AVOturboworld
Old 03-08-2013, 03:49 PM   #2297
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Hm... so I'll need motor mounts and tranny cooler at a minimum....
zohare is offline   Reply With Quote
Old 03-08-2013, 04:16 PM   #2298
OrbitalEllipses
Drives: Attitude
Your car needed a trans cooler to begin with. It's the prerequisite first mod for every AT.
Old 03-08-2013, 04:45 PM   #2299
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by Gen View Post
Are you saying the engine mounts can't handle 7+ psi or are you simply using it as an example?
At 7+psi, I'm seeing a lot of movement on the exhaust that wasn't there at 5psi. It's not a factor during regular driving, freeway, even spirited take-off's from a stop light. It does come up when you are drifting it sideways on wide tyres at higher RPM's, or if you are doing a heavy launch.
Does it make engine mounts absolutely necessary at 7~8psi? Probably not, depending on your driving style. At 10~14psi? Yeah, I'd say they are necessary. However, they are both relatively cheap, and relatively easy to put in, so of all the modifications, this is one that I find easy to recommend.
AVOturboworld is offline   Reply With Quote
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (03-08-2013), BRZranger (03-08-2013), civicdrivr (03-08-2013), cmss2000 (03-08-2013)
Old 03-09-2013, 10:00 PM   #2300
AVOturboworld
[ame="http://www.youtube.com/watch?v=7b0llaKu3xQ"]Just enjoying the Turbo FR-S on a sunny day. - YouTube[/ame]
The Following 5 Users Say Thank You to AVOturboworld For This Useful Post:
Calum (03-13-2013), kidgogeta (03-10-2013), mact (03-09-2013), Marcoscrdo (03-13-2013), Sargy (03-10-2013)
Old 03-09-2013, 10:30 PM   #2301
mact
Drives: 13 GTI
I understand your kit uses the factory air pump location to drive an oil pump for the turbo. Are you having any leak issues with the pump there instead of the block-off plate?
mact is offline   Reply With Quote
Old 03-09-2013, 10:55 PM   #2302
AVOturboworld
No, it just needs to be well silicone sealed when being put together - much the same as the OEM plates.
Old 03-10-2013, 06:49 AM   #2303
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
So what clutch are engine mounts are you going to be recommending
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 03-13-2013, 02:39 AM   #2304
sw20kosh
Drives: 2013 Black FR-S
Pure sex! Sounds so very good with that combo of parts. Any resonance in the cabin? Any drone?
The Following User Says Thank You to sw20kosh For This Useful Post:
Sportsguy83 (03-13-2013)
Old 03-13-2013, 04:38 AM   #2305
ft_sjo
Drives: GT86
Originally Posted by vubaru View Post
AVO Stage 1 w/ AVO UELs, Nameless overpipe/downpipe combo with helmholtz resonator, and Milltek unresonated catback.
Finally sounds like a Subaru.
Looks like it needs a bit of tuning on the transients.
Old 03-13-2013, 06:24 AM   #2306
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Sounds so awesome!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
vubaru (03-13-2013)
Old 03-13-2013, 10:59 AM   #2307
ft_sjo
Drives: GT86
What do you mean?
It stutters when you stab the throttle from idle.
Old 03-13-2013, 11:08 AM   #2308
Sportsguy83
Drives: Limited BRZ
Don't hear what you mean at all, and there is nothing wrong with the tune. No stuttering.
What he means is that when you blip the throttle it seems the car stutters a little bit before reacting and raising RPM's.
vubaru (03-13-2013)
Old 03-13-2013, 11:16 AM   #2309
Sportsguy83
Drives: Limited BRZ
No problem I will take the video down then.
Not trying to get AVO criticised.
Don't take it as harsh criticism, it is nothing dangerous or extremely out of place, it just needs minor tweaks. It also says nothing bad about AVO.
Old 03-13-2013, 11:25 AM   #2310
Calum
That Guy
Drives: 2013 asphalt FRS MT
Holy fuck that sounds incredible!!
I need a kleenex now.
The Following User Says Thank You to Calum For This Useful Post:
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
