-2016)
Old 02-18-2014, 08:52 PM   #2822
AVOturboworld
I put together an illustration to explain the header issue and differentiate between a warped flange and flanges that are not flat on a plane.
The first illustration is flanges that are flat on a plane. The problem with the Subaru header design is that, with a tubular header, the flanges will tweak in or out a little. It's quite common on Subaru headers. However, the flanges themselves are flat.
The problem is, as in illustration no. 3, some people will attempt to "flatten" the flanges from side to side to make it flat on a plane. That simply creates angled flanges, and they may not bolt down correctly at that point. Simply bolting the header down without touching the flanges, and it would straighten out naturally.
Illustration no. 4 shows what can happen if you put thicker gaskets on without spacing out the bracket mount in the middle.
I'll update our install guide with this information as well.
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
nataku (02-18-2014), Pitman (02-19-2014), protpibe (02-18-2014), SkAsphalt (02-18-2014)
Old 02-18-2014, 09:12 PM   #2823
protpibe
protpibe's Avatar
I was telling a mechanic of many years about this today while we were looking at the header, and he instantly saw how that support bracket could cause a gasket leak without proper installation. There's also a lot of extra weight on the header flanges due to the turbocharger hanging off of it, so it's pretty imperative that the support bracket is installed correctly.
The Following 2 Users Say Thank You to protpibe For This Useful Post:
CxG (06-25-2016), SkAsphalt (02-18-2014)
Old 02-18-2014, 10:17 PM   #2824
Bigmaxy
Hi @AVOturboworld
Thanks for the diagram. It does help clear up where you are describing a problem.
Would you say that my header flanges are within spec?
Thanks
Old 02-18-2014, 10:33 PM   #2825
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by vgi View Post
dude, obviously the top pick - you put too thick gasket, and the bottom pic - you ground it incorrectly because "the flanges themselves are flat"
If you're being sarcastic, you are not helping.
Old 02-18-2014, 10:46 PM   #2826
Bigmaxy
Took me a couple of reads but I did detect the sarcasm. :-)
The Following User Says Thank You to Bigmaxy For This Useful Post:
vgi (02-18-2014)
Old 02-18-2014, 11:16 PM   #2827
AVOturboworld
Originally Posted by Bigmaxy View Post
Hi @AVOturboworld
Thanks
If they came out of the box that way, no, they are not within spec. But since they look to have been fitted and run for a bit, it gets down to run how long, with what boost?
Old 02-18-2014, 11:57 PM   #2828
Bigmaxy
3000 Km's. 5psi boost. Ceramic coating peeled so they were sent to be recoated. Thanks
Sent from my GT-I9505 using Tapatalk
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
