#239 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
George, I have a Hotchkis bar in as a temporary solution until Sam's is ready. If you want, you can give mine a try anytime (Id say this weekend if you were coming to Sebring
). It's slightly softer on its current setting than Sam's but I wanted something to help with the camber challenged car.
#240 | |
Drives: white
FYI: from my understanding, that bar is more then 2x stiffer then Sams bar even in the soft setting. No way it is softer...
#241 |
Dodging cones
The percentages are lower on the soft setting from what I read. Maybe I read it differently?
It says 170% (which is actually 70% due to the way swaybar manufacturers tend to advertise, read Sam's website). Sam's is 185% (true 85%) I believe Edit: Link - http://www.stranoparts.com/partdetai...235&ModelID=36
#242 |
The Hotchkis 25mm is rated at 170% stiffer than stock, the Strano bar is roughly 85%. Both use increase over stock and not the 100%+ increase like the JDM vendors seem to do.
The Hotchkis would be 270% vs 185% for the Strano, its a big bar. |
#243 |
Dodging cones
Oh really? I didn't realize that. Is this for sure? I was so used to everyone else's ratings. I still plan on getting Strano's then selling the Hotchkis, got it as a temporary.
#244 |
Just to double check I looked at some of the other bars Hotchkis sells like the WRX rear bar and they list the rates as like "87%, 115%, etc." so they definitely do not add the 100% like Cusco, Tanabe, and others do. Just using logic, a 25.4mm hollow bar is going to be stiffer than a 22mm hollow bar.
#245 |
Dodging cones
Well damn. We'll see how it does this weekend. I like the way it changed the response in street driving. I have still been able to oversteer a bit so hopefully it's not TOO damn stiff!
#246 | |
Senior Citizen
Drives: Scion FR-S
So on the softer setting the Hotchkis bar would be softer or about the same as the Strano bar...(big assumption!!). |
#247 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
#248 |
Drives: white
Car will push like a pig on exit, but it will feel great in a airport course like serbing, lol. can't use street driving to judge...
#249 |
Dodging cones
I know, I dont except street to give me an indication of performance.
It was a last minute decision to go to that bar as a temporary one. Going to stagger pressure to try to neutralize it. Who knows, it may work well ![]() Never autocrossed out there before (just track days). What makes their layout good for a understeer setup?
#250 |
Drives: white
I havnt been but from looking at youtube the course is long and narrow so not so much the understeer but ur transition will feel great.
#251 |
Dodging cones
That's what Im going for. Transitions before had a lot of oversteer, even with .12 degree toe in on each side. Im at .10 now
#252 |
Had a chance to check out my grinding noise this morning. I took a good look, loaded the suspension and turned the wheels and nothing. I did kind of bend back the brake shield on the side making noise. In the end after dorking around with it for an hour I didn't have anything conclusive. Took the car back out and beat on it, no more noise... I guess I fixed it.
. I did the same parking lot tests I did with the Whiteline bar on its two settings and the Strano bar seems not quite as stiff as the Whiteline on its "21mm" setting. My parking lot test is a mock slalom, stock tires. Both bars mad the car feel a lot more stable than stock. I'm at like 1/16" total toe in. |
| 2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
| What SCCA autocross class will the FRS be most competitive | SVThis | Tracking / Autocross / HPDE / Drifting | 5 | 07-30-2012 04:29 PM |
| Share/discuss (this mornin) 86 Newsletter... | RebootWindows | AUSTRALIA | 6 | 07-19-2012 04:15 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
| Discuss.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 02-11-2012 12:55 PM |
