AVOturboworld
Old 01-24-2013, 05:12 PM   #2143
OrbitalEllipses
Drives: Attitude
Originally Posted by industrial View Post
Really any car with a turbo should have a boost gauge!
A car that sees boost, but doesn't have a boost gauge is stupid. When the WRX came out it wasn't even an option! At least in '03 or '04 I think they started offering the option. Still don't think they're standard in Subarus though.
Old 01-24-2013, 05:22 PM   #2144
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
AFR and boost should be mandatory on all boosted cars especially with an aftermarket tune
Tansey86 is offline   Reply With Quote
Old 01-24-2013, 05:25 PM   #2145
diss7
Drives: AE86, 2x GT86, TE27
I'd prefer a stand alone ecu, that can sense all of this automatically, and pull back timing/power if anything goes outside set parameters. A good ecu is going to react much quicker than any driver.
diss7 is offline   Reply With Quote
Old 01-24-2013, 05:32 PM   #2146
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I agree but really on turbos especially. What if the wastegate gets stuck?
My 02' wrx came with this gem off the lot:
I think I told my friends I was boosting .1 mpa and nobody had a clue wtf I was saying...
industrial is offline   Reply With Quote
Old 01-24-2013, 05:36 PM   #2147
OrbitalEllipses
Drives: Attitude
They offered the Lamco in '02? Hm, didn't know that. Thought it was a later addition. I stand corrected. I think they finally got the boost gauges in American units in '08; a whole generation later.
Old 01-24-2013, 07:19 PM   #2148
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I believe 2 bar+ MAP sensors are about $100? (See Below, Roadstercycle installed an 06+ S2000 4 bar sensor)
Originally Posted by Roadstercycle View Post
I put a 4 bar S2000 Honda map sensor in my setup. plug and play.
3 bar will work fine too. Just because you need help with a map sensor does not mean you are not capable of building an awesome turbo setup.
Old 01-24-2013, 09:11 PM   #2149
MANDALAY
Drives: MR2
Really why ?
You going to tell me that you will be looking at those gauges while your driving ?
Sorry i dont believe that, then you will probably add another 6 gauges for oil temp etc all over your dash.
Not needed at all , proper tune , alarm setting to back off and ability to log so as to see whats happening.
A shift light is much better , that way you will see it rather than looking at the tacho
MANDALAY is offline   Reply With Quote
Old 01-24-2013, 09:21 PM   #2150
Tansey86
Tansey86's Avatar
Originally Posted by MANDALAY View Post
Really why ?
If they are positioned correctly they are easy to see and don't require you to stare at them for 5 minutes. I just feel they are things that are great to have in terms of preventive maintenance, especially since its like 150 bucks to setup 2 gauges. Nobody says you have to do it, I just think they serve a great purpose.
Old 01-25-2013, 01:26 AM   #2151
scyzer
Drives: GTS 86
Im commenting on pricing because I'm curious and people are asking me questions I can't answer.
Those questions include map sensor questions... It's a good a valid question...
I think this is a good kit at a good price point but customers need to know if they're going to need additional hardware.
But clearly AVOWORLD and my self disagree of what the factory map sensor is good for, unless I misunderstood.
No I don't think I'm the only person that can tune* forced induction, many other vendors on here have proved that including AVO.
This wasn't meant to out anyone just real simply friendly questions.
Btw you only need one custom map for a safe boot cut.
So I don't want to drag this on but the factory map sensor is good for 4-5 psi at best, this kit or any kit should include a map sensor so a boost cut can be out in and the the customer can always datalog boost pressure. Can you do with out it? I guess.. But at least inform them so it's not a after thought
John
A previous post:
Originally Posted by AVOturboworld View Post
The stock map sensor works on our 5psi build, so no, no reason to add it to the base kit at this time.
scyzer is offline   Reply With Quote
Old 01-25-2013, 01:30 AM   #2152
Visconti
Drives: 05 STi
^ ok but what happens when the car runs more than 5 psi .. You'd never know, also wouldn't be able to have a boost cut for safety.
I guess based on this info i would suggest that anyone getting this kit should invest in a upgraded map sensor .
If you run 5 psi you'll want a 7-8 psi boost cut
John
Visconti is offline   Reply With Quote
Old 01-25-2013, 07:51 AM   #2153
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
John
John,
Which MAP sensor do you recommend?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-25-2013, 08:24 AM   #2154
Visconti
Drives: 05 STi
Originally Posted by DriftEightSix View Post
John,
Omni 2.5 or 3 bar
I like the 3bar because anyone can use it, so easy for resell later down the road
Old 01-25-2013, 12:39 PM   #2155
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
I can't wait to get my hands on this kit, but from what I'm reading since i have installed injen intake, Motiv concepts test pipe, over pipe and a Fujitsubo exhaust this kit with it's stage 1 map will not work on my car?
mnsayer is offline   Reply With Quote
Old 01-25-2013, 03:27 PM   #2156
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
The stage 1 base map would get you started up and to a tuner, but I wouldn't run it hard or long term. Changing that many components brings it beyond the stage 1 parameters.
It's the same as, say, adding a boost controller and running the car at 8psi - the base map isn't designed for that.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
DriftEightSix (01-25-2013)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
