#2213 | |
Pegasus White
Drives: 86
Driving: Pegasus White Manual GTS 86.
#2214 |
I Love custom Turbo kits
Drives: Limited BRZ
When you get the kit, change fueling and get a custom tune at higher Boost. AVO provides a base map, they don't tune specific setups. The custom tuner will take care of you (I am getting my kit and right off the bat getting a custom tune to extract all the HP available for my weather conditions).
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | DriftEightSix (02-12-2013) |
#2215 | |
Drives: BRZ WRB
![]() Would you be able to recommend fueling components to start looking for to cover 14psi? I mean which cc rate should injectors be and which lph a fuel pump should to be on a safe side? Would it be possible to include these fuel items in the package? ( personally I'm tempting against Deatschwerks 700cc's & Deatschwerks 265lph ) I ask this because I know, that different injector sizes need different fuel maps even for start-up. I am going to have a Pro-tune ASA I put the kit on, but I think I will need your basemap to allow me to start the engine up and roll to the tune spot in some time. Possible? Mike Last edited by MSTiFK8R; 02-13-2013 at 05:47 PM. |
#2216 |
Drives: '14 Maybe
Sorry if this was already covered, but how much weight does the kit add to the car and what's the final weight distribution?
#2217 | |
Drives: 2013 "AVO Orange" FR-S
| The Following 4 Users Say Thank You to AVOturboworld For This Useful Post: |
#2218 |
Drives: '14 Maybe
Thanks for the info, that's not bad at all.
#2219 | |
Pegasus White
Drives: 86
#2220 |
Drives: Scion FRS
Really looking forward what stage 2 does, i want to see how the top end holds up. Still 1400 for the stage 2 is not bad and it should be less for those already have a exhaust
#2221 |
Drives: 2003 Subaru Outback
Any update on the high flow intake kit?
#2222 |
Drives: AVO BRZ
We are going to use Visconti's SPD pump and his ~500cc short barrel injectors as well as an omni sensor to make around 10-14 psi on e85. Should have results in the next fortnight for you guys.
| The Following 8 Users Say Thank You to nix For This Useful Post: | cmss2000 (02-17-2013), dabocx (02-17-2013), DriftEightSix (02-18-2013), mact (02-17-2013), MSTiFK8R (02-19-2013), OjiGeorge (02-18-2013), Sportsguy83 (02-17-2013), Tansey86 (02-17-2013) |
#2223 |
Drives: Sonic Blue 86GT Manual
#2224 | |
Pegasus White
Drives: 86
What size exhaust are you running?
#2225 |
Drives: Toyota 86, Black, MT
I'm curious - has anyone done any 0-100km/h testing with the AVO Stage 1 kit installed?
#2226 |
Drives: Perrin/VORTECH Supercharger TestBRZ
is there any way to oil the turbo without the extra oil pump? cant one elect to use the cars oil pump pressure?
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
