AVOturboworld
Old 04-20-2013, 07:15 AM   #2451
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Originally Posted by Calum View Post
any chance you could ninja-edit the rpms in?
The results look great, as always.
Ha! Same thing I was thinking. Based on the other charts posted, it looks like the first line is 2000 rpm and in 500 rpm increments, so it is showing 2000 to 7500 rpm.
cmss2000 is offline   Reply With Quote
Old 04-20-2013, 11:53 AM   #2452
dabocx
dabocx's Avatar
Drives: Scion FRS
So what actuator do we buy if we plan to run E85? The 7psi one should be enough for 10-11psi on 93 but what would i need if i plan for e85?
dabocx is offline   Reply With Quote
Old 04-20-2013, 12:50 PM   #2453
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Ok, I fixed the chart:
....just kidding! The original charts have the rpm's back in them.
The new 7psi actuator should carry you from 7~14psi fairly easily with some sort of boost controller. It's going to be more of a question of, what's your final boost goal vs. if the car will ever have to run on pump gas.
AVOturboworld is offline   Reply With Quote
The Following 5 Users Say Thank You to AVOturboworld For This Useful Post:
BRZranger (04-20-2013), Calum (04-20-2013), dabocx (04-20-2013), Draco_PR23 (04-20-2013), Sportsguy83 (04-20-2013)
Old 04-20-2013, 01:29 PM   #2454
cmss2000
You're supposed to draw that on a knapkin or toilet paper.
Old 04-20-2013, 03:42 PM   #2455
Calum
That Guy
Drives: 2013 asphalt FRS MT
Updates to the turbo kits:
We will be shipping kits out with newer, updated wastegate boost actuators. I've been testing the updated 7psi and 5psi actuator on 91 octane in California, and performance has been excellent.
Here are dyno charts of the new 5psi and the new 7psi on my car. These charts are purely on wastegate pressure, 92 octane, with no modifications to the tuning maps.
These were done on the 91 Octane maps, correct? If so, how will that effect the outcome now that you're running 92 Octane?
Thanks for the RPM's. I was pretty sure that's what they were, I just like to be sure. I can't believe you guys are starting your pulls at 2000 rpm, and making good improvements even there. Sure beats the pants off of vortech
The Following User Says Thank You to Calum For This Useful Post:
Cal3000 (05-05-2013)
Old 04-20-2013, 04:30 PM   #2456
dabocx
dabocx's Avatar
Drives: Scion FRS
350-400whp?
Old 04-20-2013, 04:48 PM   #2457
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
if we got the kit already, can we get the upgraded wastegates for frees ????? or maybe a discount ?
killerkid08 is offline   Reply With Quote
Old 04-20-2013, 05:21 PM   #2458
buditjoenawan
Drives: Very very slowly
But the lower torque in lower RPMs help with traction issues.
buditjoenawan is offline   Reply With Quote
Old 04-20-2013, 05:23 PM   #2459
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Does anybody know what oil pump this kit is using and where to get one?
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Calum (04-20-2013)
Old 04-20-2013, 05:29 PM   #2460
Calum
That Guy
Good question. I've actually been wondering this myself. From what I understand it's an OEM setup. If I do go with another kit I'd really like the stability of a mechanical OEM pump.
Old 04-20-2013, 05:36 PM   #2461
Calum
That Guy
Originally Posted by dabocx View Post
350-400whp?
I'm not here to argue their merits and I really don't want to have AVO's thread go there. I was only referring to the 40 extra hp at 2500 rpm this kit showed on this dyno, on this car, and on this day, vs the highest dyno I've seen from a Vortech kit. That Vortech kit made a ton more at the top end though. Different strokes for different folks.
Old 04-20-2013, 06:07 PM   #2462
dabocx
dabocx's Avatar
Drives: Scion FRS
I was not responding to you, i was responding to AVOturbo. They asked what my goals were and I forgot to quote them.
The Following User Says Thank You to dabocx For This Useful Post:
Calum (04-20-2013)
Old 04-20-2013, 07:38 PM   #2463
normanb21
Drives: black frs
I had an 2005 subaru sti stage 2 with custom tune. It made 271whp and 371wtq. The torque peaked at 2800rpm and dropped off from there. How would the frs with this stage one turbo compare to my sti?
normanb21 is offline   Reply With Quote
Old 04-20-2013, 08:10 PM   #2464
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
