AVOturboworld
Old 02-21-2013, 07:09 PM   #2241
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by diss7 View Post
Removing a cat is not what we're talking about.
You don't want any restriction for peak power, this is why high HP cars have as little exhaust as possible. But back pressue helps spool turbos. When you're talking high HP, using a smaller exhaust to create back pressure to generate spool sooner will act as a massive restriction on peak power.
This is not the case for this setup.
Edit - Prove to me with dyno graphs showing the same car running the same turbo setup, the only difference being a bigger exhuast, that shows the larger exhaust helps spool. Until then I still call BS.
Is a 2.5" system going to be a significant restriction on this kit? No its not. So, use it, as the smaller piping will create more back pressure to help the turbo spool sooner.
Quick google search netted me this result - http://www.dsmtuners.com/forums/turb...provement.html
Not a graph but it provides an outside source on how his power and spool time improved by going from a 2.5" to 3" exhaust.
I completely agree that a 2.5" is fine for this kit, thats not questionable. All im saying is that you DONT want backpressure with a turbo kit, and eventually 3" WILL be an improvement. The higher the HP the bigger the improvement. I mentioned the HFC due to the issue of restriction is results in terms of making power on a turbo application.
Tansey86 is offline   Reply With Quote
Old 02-21-2013, 07:15 PM   #2242
sw20kosh
Drives: 2013 Black FR-S
Its 2013... The backpressure theory has been debunked. In no way shape or form is back pressure beneficial to FI. In most cases back pressure isn't even useful in NA applications.
I gained 400 rpm of spool upgrading from 2.5" to 3" piping on my Mr2 turbo and had HP gains everywhere.
The Following User Says Thank You to sw20kosh For This Useful Post:
Tansey86 (02-21-2013)
Old 02-21-2013, 07:16 PM   #2243
SnapOv3st3r
Drives: 400whp Scion tC
Turbo need backpressure? Umm...No.
SnapOv3st3r is offline   Reply With Quote
The Following User Says Thank You to SnapOv3st3r For This Useful Post:
Old 02-21-2013, 07:19 PM   #2244
diss7
Drives: AE86, 2x GT86, TE27
Was anything else changed at the time?
Alot of 'proof' on this point on the net are dynos where a 3" has been installed and more boost or the tune altered.
By the same theory, going to 4" would be even more benefical, and having no exhaust at all would be better again.
I don't want to further clutter this thread on this point, but happy to discuss further in another thread specifically about this.
Edit - one last point I will make, is consider that 95% of the time you aren't driving on boost. Now, if you're not on boost the car is effectively less powerful than the same car with no turbo attached at all. Whether its rev/load dependant, its going to spool quicker with some back pressure. I'm not at all arguing whether back pressure is needed once there is boost, the point I am making is back pressure is better for off boost and boost transitition (spooling). I would much rather lose a few peak numbers to have the car perform better, in the range that I am using it for 95% of the time. Sure, if the size of the exhaust was robbing 10-20% of peak power, thats a different story.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
MSTiFK8R (02-22-2013)
Old 02-21-2013, 07:25 PM   #2245
Tansey86
Tansey86's Avatar
http://www.ft86club.com/forums/showthread.php?t=29525 - In an attempt to avoid " clutter "
Old 02-23-2013, 06:23 PM   #2246
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
I'll be at the Importmeet.com event at the XXX Rootbeer in Issaquah, WA tomorrow. Boothing it up and showing off the car - spent the day cleaning it and packing.
AVOturboworld is offline   Reply With Quote
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
Draco_PR23 (02-24-2013), SanDiegoFRS (02-27-2013), Sportsguy83 (02-23-2013), vubaru (02-24-2013)
Old 02-23-2013, 11:49 PM   #2247
sw20kosh
Why is your FR-S looking so good I just dont understand it!?!?! =)
I really like that vinyl stripe you used on the side of the car. Nice touch.
Old 02-24-2013, 10:47 AM   #2248
brzadmir
Drives: 13' BRZ, 05' 325xi, 02' RAV4
Originally Posted by AVOturboworld View Post
The AVO turbo, UEL manifold, and turbo discharge pipe as a unit weighs 29lbs - the stock exhaust manifold that those replace weighs 20.5lbs. After that, you are adding in the weight of the FMIC and it's silicone hoses. So we are talking about 8~9 lbs in the same location at the engine, then another 28~30lbs for the FMIC portion of the kit.
Sorry guys, do not feel like flipping through the whole forum but, from what i remember reading through the forum is AVO created a UEL header for their turbocharger, can that UEL Header be sold separately? Not looking to turbocharge or supercharge my car, creating a NA build so I'd love to have the UEL Header towards my NA build.
brzadmir is offline   Reply With Quote
Old 02-24-2013, 10:59 AM   #2249
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
AFAIK the UEL header + the turbo together is what lines up with the OEM header connection. That means the UEL header alone would be offset a bit from where the OEM header connects to the rest of the exhaust.
nataku is offline   Reply With Quote
Old 02-24-2013, 11:00 AM   #2250
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Just look at page one of this thread. It is made to bolt up to their turbo. Even if they sell it to you, it won't be a straight bolt-on. You'll need to fabricate another piece to connect it to your over-pipe.
cmss2000 is offline   Reply With Quote
Old 02-24-2013, 11:14 AM   #2251
brzadmir
So its irrelevant to buy the UEL even if they were to sell it right? Rather off buying a aftermarket UEL headers that's a straight bolt on as opposed to these?
Old 02-24-2013, 11:21 AM   #2252
Calum
That Guy
Drives: 2013 asphalt FRS MT
Is this gonna be the most quoted post ever?
Try looking for the Borla UEL header. I don't have any first hand experience, so do your research, but it's the only one I know of.
The Following User Says Thank You to Calum For This Useful Post:
vubaru (02-24-2013)
Old 02-24-2013, 11:38 AM   #2253
brzadmir
I did my research and if you see for yourself, The Borla UEL header shows to be ineffective reason being there actually loosing WHP. There reproducing the design to make it more efficient. Reason i am not purchasing and i want avos product due to their quality.
The Following User Says Thank You to brzadmir For This Useful Post:
Calum (02-24-2013)
Old 02-24-2013, 03:15 PM   #2254
cmss2000
Definitely!
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
