#2367 | |
Drives: GT86
Unfortunately no, noone has manned up to my challenge yet.
| The Following User Says Thank You to ft_sjo For This Useful Post: | vubaru (03-26-2013) |
#2368 |
Drives: Subaru BRZ Limited
Has anyone received a march shipment of these kits? Just wondering if and when the second set of kits will begin shipping?
#2369 |
Drives: 2013 "AVO Orange" FR-S
They'll be shipping a bit late, from the end of this week and through the next 2 weeks. Our apologies, just got delayed a bit on some components.
#2370 | |
Drives: 2013 Black FR-S
A wastegate senses the pressure in the system via a vac hose and maintains it via a spring with a certain psi rating. On a turbo motor boost creeping up means: 1. an inability of the waste gate system to expel the gas enough to keep boost stable. This can be due to: A. Boost control, if there is one, is faulty or un-tuned. B. malfunctioning waste gate flapper door (in internal gated system) or an inadequate wastegate size C. Boost leak in the system causing the signal to the waste gate to be less than what it is. This allows boost to reach higher levels before the waste gate opens. Vu, I am sure you have experts working on fixing your problems but these are the areas on the system you can check yourself. I've had an internally waste gated turbo have a sticky flapper door which prevented the door from opening fully. Boost creep resulted. I've also had broken vac hoses causing the waste gate to not open when it should. And lastly I have had an ebc that just couldn't do what it was supposed to do. Switched to a manual one and it was fixed. Last edited by sw20kosh; 03-26-2013 at 02:10 PM. |
| The Following User Says Thank You to sw20kosh For This Useful Post: | Alienate (03-26-2013) |
#2371 |
Don't forget the rare, but applicable case of wastegate control rod adjustment. I've gotten internally gated kits where the arm from the wastegate actuator to the flapper door needed to be adjusted because of boost creep.
#2372 |
Drives: 1986 MR2
What's up with the boost decrease from 4.5psi to 4psi from 3k to 5k rpm?
#2373 |
I'm waiting for some log analysis, but right now we suspect a bit too much retard on the ign. timing, especially in that range, along with a adjustable boost actuator rod being screwed up a bit too tight.
We know from experience that the kit will maintain a smooth boost curve, even at higher boost levels. 8psi on Stage 1.5, with full exhaust, MAP sensor, 7psi Actuator ![]() 10psi on Stage 1.5+, with full exhaust, MAP sensor, 7psi Actuator ![]() So just looking at sorting out what it is specifically. |
| The Following 7 Users Say Thank You to AVOturboworld For This Useful Post: | Alienate (03-27-2013), BRZranger (03-26-2013), dabocx (03-26-2013), Draco_PR23 (03-27-2013), MSTiFK8R (03-27-2013), SkAsphalt (08-13-2014), Sportsguy83 (03-26-2013) |
#2375 | |
Drives: GT86
#2376 |
Drives: GT86
Looks like Fensport in the UK are doing well with the AVO kit:
![]() They claim the calibration/map is not finished yet. |
#2377 |
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
^^^ NICE! Looks really similar to ours, a little more power due to generally better gas I'm assuming...
Regards, Bob @ Drift-Office, LLC |
#2378 |
Drives: BRZ WRB
#2379 |
Drives: GT86
#2380 |
Does theirs spool up faster due to their gas?
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
