AVOturboworld
Old 03-24-2013, 10:55 AM   #2353
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by scraejtp View Post
I would almost consider that oil temperature as overheating. I don't think anyone was expecting overheating to the point the car wouldn't run.
That is way too hot, where were you measuring oil temperature?
While I understand your valid point that it is too hot, I believe the term "overheating" was used here meaning when you see the temperature gauge in the car go to H and need to stop using it.
Also, synthetic oil is not expected to break up at those temperatures. But I do agree with you, I don't want those temperatures in my car, but then I also don't plan on tracking my car more than a few times a year. I got some heat mitigating parts on the way.
Old 03-24-2013, 02:07 PM   #2354
dabocx
dabocx's Avatar
Drives: Scion FRS
Anyone going try out the Perrin CAI? Still wondering if itll work.
dabocx is offline   Reply With Quote
Old 03-24-2013, 06:52 PM   #2355
xwd
Overheating can apply to anything really. 135-140c is too high, the oil no matter what it is will thin out and you'll be running very little oil pressure which isn't good. If you are hitting like 125-130c+ I'd be looking at an oil cooler.
Old 03-24-2013, 08:21 PM   #2356
Sportsguy83
Drives: Limited BRZ
Me I don't see why it wouldn't, fits right with the stock tube which is the exact location AVO uses. You'll have you anwser by next weekend.
Yes, I agree 100% with all your points.
Old 03-24-2013, 09:21 PM   #2357
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
I would almost consider that oil temperature as overheating. I don't think many people were expecting overheating to the point of limp mode/not running.
80 laps in one day - trust me, we were not expecting the oil to run cool! This was a stress test, we wanted to see what the oil and water temps would be like with no external coolers while running the turbo kit flat out.
As mentioned previously, we do suggest running an oil cooler if you are going to circuit race with the kit, but to better clarify that, we would suggest to run the oil cooler, period, if you are going to be doing a lot of circuit racing, n/a or turbocharged. Even the n/a's will be running quite hot. And when you make more hp, you have more heat in the engine. A 250whp n/a setup will run hotter than a 170whp n/a setup.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (03-25-2013)
Old 03-25-2013, 03:36 AM   #2358
dabocx
dabocx's Avatar
Drives: Scion FRS
I think im going to start piecing stuff together.
7 psi aculator
AFR/Boost/oil temp gauges
Fuel pump/injectors
3 bar Map sensor
Catch can
Hopefully that will let me run 10-11psi on 93.
Old 03-25-2013, 06:40 AM   #2359
Sportsguy83
Drives: Limited BRZ
7 psi aculator
Fuel pump/injectors
3 bar Map sensor
Catch can
I have oil temp gauge for sale right now (Price negotiable) and yes, the fuel pump injectors will allow you to run 11 psi on 93
Old 03-25-2013, 07:59 AM   #2360
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
which cc' injectors?
and which fuel pump are you looking for?
I'd love to reach 13-14 psi on 93
MSTiFK8R is offline   Reply With Quote
Old 03-25-2013, 08:05 AM   #2361
Sportsguy83
Drives: Limited BRZ
I'm not going to buy now, but did some research and the injectors I believe are best are the 550cc from Visconti. For fuel pump I'm still waiting for something more "drop in" than the current offerings.
Old 03-25-2013, 08:14 AM   #2362
dabocx
dabocx's Avatar
Drives: Scion FRS
Ill think about the gauge but im still trying to find a way to mount the 3 gauges without it looking ridiculous and blocking stuff.
The Following User Says Thank You to dabocx For This Useful Post:
Old 03-25-2013, 08:24 AM   #2363
Sportsguy83
Drives: Limited BRZ
You only need two. AFR/Boost can be had in one gauge. AEM Failsafe.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
dabocx (03-25-2013)
Old 03-26-2013, 03:38 AM   #2364
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by vubaru View Post
So I made that 247 WHP at about 6.4 PSI (a little above 6).
I can still improve on these numbers by getting the boost up to spec, especially in the torque department.
I kinda like that lol. It must feel like v-tec kicked in yo.
In fantasy land I'd like to keep boost even untill 6500 rpms when the VE starts to drop. That is where I would adjust the EBC to increase boost to keep torque flat.
Old 03-26-2013, 04:05 AM   #2365
ft_sjo
Drives: GT86
You don't need an EBC to keep a flat boost curve. Dropping boost with revs is often a sign of a turbocharger of less-than-ideal spec for the application.
That boost curve above is just weird. I can only assume there's an EBC hooked up, or the OE ECU is doing some boost control, badly.
But as you say, vubaru, you intend to get this sorted. I'm sure it'll be great after that's done.
Old 03-26-2013, 11:08 AM   #2366
AllDayJonRay
Drives: 2013 Ultramarine FR-S
What kosh was referring to was not keeping a flat boost curve, it was manipulating the boost to keep the torque curve flat.
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
The Following User Says Thank You to AllDayJonRay For This Useful Post:
sw20kosh (03-26-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
