#687 |
Drives: 2016 FR-S
Anyone have the PIDs for the knock sensor data?
#688 |
Drives: None
#689 |
Drives: 2016 FR-S
Thanks, I'm aware of that plugin. However, that is a simple calculated knock detector. I'm looking for the knock sensor values like knock correction, learned knock correction, etc.
#690 | |
I love peanut butter
Drives: 2013 SWP BRZ Limited
http://www.tactrix.com/index.php?opt...hk=1&Itemid=53 |
#691 |
Old Fart
I put in the oil temperature PID exactly how it states to put it in, but the readings I get are really erratic. It jumps constantly from as low as 6.4 all the way up to 498,536.
What could be causing this? |
#692 | |
Drives: Neptune GR86
I also have "use Celsius" unchecked.
#693 | |
Alexandrino_Auto
Drives: series.Blue
The Shadetree Project: I turn wrenches
#694 |
Old Fart
Yessir. That's how I have it
#695 |
I have found this site talking about Toyota PID's and I put some of them in.. looks like the wheel speed PIDs seem to be working! I haven't jacked up the car and tested each wheel individually, but I can say that when I'm turning slowly in a parking lot they are all reading different as they should (outside faster than inside) and when I'm going straight they all read what my speedo is reading! I'm going to play with some other ones and see if they are right or accurate. Have fun!
http://www.toyota-4runner.org/5th-ge...orque-app.html @G_Rossney I know you were looking for these too! Not sure if you still are. Last edited by fika84; 06-04-2015 at 09:52 AM. |
#696 |
Old Fart
Doesn't work. I tried the stock oil temp. It's not green, so it's not reading anything.
#697 | |
Alexandrino_Auto
Drives: series.Blue
#698 |
Old Fart
i have version 1.8.52
#699 |
Drives: None
So does the boost only read up to 5.2 with the oem map sensor?
#700 | |
Drives: None
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
