AVOturboworld
Old 12-04-2012, 10:10 PM   #1821
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
This kit has to have both a waste gate and a blow off valve. The waste gate in this case is an internal waste gate because its part of the turbo assembly, the waste gate is required to control max boost level by bleeding off exhaust gases around the turbo. A blow off valve is required to bleed/blow off the compressed intake charge when the throttle body closes, this is not optional. Now there is recirculating BOV's and vent to atmosphere BOV's and correct me if I'm wrong but a Bosch recirculating BOV does come with the stage 1 kit and recirculates the bleed/blown off compressed intake charge into the silicone opening shown here.
Lawnik is offline   Reply With Quote
Old 12-04-2012, 10:17 PM   #1822
nix
nix's Avatar
Drives: AVO BRZ
A BOV isn't mandatory at all for low boost turbo setups but it's a good idea.
I got some bad news today from AVO ... confirmation of the factory delay pushing the first run to mid January. There will be a couple of preview kits going out this month to each continent though so we should still see some nice builds and magazine articles etc before Christmas.
nix is offline   Reply With Quote
Old 12-04-2012, 10:19 PM   #1823
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by Lawnik View Post
...correct me if I'm wrong but a Bosch recirculating BOV does come with the stage 1 kit..
It depends who and where you get the kit from. In AU the base kit comes with just the hardware, then the ecutek map, bov, air filter and catback exhaust are all add-ons. I can't speak for US but I'm pretty sure Paul has answered this already.
Old 12-04-2012, 10:39 PM   #1824
Lawnik
Lawnik's Avatar
Is the port in the picture just going to be plugged then along with the port on the underside of the pipe that connects to the TB?
I would not call this an option if what you say is true its an additional cost over the base kit which would be incomplete without it.
Old 12-04-2012, 10:43 PM   #1825
Lawnik
Lawnik's Avatar
It would be nice if their website had an itemized list of what's in the kit.
Old 12-04-2012, 10:48 PM   #1826
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
It used to. I noticed the itemization wasn't there when I put down my deposit.
I went with the ceramic coating upcharge and BOV.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 12-04-2012, 11:19 PM   #1827
Lawnik
Lawnik's Avatar
Nice choices
Old 12-05-2012, 12:10 AM   #1828
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Also went with the ceramic coating and BOV
Bummer about the production delays.
vubaru is offline   Reply With Quote
The Following User Says Thank You to vubaru For This Useful Post:
ngabdala (12-05-2012)
Old 12-05-2012, 01:45 AM   #1829
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
I'd love to have ceramic coating of the whole manifold\turbo\overpipe combo
I just hate heat wraps - ugly looking and oil&mud- absorbent = fire risky & smelly
OMG look what brake cool ducting you gotta have to cope with THAT MUCH POWA... yikes... I wonder why it's not listed in the kit description...)
MSTiFK8R is offline   Reply With Quote
Old 12-05-2012, 05:20 PM   #1830
Coastermikey
Drives: BRZ DGM
You can see the waste gate actuator in the pic, as for bov, it does not come with the kit.
Coastermikey is offline   Reply With Quote
Old 12-05-2012, 05:50 PM   #1831
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
I think there have a BOV included with the avo kit.
Its a cheap plastic bypass valve. ( Type on google images : Bosh BPV )
It is exactly the same part that usually comes on a factory turbocharged car like I use to have on my stock RX-7 TT and also on the genesis coupe 2.0T.
The air coming out from that valve is pushed back into the intake system and it is almost impossible to hear it. If you unplug this valve, the air will be release into the atmosphere like an aftermarket BOV but the sound it will make will not be really nice to hear...
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 12-05-2012, 05:53 PM   #1832
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You cannot unplug this BPV because that would create a boost leak.
A BPV is different than a BOV. The kit includes a BPV but no BOV. BOV is optional.
Old 12-05-2012, 06:32 PM   #1833
Lawnik
Lawnik's Avatar
BOV and BPV are the same thing, they serve exactly the same function. The only difference is where the compressed intake charge is routed.
The Following User Says Thank You to Lawnik For This Useful Post:
t0dd (12-06-2012)
Old 12-05-2012, 10:03 PM   #1834
NoFear99
NoFear99's Avatar
I did it with my RX-7 and with the Genesis Coupe before to buy a nicer aftermarket BOV and it worked great but the sounds was just like crap...
You just need to put a plug at the place where the BPV was connected to send the air back into the intake system.
The Following User Says Thank You to NoFear99 For This Useful Post:
Sportsguy83 (12-06-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
