Old 06-12-2019, 06:26 PM   #4215
codec
Drives: gt86 FIRST edition #86
Did any of you have to replace the injectors?
codec is offline   Reply With Quote
Old 06-13-2019, 08:49 AM   #4216
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Nope.
Helios is offline   Reply With Quote
Old 07-10-2019, 10:01 PM   #4217
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
So, I was finally able to hook up my oil cooler again.
I had it disconnected because I couldn't figure out how to stop leaks from the sandwich plate adapter cluster f*** we have to use in order to have an oil cooler with the kraftworks kit. I tried everything short of devil worship to get the thing to work. Basically we use a spacer on the bottom, and a plate with a sensor on top of that, and then the oil cooler adapter plate on top of that, and finally the oil filter on top of that! So, 3 sandwich plates and an oil filter for grand total of 4 mating surfaces and something somewhere leaking in between.
How did I solve it? I got me a fancy shmancy Skunk2 sandwich plate. I'm not sure when they came out with this thing, but I'm pretty sure it's relatively new to the market. It's basically one giant sandwich plate with an oil temp sensor bung, and the oil cooler adapter all in one! So now I only have two mating surfaces and zero leaks.
I run the mishimoto oil cooler and had the male/female fittings from a motul sandwich plate which is 10AN on both ends. That doesn't fit on the Skunk2 plate. I had to purchase two 8AN male with 10AN flare adapters. The Skunk2 sandwich plate is 8AN.
Oil cooler is 10AN.
I'll edit this post with a pic once my wife gets back from the store with the car.
Here's the links to this stuff if anyone is interested:
Oil Filter Sandwich Adapter - '13-'16 BRZ/ FRS/ FT86
RaceFlux -8AN O-Ring Boss to -10AN Male Flare Adapter Fitting SKU: OM-08-10
these are nice because they have o-rings.
2018 Audi RS3 - Iroz
2005 Long Travel Tundra 4x4
2008 Long Travel Tundra 2wd
MartyMcfly is offline   Reply With Quote
Old 07-11-2019, 02:01 PM   #4218
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
Originally Posted by Sgtfluffy16 View Post
Hate to tell you this buddy, but this is not new. I bought mine a little over a year ago. But just like you said, the craft Works kit requires you to run the Skunk2 oil cooler kit. But the only bad thing about it is the sandwich plate is not thermostatically controlled like the MoCal one
So it is what it is. But so far I'm good and I was on VIR on 100 degree day. With track temps well in excess of 120 with no overheating problems
Not sure how I missed it. Well, it's new to me, and just the fact that I don't have to deal with leaks is enough for me.
Old 07-11-2019, 02:39 PM   #4219
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
The oring supplied with it is super low quality. I replaced mine with viton after it failed
Sent from my iPhone using Tapatalk Pro
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 07-11-2019, 03:26 PM   #4220
Apoc
Apoc's Avatar
do you happen to have a part number for this O ring on the sandwich plate you can provide?
No part number sorry. I just took the adapter plate to my local industrial supply and asked them to find a viton o-ring the same size. I have the old adapter so it may not be the exact same size as yours.
“The World is Flat”
[||•]=(86)=[•||]
Old 07-11-2019, 06:45 PM   #4221
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
Just out of curiosity, I'd like to know where this coming from that the KW SC kits require the Skunk2 oil cooler kit.
Old 07-12-2019, 02:50 PM   #4222
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
They don't require an oil cooler kit. But for our cars, if you track them, it is better to have some sort of external oil cooler. Because of the design of the supercharger mounting plate you have to use the Skunk2 sandwich adapter plate. To obtain your oil lines the run to the cooler or even a mishimoto radiator oil cooler combo
Right. That's well understood. I guess I just misunderstood about requiring a "Skunk2 oil cooler" The kit requires an oil cooler in general, that works well, along with a sandwich plate or stack that also works well. It could be Skunk2 or something else.
Thanks!
Old 07-26-2019, 02:33 PM   #4223
j.F.c.R.a.S
j.F.c.R.a.S's Avatar
Drives: rx8. frs.
Anyone with this kit drift?
If so are you on the new updated belt?
I’ve gone through 1 belt an event this season. Last event, belt lasted two laps. I’m still on the 20mm belt, I guess I need to upgrade, but want to make sure it would be worth it.
I guess with the money I spent on belts I could have bought it already but I didn’t want the belts to go to waste.
j.F.c.R.a.S is offline   Reply With Quote
Old 08-01-2019, 04:41 PM   #4224
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
just thought i'd help:
https://www.ft86club.com/forums/show...3&postcount=23
pgranberg11 is offline   Reply With Quote
Old 08-05-2019, 12:14 PM   #4225
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
how do you even fill your engine with oil? Can the cap even be removed? in all honesty how much was everything? oil cooler, hoses, sandwich plate, fittings, everything that you needed?
You get a long skinny bottom tip funnel. and I also had perrin oil cap. The oem didn't fit.
Something like this:
As far as price goes...
Mocal Thermostat - $170
Mocal Spacer - $16 (these two are sold together)
ES20 (have to call BAT inc. they're the mocal contact for US - extended screw on) - $13.50
2 Mocal 1/2" BSP x -10 fitting - $12 each
Mocal 90 Degree Socketless Push Lock Hose End -10AN - $12
Mocal 45 Degree Socketless Push Lock Hose End -10AN - $15
-10 Aeroquip Socketless Hose, Black - $80
Two remaining fittings on the oil cooler - ~$30
X-PSP-OIL-001 - Oil Filter Spacer for BRZ/FRS Black - $60
X-PSP-OIL-006 - Threaded Extender for Sandwich
Adapter M20 (Oil Feed Pipe) - $25
Mishimoto oil cooler (probably should buy a setrab or mocal instead... mishimoto's fin density isn't the greatest) - $163
You can probably do it for a lot cheaper if you go with cheap hardware on amazon like fragola or whatever else is on there. But I wanted to best I could afford. It gets expensive when you start to price out the hoses if you want black nylon braided, fire sleeve protection, etc...
so in total: $608
Old 08-20-2019, 11:50 AM   #4226
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Hey guys,
Has anyone been in contact with Kraftwerks customer support? I have sent them 2 emails in the last 2 weeks and they have not replied to me. I'm not sure if they have disappeared or they are ignoring me.
I just wanted to inquire about upgrading to the 30mm belt setup along with a high boost pulley.
projek_01 is offline   Reply With Quote
Old 08-20-2019, 04:50 PM   #4227
projek_01
projek_01's Avatar
https://www.ebay.ca/itm/New-TP1200-8...0AAOSwYS9ZYQmw
^great deal on a new 30mm belt. double check the part number/item before you buy!
Old 08-22-2019, 03:38 PM   #4228
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by projek_01 View Post
Hey guys,
ha i'm not surprised. they have literally THE ABSOLUTE WORST customer service on par with Comcast.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
