AVOturboworld
Old 12-11-2013, 08:54 PM   #2745
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
Is it possible to buy the AVO kit without the ECUtek? Id like to use the OFT instead. @AVOturboworld
glorydays is offline   Reply With Quote
Old 12-11-2013, 08:58 PM   #2746
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
It is entirely possible to buy it without Ecutek, we don't insist on that. We just don't have any OFT basemaps available for the turbokit at this time.
AVOturboworld is offline   Reply With Quote
Old 12-11-2013, 09:28 PM   #2747
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I posted my comment right after you guys posted something so you may have missed it, but would a manual boost controller be a beneficial item for this kit? I would be getting a BOV too. Thanks!
Old 12-11-2013, 11:56 PM   #2748
AVOturboworld
I don't think you need to worry about a manual boost controller initially. It is something I would only look at after you've got the kit installed and have everything operating smoothly.
The Following 3 Users Say Thank You to AVOturboworld For This Useful Post:
DAMotorsports (12-12-2013), Draco_PR23 (12-12-2013), SkAsphalt (12-12-2013)
Old 12-12-2013, 11:26 AM   #2749
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I'm still debating between a MBC or an EBC.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 12-12-2013, 01:50 PM   #2750
AVOturboworld
The reason I mentioned not installing the MBC on the initial install is really for a couple of key issues. The main reason is trouble shooting.
Installing any sort of FI to a non-FI car is going to introduce potential issues. We would all love to have a 100% trouble free no-issue install, but lets face it, there is often issues when even just installing a piece of exhaust. So with something more complicated like a FI kit, you want to concentrate first on getting the kit on and running properly. That way, if there is any problems, you know it is with something on only that area. When you install several different parts at the same time, when an issue does arise, you can (and frequently do) end up chasing your tail because you don't know which of those parts is the problem.
I'll admit, though, it's cheaper to get some things out of the way all in one package - if you are installing an FMIC, a radiator upgrade, and an oil cooler, you want to do that all at once while the bumper is off and everything is already apart. But then, it's fairly easy to guess which of those items is the problem area because they do different things.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Old 12-12-2013, 01:58 PM   #2751
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Paul is completely correct here, I have tuned a few of these kits and having the standard package from AVO installed and dialed in perfectly is ideal first. From there then you can add in boost control through EcuTeK for more power and have it on switchable maps.
But make sure the kit is working as expected with the AVO tune or our tune. It will help in the long run and make you, the customer, a little happier to know it is working to the specs already defined.
Cheers,
William Knose
The Following 5 Users Say Thank You to DeliciousTuning For This Useful Post:
AVOturboworld (12-12-2013), DAMotorsports (12-12-2013), DesertFrs (12-13-2013), Draco_PR23 (12-12-2013), SkAsphalt (12-14-2013)
Old 12-13-2013, 10:03 PM   #2752
AVOturboworld
Stage 3 testing on the AVO Turboworld Japan BRZ
We've been hard at work here at AVO on a variety of projects, with possibly the biggest one right now being the Stage 3 upgrades for the AVO BRZ/FR-S turbocharger kit. Our Stage 1 turbocharger kit has been incredibly popular worldwide, and has made a lot of people very happy by bumping the power up dramatically, from 165whp to 260+whp. Yet some people want more, much more, and we've listened to their requests.
It would have been easy enough to just up the boost and get a few glory runs on a dyno, but we are far more committed to our customers long-term enjoyment than that. We wanted Stage 3 to be as reliable as possible, with all the high-quality engineering and attention to detail that has been a trademark of AVO for the last 40+ years.
To this end, we spent a considerable amount of time and testing on our fuel pump upgrade, as the car was already starting to reach the limits of the pump at 300whp, and we were planning to go much further than that. After much time and effort, we have now got a full bolt in, no fitment compromise fuel pump that does not require any re-wiring or dremelling. It clips right in to the assembly, and doesn't require you to have the fuel filter mashed up against the bottom of the pump housing. The standard wiring harness will clip right into it as well, and it doesn't require additional O-rings to seal up.
Matched up with that is our upgraded Port Injectors. These were also designed to fit to the BRZ/FR-S, with the longer "neck" on it so that they reach down into the intake system and spray properly, unlike some other "short" designs that merely let the gas puddle down. Put these together with the fuel pump, and we now had the fueling to push the engine further.
But why so much extra fuel? Because we upgraded the turbocharger as well! The Stage 3 turbocharger utilizes a new billet compressor wheel with a more efficient design. While the overall size of the turbocharger hasn't changed, the flow has improved dramatically enabling us to push it harder at higher boost levels. This allows up to bump up the peak horsepower available while keeping the impeccable low-end torque that makes this turbo kit such a pleasure to drive.
The final piece of the power puzzle is the complete 3" exhaust system that will come with this kit. We don't mean just from the cat-back, no, this exhaust is 3" from the turbo charger exhaust housing back. The turbo discharge pipe and crossover pipe have been re-designed to provide maximum flow from the turbo all the way back.
As part of the testing we recently put the Stage 3 kit through it's paces at the RevSpeed Super Battle Time Attack at Tsukuba Circuit. It went very well, with the car going roughly 1.5 seconds faster around the circuit on the exact same tires as earlier in the year. Power through the corners was very well controlled, and it was a rocketship exiting the corners and on the straights.
Immediately after the event we put the car on the dyno to see how it was doing at the race settings. Power was quite impressive, with 373whp on tap at 6400rpm, and a peak of 318ft/lbs of torque at 4800rpm. Even more exciting is how it was doing 290ft/lbs of torque from 3300rpm. This is a quick-responding turbo!
We are still undergoing testing, but expect to see this available soon from AVO!
The Following 11 Users Say Thank You to AVOturboworld For This Useful Post:
Bach415 (12-13-2013), Brody602 (12-13-2013), civicdrivr (12-18-2013), DoomsdayJesus (12-19-2013), Draco_PR23 (12-13-2013), Guff (12-14-2013), jamesm (12-19-2013), Mr.Jay (12-15-2013), Pete156 (12-14-2013), SkAsphalt (12-14-2013), TRD_07 (12-14-2013)
Old 12-13-2013, 10:35 PM   #2753
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
What octane gas was this on, and how much boost? Any ball park ideas on pricing? I'm guessing close to the 9k mark?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 12-14-2013, 03:19 PM   #2754
AVOturboworld
That was on the race gas, 108 octane unleaded at 13psi of boost. We will be testing it on regular pump octanes and at higher boost levels on the race gas.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 12-14-2013, 11:35 PM   #2755
Pete156
I like to eat!
Holy Cow! A 3" Overpipe? How on earth did that fit? Now this engine can REALLY breathe!
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
OICU812 (12-17-2013)
Old 12-15-2013, 09:11 PM   #2756
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Hey guys, I look to be ordering an AVO turbo kit right away here for my FRS and I am wondering if there is a flange fitting for a recirculating BOV on the stock Stg 1 charge pipe (to throttle body)?
thanks!
Edit looks like it does! found some pictures
The Following User Says Thank You to SkAsphalt For This Useful Post:
Jason@DSG (12-15-2013)
Old 12-17-2013, 03:21 AM   #2757
AVOturboworld
It is tight, and I'd certainly suggest putting engine mounts in at the same time.
Old 12-17-2013, 04:09 AM   #2758
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
It's amazing how this can even fit? Awesome that improvements continue!!
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
